Question about Toshiba CF27F30 TV
I have the same TV and it gets sound OK and changes channels but there is only a white horizontal line on the screen.
  • 975 Answers
Thats the VERTICAL IC or TRANS OUTPUT , needs to be replaced , thanks AJ
Posted on Jul 14, 2009
Black screen horizontal white line moving from top to bottom of screen
Hi Mandy
Think you have a problem with the cabel or if you could adjust the channel for the correct signal. Maybe the tv-chip on the consol are broken, and you live to far from me for me to help :)
you have any friend who could take a look ?
Best regards
Joakim
Feb 26, 2013 | Atari 2600 Console
White horizontal dashed lines appear and at top of tv screen
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Mar 13, 2017 | Apex Digital GB43HD09 43" Rear Projection...
Insert game disk and horizontal lines move fast on screen ???????
Sounds like your TV has multiple video inputs. Make sure the TV is set to the right channel or input. I know on ours if I hit the TV-input button on the tv remote I can change from inputs like s-video, video, cable etc and the Wii only displays properly on one of them.
Mar 28, 2009 | Nintendo Wii Console
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
It sounds to me like you're describing the re-trace of the unit. It is repairable, and more so the sooner you get it to the repair facility.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-27FS120 27" TV
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
TV picture
The set you have has a bad tuner assembly. At this point most likely you would be better off getting a new TV set. Good Luck
Mar 30, 2007 | Mitsubishi CS-27309 27" TV
TV has bright horizontal line
do some voltage checking on the ic and make sure that volages are reaching there, about 32 volts. if it is reaching, then you can change the ic there. but before you do that, check around that ic and make sure everything is ok there. good luck
Aug 15, 2006 | JVC AV-35750 35" TV
Open Questions:
Televison & Video Logo
55 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
