Question about Tamiya America Tamiya 1/10 Rc Hp Off Road Racer Rising Storm Kit
My tamiya fs-18fd leaks gas through the exhaust, therefore burning fuel quickly. How to solve this problem?
  • 308 Answers
You need to lean out the mixture, you are running way to rich.
Posted on Jul 21, 2009
What does fuel control sensor is out of calibration mean?
have a read
' Repair Guides ' Diagnostic Trouble Codes ' 3.3l V6 Vin A Std 1 ...
https://www.autozone.com/repairguides/Nissan...05/.../_/P-0996b43f80376bd1
Trouble Code: P0171. Fuel Trim Lean (Bank 1). Possible Causes: Air leaks after the MAF sensor, or in the EGR or PCV system. Base engine "mechanical" fault affecting one or more cylinders. Exhaust leaks before or near where the front HO2S is mounted. Fuel control sensor is out of calibration (i.e., ECT, IAT or MAP).
' Repair Guides ' Diagnostic Trouble Codes ' 2.7l L4 - Std 2 ' AutoZone ...
https://www.autozone.com/repairguides/Toyota...06/.../_/P-0996b43f80378cd5 Base engine "mechanical" fault affecting one or more cylinders. EVAP system component has failed or canister fuel saturated. Exhaust leaks located in front of the A/FS or HO2S location. Fuel control sensor is out of calibration (i.e., ECT, IAT or MAF). Fuel delivery system supplying too much fuel during cruise or idle periods ...
' Repair Guides ' Diagnostic Trouble Codes ' 3.0l V6 Vin H Std 1 ...
https://www.autozone.com/repairguides/Mitsubishi.../_/P-0996b43f80379593 Fuel Trim Fault (Bank 1). Possible Causes: Air leaks after the MAF sensor, or in the EGR or PCV system. Base engine "mechanical" fault affecting one or more cylinders. Exhaust leaks located in front of the A/FS or HO2S location. Fuel control sensor is out of calibration (i.e., ECT, IAT or MAP). Fuel delivery system supplying ...
' Repair Guides ' Diagnostic Trouble Codes ' 2.7l L4 - Auto 2 ...
https://www.autozone.com/repairguides/Toyota...06/.../_/P-0996b43f80378cbc Base engine "mechanical" fault affecting one or more cylinders. EVAP system component has failed or canister fuel saturated. Exhaust leaks located in front of the A/FS or HO2S location. Fuel control sensor is out of calibration (i.e., ECT, IAT or MAF). Fuel delivery system supplying too much fuel during cruise or idle periods ...
Auto-calibration method for a wide range exhaust gas oxygen sensor
https://www.google.com/patents/US6227033
An improved fuel control in which the transfer function of a wide-range exhaust gas oxygen sensor is automatically and periodically learned or re-learned in the course of vehicle operation. The oxygen sensor is calibrated at two different operating conditions: at a stoichiometric air/fuel ratio, and at a fuel cut-off or free-air ratio ...
Mar 06, 2018 | Cars & Trucks
I have a 2005 ford sport trac I have gas leaking from my exhaust flange and a lot of white smoke what is wrong with
You have either a cylinder misfire, not allowing the fuel to burn therefore its coming out of the exhaust, or you have a leaking injector letting too much fuel into the cylinder to burn and fouling out your spark plug. \
Are you sure its fuel?
Feb 17, 2017 | Ford Cars & Trucks
Why do I smell gas and it's leaking from the exhaust pipe?
If you have raw fuel coming out of the exhaust pipe , you have real issues. There are a couple reasons this can happen.
1. You have a dead cylinder and the fuel is not being burned and is exhausted thru the tailpipe. This is unusual since most of the time if this occurs during operation the catalytic converter is hot enough to burn off the excess fuel.
2. You have a frozen injector and it is leaking into the cylinder after shutdown. Hard to believe this though, as you'd need a good bit of fuel to fill a cylinder to where it could flow out through an open exhaust valve. Usually the fuel would wash down past the piston rings first into the oil pan.
Feb 14, 2016 | 2000 Oldsmobile Alero
Smel of fuel throgh the exhaust
Gas Smell from Exhaust Sometimes you may find that the exhaust smells like gas. This is normally a problem with the air and fuel mixture as your fuel injector may be sending too much gas through the engine and not all is burning. This can easily be fixed by having your engine properly tuned. You also may not be using the correct brand of gasoline. Therefore the engine and exhaust are not working properly which results in gas like odors emerging. You may also find that the fuel injector is clogged and needs cleaning. Another cause of this gas smell is a stuck choke if you have a carburetor.
Dec 09, 2013 | 1980 Peugeot 305
Strong gas smell inside of car
is there a leak in your fuel line, or possibly your fuel filter, if you see raw gas leaking, then it is dangerous for you tio continue to drive it, it only takes one spark to ignite it, however, if the smell is just your car burning rich and the exhaust has holes in it, it will smell up the inside of your car. And yes if your carb. is burning too rich then it needs adjusted. Wasting your fuel, and overloading your engine. I hope some of this was helpfull.
Sep 21, 2012 | 1983 Chevrolet Malibu
95 Mazda b2300
Sounds like there is unburnt fuel. Could be a spark plug that's burnt out and therefore just flooding a cylinder. Which would push out fuel through the exhaust valve on the exhaust stroke. So once the fuel hits the inside of the exhaust manifold, it burns white, as if you're boiling it off. That one cylinder could have a damaged compression ring on the piston, so the fuel is bypassing it and going into the oil.
I would have your engine tuned up, and check the compressions on the cylinders.
May 27, 2012 | Mazda Cars & Trucks
Poor gas mileage
Do you have a gas smell in vehicle if you do there check and make sure that you are NOT loosing gas by a leak in the fuel line that was replaced or anyother part of the fuel sytem for that fact. If there is NO leak then the pressure from the pump may be too high and therefore dumping too mucj fuel into chambers but if this is true the vehicle may have a hesitation on take off or may run a little roughand a rich burning smell from exhaust, Check these things out make sure that the fuel pressure at the injector rail is correct refer to your repair manal for exact specs,because I NOT sure what it its, good luck and thanks for using FIX YA
Mar 21, 2009 | 1999 Buick Century
Exhaust
The most likely cause is that the motor is running very lean. Make sure that all of the componets for the air intake system are connected and not leaking. This can happen if you have changed to one of the new high flow air cleaners like K&N. This causes the air/fuel mixture to have too much air and not enough fuel (lean). If you can adjust the carb then make it richer.,
Nov 10, 2008 | 2003 Husaberg FS 650e
Tamiya America Tamiya 1/10 Rc Hp Off Road Racer Rising Storm Kit Logo
413 people viewed this question
Top Tamiya America Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Tamiya America Toy Expert? Answer questions, earn points and help others
