As your diagnostic flow chart will tell you now you need to test the coolant sensor(3 wires sensor in water jacket screwed into steal pipe near intake manifold) Most likely out of range.If the first part of your pinpoint test had failed then there might be a possibility of and open inside the pcm but since it passed the first test then I don't think they are a related concern.
Over heating can be caused by a faulty thermostat and or weak water pump and dirty radiator and old antifreeze or the radiator fan now working when at idle but should not over heat when driving. Service the cooling system if it has never been serviced before. Replace the thermostat, buy some radiator flush to clean out the radiator and heater core. Just follow the instruction and replace the antifreeze and make sure it's a 50/50 mix water/antifreeze. If you not sure how to mix it 50/50 you can buy them 50/50 premixed. Water boils at 100'C so you need antifreeze mixed with it but antifreeze does not have the same heat transfer as water so you cannot run 100% antifreeze cause it does not transfer heat fast enough and you over heat. Good luck and hope this helps. Keep me posted, Be glad to help, once you service the cooling system and your still over heating, then we look at the water pump.
