Question about Acer AC713 17" CRT Monitor
Take apart monitor
I need info on how to takr apart an ACER 2017 monitor.
I took out the two screws and then ?????
There are clips on the opposite end try pressing the back cover inwards
Posted on Aug 16, 2009
Took out marked screws, how does it come apart?
Take it in and have it bench tested.
Terry
Feb 23, 2014 | BenQ MX764 Projector
How do I take apart Acer AL1715 LCD Monitor
You do have to remove stand (the stand hinges are covered by the plastic pieces that you just pop them out) and all the screws. Start at the bottom to crack open the case. See AL1716 (almost the same as 1715):
http://s807.photobucket.com/albums/yy352/budm/ACER%20AL1716/
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 27, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
Acer monitor will not work, not light no
The capacitors are good, no bulging top/seal? Pictures? see example of failed monitors: http://s807.photobucket.com/home/budm/allalbums
Pictures will help a lot.
Mar 19, 2010 | Acer AL1914 19" LCD Monitor
My Acer Aspire One A150 screen is damaged and in inverted colours
"I got somebody to replace the screen for me and it was working until now" this more likely affects your warranty as the warranty seal is tampered..
What did the guy do to get it right did you replace something or just got it serviced..??
I don't user acer but my friend had problems with his lap DVD drive n got replacement. It took 2 weeks though
Sep 05, 2009 | Acer Aspire One PC Notebook
How To Disassemble Acer AL1715 Monitor?
the pedestal has a screw behind it most likely you can remove the cover and find the pedestal screws once that is removed then the last 5th screw. open the screen half's by using a knife or similar thin strong object, and then the rear power board cover will be viewed, their are 4 screws on this and the vga and power connector has screws as well
after this it should be obvious but you can post after you get this far . good hunting
Mar 22, 2009 | Acer AL1715 17" LCD Monitor
My BenQ FP757-12 monitor stopped working
I commend your courage in taking your monitor apart. I hope it was out of warranty when you did it; because it is out of warranty now.
I have no idea where to find the info you are looking for. Monitors are cheap now, though.
Dec 28, 2008 | BenQ FP757-12 17" Flat Panel LCD Monitor
Dismantaling monitor from base
acer monitors are usually put together with 5 screws on the back of the monitor, 4 where you can see them and 1 under the pivot mount, this can be accessed by removing the pivot cover and then unscrewing the pedestal then you can get the last screw, after that you need to pry the half shells apart and then you can get at the cover for the power board the VGA screws and the power socket screws must also be removed.
Oct 25, 2008 | Acer AL1715 17" LCD Monitor
Acer AL1916W 19" LCD Monitor
On a Acer AL2016w and the 2017 it is the far right larger button with the light in the middle of it.
I'm almost positive the AL1916 is in the same place
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
Acer AL 2017 Monitor
I just repaired one.... will likely require that you replace 3 X 220 uf 25 volt capactiros and 2 X 1000 uf 25 volt capacitors. can't miss them the tops are swelled up. but the monitor appears to work now... not bad for 5 bucks worth of parts.
Sep 10, 2008 | Acer AL2017 20" LCD Monitor
Acer AC713 17" CRT Monitor Logo
372 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
