Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
The tub is leaking in the botto center - Maytag LSE7806A Top Load Stacked Washer/Dryer
Had the same problem...the washers that hold the water in need to be replaced...only $20 for parts, but labor is $700 to take entire thing apart and is not covered after 1 year [I've had 9 yrs]; I opted to trash / replace entire stack unit; buy new amana washer & dryers @ home depot b4 7/29/09 / big sale!
Posted on Jul 25, 2009
The washer is leaking from the bottom
Your center seal is going bad or you have a bad hose, leaking water pump, or a cracked tub but GE is notorious for there center tub seals to going bad I would recommend a qualified service technician come look at it to rule out which one it is if your centers tub seal is bad I would buy a new washer but sorry for the troubles.
Jan 22, 2011 | GE WBSE2090A Top Load Washer
Leaking from underneath the machine
If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Dec 31, 2010 | Hotpoint VBSR3100D Top Load Washer
Dish washer is not draining
Check to see if the strainer at the botto of the tub if covered/clogged.
Does your sink drain OK?, most washers are hooked up to the same drain line
Nov 10, 2010 | Dishwashers
Water is leaking from the under side of my washing machine what could be the problem?
Check all hose connections, fill tub check for leak while full, then drain and check pump while draining. Also while tub is full use a flashlight and look where trans goes into tub if you see a leak in the center then it is your center seal.
Oct 03, 2010 | Hotpoint GE VWSR4150DWW WASHER
Leaking from bottom middle and right side of door
The center spray arm may not be turning straight and level, causing water to spray over the top of the splash shield. The shield needs to be adjusted to block water as it is sprayed from the center arm.
1. Remove the bottom door seal and reinstall, making sure there is not less than 3/8 inch of seal showing below bottom of internal door panel before closing the door.
2. Check tub seal, at the bottom the tub, seal makes a right angle and points to front of tub. In tub bottom there is a block molded in the tub, the tub seal is to fill this block but not extend over.
3. Select the shortest wash cycle or just use a rinse and hold cycle if available. Run the cycle, making sure the water spray changes from bottom to center not less than twice before making any adjustments.
4. If splash over is found, work only one side at a time. Remove black door seal enough to raise the splash shield up off the bottom of the tub not more than 1/8 inch and reinstall door seal properly. Retry and check for leaks.
5. If leak persists, remove door seal again. This time raise shield an additional 1/16 of an inch, then reinstall tub seal. After the first adjustment of 1/8 inch, any other adjustments will be no more than 1/16 inch at a time.
6. After splash over is stopped on one side go to the opposite side if needed.
May 11, 2010 | Frigidaire PLD2855RFC Dishwasher
Its leaking water while the washer is washing
Hi
If your washer leaks every time you run it, then check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make.
Please rate the solution if you find it useful and helpful.
Thanks
Rylee
Oct 16, 2009 | Whirlpool Washing Machines
Leaking below washer
Sounds like you have a leak from the tub. Either the seal in the bottom of the tub or a hole in the tub.
When you run it again try feeling around the bottom center of the tub for water or try to see if water is leaking any where out of tub. Clear water would be from the supply line , soapy water would be from tub or a hose coming out of tub.
Jun 09, 2009 | Washing Machines
Leak underneath tub
check for a broken seal at center of tub , if so , write down the brand & model and go to an APPLIANCE PARTS SHOP, and get a new RUBBER SEAL KIT, hope this helps , AJ
May 20, 2009 | Washing Machines
Tub leaking from center of tub under the aggitater
This type of leak indicates a failed tub seal and bearing. Replacing is time consuming, can be difficult and requires special tools to disassemble.
Jun 15, 2008 | Maytag Washing Machines
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
113 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
