Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Can't start husq. 261
What is the starting procedure for approx. 1997 model 261? do not have manual. just got saw back from shop. new fuel filter, carb cleaned new gas line. what is gas/oil ratio suppose to be? thanks
    Novelist:
  • 168 Answers
Most all of these saws use a 50 to 1 ratio. However, i like to use a two cycle oil that has a TCW3 rating to it. This helps to fight again moisture and condensation when the saw isn't being used.
Posted on Aug 02, 2009
    Problem Solver:
  • 5 Answers
Don;t take this the wrong way, but if you can't start it without a manual, maybe you shouldn't run it. They're very dangerous
Posted on Aug 17, 2009
Help husqvarna 372 chainsaw will not run
check with a husq.dealer,they had some crummy carbs that may need replaced not rebuilt
Mar 06, 2014 | Husqvarna Garden
HUSQVARNA 41 CORRECT FUEL FILTER TO BIG FOR MY FUEL LINE IN TANK--DO I NEED TO GET BIGGER FUEL LINE??
you can get saw specific parts from a Husq. dealer or you can make shift something to get you by. the key is to make sure the hole in the tank is slightly smaller then the diameter of the hose to ensure there is no air leak there. I drill the tank hole out a size at a time until I have to force the hose in that will fit snuggly on the carb inlet then replace the fuel filter with one that fits the line
Mar 20, 2013 | Husqvarna 36 41 50 51 55 136 141 154 254...
My Husq 136 will start but has no torque, if you try to cut it loses power. Have cleaned fuel filter and air filter, no effect.
It sounds like you carburetor is dirty, this is common when they sit for extended amounts of time. First I would try removing the air filter and spraying the carb with carb cleaner and letting it soak in, Then start it up, (it may be difficult) when it starts rev it up and cover the air intake so it could possibly **** the blockage through, other wise you would need to disassemble the carb an manually clean it.
Jan 02, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Cannot start husq 340 have spark but no combustion even if put gas in spark plug hole. have new spark plug
The engine may be flooded--take the plug out, turn the saw upside down, and pull the starter rapidly a few times with the throttle full on. If flooded, a fuel spray will likely come out of the plug hole. Make sure the ignition is OFF when doing this--you don't need a fuel fire! Is the spark at the plug blue and snappy (plug gap set to 0.020")? Replace the plug and see if it will run. Make sure the air filter is clean. Hope this helps!
Oct 16, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
What is the factory setting for the throttle and low & high screws for a Husq 41 (1994)
Workshop Manual for a Husky 357XP/359 (2006 - I will wager yours is similar) follows:
The Husky workshop manual on Appendix A (USA, this probably does not apply to your vintage saw) says "H" 3/4 turn CCW from lightly seated. "L" 1.5 turns CCW from lightly seated.
Page 36 (every other nation on earth) 1 turn CCW from lightly seated for both the "H & L" needles. There is no recommended initial "T" setting. (from manual) "The idling speed is correctly set when the engine runs smoothly in all positions and there is a clear margin to the speed at which the chain starts to move".
These are initial settings and the saw needs to be adjusted for performance. Start with a clean air filter and a fresh fuel mix. I could not find an OM for a 1994, a 1995 says mix @ 50:1 per Husky (1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil).
This explains performance carburetor adjustment better than I can:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. Good Luck. HTH.
Lou
Feb 23, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Hard starting model 345e
The newer 345 Husqvarnsa are very easy to start, providing you dont flood it/ remember the bulb that you push prior to choking and pulling the recoil is an air purge bulb, NOT a PRIMER.Just make sure ther is gas in the bulb and stop pushing it. Also make sure your gasoline mixture is the correct ratio of fifty to one, use only a good synthetic oil like HUsq, echo,redmax. Avoid the high ash oils like store brands and stihl. MOST importantly check the fuel lines for cracks where the line comes out of the tank and bends arround and up into the airbox. They usually last a year or so because of the ethanol in the gas. Good luck
Dec 15, 2009 | Husqvarna Garden
Have plenty of compresssion , are getting fire , seems to be gettin g fuel but still will not start - 570 husqvarna
If as you say it has good compression, spark, and fuel, yet will not start, it is most likely flooded.
Model 570 IPL (may not be your saw)
http://weborder.husqvarna.com/order_static/doc/USA/2009/I09000/I0901006.pdf
Detail G (Muffler) clean Item 3 and try once more.
Remove the plug (wet?). Install a new plug (very inexpensive).
Download your manual and follow the start procedure exactly.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL/Manual
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
My 359 floods in a nano second if I leave the choke engaged once it attempts to start. The only other time it really gave me trouble was one time I failed to set then turn off the choke when it was warm. Setting the choke also sets the fast idle on my saw. Once it has fired pulling the starter with choke on floods it.
If it still does not at least try to start, remove and clean the air filter. Put about a teaspoon of fuel mix in the carburetor throat, reinstall the clean air filter, turn on the ignition, close then open the choke, set the fast idle (if equipped), and try to start it. Did it sputter? If it sputters, attempts to run and quits it probably has a fuel delivery problem.
At this point I think it time to contact a local chainsaw seller mechanic (I use Stihl). For about a tune up/repair estimate. $40 - 60 depending on parts required. If tuned by local shop when you pick it up ask what fuel/oil mix they used (should be 50:1) and use that mix until the next time it needs service (I suggest you affix a self adhering tag near the fuel cap). HTH
Lou
Nov 23, 2009 | Husqvarna Chain Saw 20" Bar
Will not start. Has spark, gas,chain oil,on/off
If everything you say is true it is flooded. Have you tried the EXACT start procedure from the manual?
My 359 floods in a nano second if I leave the choke engaged once it attempts to start. The only other time it really gave me trouble was one time I failed to set then turn off choke when it was warm. Setting the choke also sets the fast idle. Pulling the starter with choke engaged floods it once it has fired. This should be similar to your Operator's Manual.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually first pull)
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) - Don’t pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull)
Incase you've misplaced your manual:
HusqvarnaUSA.com
06 1500198
Nov 23, 2009 | Garden
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
196 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
