Question about Kenmore Dehumidifiers
I have a 129-25803 Kenmore dehumidifier. It was working great until one day after I emptied it, it ran again but the water was going on the floor. Somehow, the water now drains from the drain hose instead of in the water bucket. I have no idea why this all of a sudden happened. I know it's a simple fix but haven't been able to figure it out. The manual says nothing in the troubleshooting section about water draining from the hose and why it happens. I think it may be a setting or something. Please help.
  • 10,515 Answers
It seems that the Float Switch has been turned off or damaged. Check the float switch and let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 14, 2009
Why is my Kenmore Energy Star 50 pint model 251-50501012 dehumidifier leaking water after I disconnected the drain hose
If you reconnect the drain hose, make sure that it lays flat from the dehumidifier and into the sump pump hole. I did that and it solved my problem of water leaking onto the floor.
Jun 15, 2014 | Kenmore 50 Pint Dehumidifier Electronic...
Kenmore 54351 Dehumidifier is leaking -- water isn't going into the tray, but seems to be leaking out into the floor.
Mine is doing the same thing. The bucket is dry and the floor is flooded, so it is not an inability to condense, and it is not that the bucket has overflowed, and the bucket does not have a leak. It had been working great and then this suddenly started happening, it's as if the water is not flowing along the proper route and instead is gathering behind the bucket.
Nov 27, 2012 | Kenmore 54351 Dehumidifier
Coils freezing up..is this normal? Not sure how this is supposed to work. Could it be that it freezes the water, then turns off and empties into the pan?
The coils should not freeze up. If the fan is working, try lowering the setpoint to just below actual humidity. This will allow the dehumidifier to run and shut so water can drip off without freezing. If that works, slowly lower the setpoint over the next day or so. If the setpoint is too low, the unit runs continuously until it freezes, then never shuts down.
Gary
Aug 30, 2011 | Kenmore Dehumidifiers
My DDR7009REE HAS WORKED GREAT FOR A MONTH. BUT NOW IT LEAKES ON THE BASEMENT FLOOR. I SHUT IT OFF FOR 2 DAYS THINKING IT MAY HAVE FROZE UP. TURNED IT BACK ON AND IT LEAKS ON THE BASEMENT FLOOR INTEAD OF...
dehums remove humidity from air inside unit the evaporator sits in drain pan , drain pan has some sort of line or tube witch leeds to the internal collection or bucket thats what you slide out and empty when its full , ther is some sort of sensor or float switch that lets you know wen full make sure unit is draining properly inernaly and full system is working properly
Jul 03, 2011 | Danby DDR7009REE Dehumidifier
It ran for a couple days, went to empty the bucket and maybe a inch of water was in it. normally i'm empting it everyday. when i took the bucket out i noticed a little ice under the machine.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 07, 2011 | Fedders A7DH45B2A Dehumidifier
I have one of your dehumidifiers and it turns on but we do not get any water out of it I have had for a few years but it was only used one year and it worked great when we went to use it again we got no...
If you haven't clean the air intake filter since you've had it. More than likely that's the problem. A dirty filter makes the dehumidifier strain to take in the moist air and it just can't keep up.
If you don't have your Owners Manual to guide you through the process. You can download one online, from Sears Parts Central.
Hope this helped you to solve the problem.
Apr 27, 2011 | Kenmore 54501 Dehumidifier
I purchased a 45 pint/day dehumidifier model # DD45P last year and it worked great. We needed to empty it almost every day as it was located in our lower level at a lake home. We have just returned to our...
heatman101
Apr 11, 2011 | DeLonghi Dehumidifiers
My amcor dehumidifier tc120 has started clicking recently and now its out put is poor the unit is used in a cellar just to keep control of humidity it works 24/7 then has few days off when full untill i...
heatman101
Jan 17, 2011 | Amcor DC930 Dehumidifier
DDR583R Danby Dehumidifier
Use a piece of ethernet cable and carefully push it through the water discharge area's...This should free up the grime that's clogging the drainage holes.
Jun 02, 2008 | Danby DDR583R Dehumidifier
Dehumidifier does not collect water.
My unit does not collect water any more. It was fine until I lent it to my brother in law and it was returned damaged. Do you know how to fix this
Dec 06, 2006 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
202 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
