Question about Magic Chef CAV2000AWW Top Load Washer
Machine stopped just before draining to go into spin cycle. Now it won't do anything
  • 464 Answers
Check for something being caught in the pump, small sock, bra wire etc.
Posted on Oct 11, 2009
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
Duets washer won't drain
Probably a blocked filter, outlet pipe or pump.
Take the drain hose and lay it flat and lower then the level of the drum and this will drain the machine providing the blockage is not solid. When machine is empty check filter , pipes and pump and remove any blockage found.
Replace drain hose and you should then be able to carry on with your wash or spin the clothes.
Dec 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My washing machine won't finish its cycle?
try the reset again but turn the water off
Feb 25, 2012 | Zanussi Washing Machines
Stops during rinse cycle and won't pump the water out
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My machine stops working after the rinse cycle and won't go into the spin cycle. The water stays in the tub and will not drain. I have unplugged and replugged the machine just to make sure. I wanted to see...
It sounds like the Drain pump may have stopped working. After the rinse cycle, the machine should drain the water and start spinning. The Drain Pump should be at the bottom of the machine.
Feb 22, 2011 | Roper RAS6233KQ Top Load Washer
Washing machine isn't spinning to drain water
suggest that the drive belt is worn and slipping under exess load solution replace belt regards billnkaym
Apr 02, 2009 | Whirlpool LSQ8543J
Magic Chef CAV2000AWW Top Load Washer Logo
146 people viewed this question
Top Magic Chef Washing Machines Experts
Ian Jones
Dan Webster
Dan Webster
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
