Question about Garden
Hi I have a 16hp roper lawn tractor it is about a 1989 model what type of oil goes in the hydrostat transmission Thankyou Richard
    President:
  • 986 Answers
Hydrolic oil I use 46
Posted on Jul 29, 2009
My John Deere rinding lawn mower won't go forword or backwards
John Deere mowers, for the most part, use hydrostatic transmissions. These use an oil of some type (they vary by model) in the transaxle to provide hydraulic pressure to move the tractor. Older tractors will eventually experience some oil leakage over time due to seal wear. If the level gets too low, then you fail to move. Check the oil level in the transaxle. The location of the reservoir varies from model to model. If it is low, after determining the correct oil to use, fill to proper level. Then, start the tractor and work the hydrostatic drive lever forward and backward slowly and continuously until you get full speed operations in both forward and reverse. This can take a few minutes until all the air has been purged from the system.
Oct 03, 2016 | John Deere Garden
Hydrostatic transmission in YTH2348 is very weak, pulls intermittently then stops. I changed the oil put 50wt in it, still doesn't work.
hydrostatics will not work with gear oil they take transmission fluid . or hydraulic fluid check with a dealer or read you manual
Sep 15, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Model 917.203900 22 HP lawn tractor. Shifts consistently into forward but frequently won't shift into reverse. What's wrong?
  1. Craftsman Hydrostatic Transmission Fluid Change - YouTube
    ? 40:15
    www.youtube.com/watch?v=vd1EqFtTYgk
    May 10, 2012 - Uploaded by Smokeasammie
    I change the gear oil and hydrostatic transmission fluid on my Craftsman Lawn Tractor. Fluid per Peerless ...
Jul 20, 2015 | Craftsman Garden
How to fill hydrostatic transmission fluid on Poulan Pro
How do I check the transmission
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Fill Hydrostatic Transmission in Lawn Tractor
http://husqvarna.custhelp.com/app/answers/detail/a_id/387/~/maintenance---what-type-of-oil-is-used-in-the-hydrostatic-transmissions%3F
Jul 28, 2012 | Poulan Garden
Mower won't move in forward or reverse, it just makes a loud wining noise. I've had this happen before but I usually can get it moving.
If this is a hydrostatic drive. Check oil level in transmission. If you have been running it low on oil, it may be too late for the hydrostatic drive unit. If it has a drain plug, drain it and change the oil.
Jul 18, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
What type of oil do I use for a hydrostatic transmission for a murray lawn tractor
Use a lo viscosity hyrolic fluid for you tractor and you will be good to go.
Apr 07, 2010 | Garden
Looking for when the oil and transmission should be changed on Lt
Hey,
Many manufactures recommend a engine oil change every 50hrs more often in extreme conditions,
Most transmissions are sealed units if this is the case company's recommend not to touch these,
If you have a hydrostatic drive or a Zero turn unit with twin hydrostatic drives the transmission oil must be changed every 500 hours or every year whichever comes first as the hydraulic oil brakes down in time, also at these intervals the hydro oil filter must also be changed...
Brad:)
Sep 16, 2009 | Cub Cadet Street Sign- tractor lawn riding...
What kind of oil do I use in a Wheel Horse lawn tractor?
Your Onan engine will do excellent with Mobil One 0w40, Mobile One 5w30.
DO NOT use hydraulic oil in the transmission/transaxle, you will destroy it. Your tractor uses an Eaton 11 Hydrostatic transmission pump with the oil resevour being the cast iron transaxle. The WheelHorse transaxle is as rugged as they come. It uses a solid cast iron housing, case hardened intermediate gears and forged differential gears with an eight pinion differential.
Your transaxle requires 10w40 synthetic or conventional oil as well as a wix 51410 filter or the OEM wheelHorse filter. It should be changed every 100 hours with conventional oil or 250 hours with synthetic. DO NOT use hydraulic oil!
Jun 24, 2009 | Garden
Garden Logo
828 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
