Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
I have a GE refiregetor that has stopped cooling. I opened the back and made sure everything is clean and there are nothing is frozen.
  • 53 Answers
Just check your relay and the wiring connections!
Please see that your plug point gets power supply and earthling is done properly!
turn the thermostat knob to two or three setting in case it is in Zero and your unit should run.
Still it does not start your compressor might have grounded and need replacement.
Posted on Jul 14, 2009
Oven will not unlock after self cleaning
User manual says that the oven must cool off. I am sure this is not the case. Try starting the oven self clean function, and then clear/off to stop the function. Since the oven is cool, perhaps the oven will unlock.
Finally, you could try turning off the circuit breaker and then back on to see if it unlocks - unfortunately you will have to reprogram everything. All else fails, call a technician.
http://www.manualslib.com/download/58340/Ge-Jt912-Jt952.html
Mar 04, 2015 | GE Profile JT952 Electric Double Oven
My ctf1826ar freezer works great but the fridge is not cooling. Nothing is frozen or blocked. When the freezer door is open there is cool air that comes our of the vents in the fridge but when it is...
the frig part not cooling though the freezer works is usually caused by bad air flow due to restriction somewhere. check ur vent settings and make sure not defective, the door rubber insulation may also be defective and not sealing properly after closing? and thus cool air escapes? but if ur feeling noticing air flow from the freezer but not in the fridge, the flow is obstructed, if the flow is off and on, do u notice the sound of the fan always running or does it go off and then on, it may be defective, the only time fan should go off is when in defrost mode?
Sep 27, 2014 | Refrigerators
Our 2004 GE gsl251grb bs refrigerator is freezing food.
1st try cleaning the condenser core cooling fins
Aug 23, 2017 | GE Refrigerators
Have a S/S GE Profile Artica. We came home tonight to find the freezer not cold enough and the fridge sweating inside. I have done the best i could to clean the condenser unit and the evaporator coil in...
the ice maker quit because the tempt in freezer is too warm / like abofe 15 deg./ the sweating is caused by the ice blocking the air flow . . to correct the problem from comming back ( next week ) you will have to replace the heater or defrost thermo . if these are not bad then replace the main control board .. mm hope thes helped ..
Feb 23, 2010 | GE Profile Arctica 25.4 Cubic Feet...
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
Not cooling at all
refridgerator not cooling making clicking noise from back
May 03, 2009 | GE Profile Stainless Bottom-Freezer...
Can't find refrigerator coils/ cooling issues
There're two coils ,the condenser coil wich you already clean (also make sure the condensing fan motor works properly and the fan blades are also clean).The other is the evaporator coil wich is located inside the freezer behind the back wall cover.
Apr 21, 2009 | Refrigerators
Refrigerator will not defrost or cool
Either your fan is going out or you have a blockage.Replace the fan after you totally defrost it.
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked.With out a fan you have no circulation but your freezer may look likes its working becuse it is still frozen,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open 12 to 24 hrs this will free up any clogged tubes. Good luck.
Len West
Feb 16, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE side by side refrigerator is not cooling on one side.
if there is a motor over protector mounted to the compreesor try changing it and that should fix the problem
Jan 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
291 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
