Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Need manual for poulan chainsaw 2300 cva 2.3 cu in
  • 76 Answers
Hi
I could not find manual for your model , looks like it an old one .
However I found parts list .
http://72.3.225.179/manuals/64828.pdf
hope it helps
Posted on Jul 20, 2009
Chainsaw won't idle- runs fast only
Gently Tighten the carb adjustment screw fully tight then adjust it out 360 (full turn) then again a further 180 ( half a turn) and your idle speed should be set correctly. Let me know how you get on
Oct 02, 2014 | Oregon Poulan/Poulan Pro 10" Chain Saw...
Service manual poulan 4018wt
Owners Manuals
Add your model number and download the manual.
Jun 06, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chain oiler for poulan 2300 seems to dump all the oil out at once within minutes of usage
there is a seal between the pump and the case if that seal fell or wore out it will drain out of there
Aug 16, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I need to get the muffler off off my Poulan 42cc chainsaw. Is there a stepped procedure for this?
The honest answer is no. You can purchase a repair manual similar to a Chilton's or Motor repair manual but they offer little help. What most use including chainsaw mechanics is the parts list. An IPL for your saw if a PP4218 can be found here:
Poulan.com/CurrentModels
http://www.poulanpro.com/node4043.aspx
Type just the model numbers (choose the suffix after the list is provided).
My interpretation of your saw remove 1 nut, 2 bolts and perhaps the engine cover.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 19, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 2300 Firewood chain doesn't oil
She is long of tooth. Some oiler parts are NLA. Item 17 on the "Power Unit" print is the actual oil pump. Do not mistreat it; do not blow it out with air; they are no longer available.
http://www.ordertree.com/modelinfo/PWE/2300AV-Gas-Saw/75.2300AV-Gas-Saw.1.59.1.html
Please see this thread, post 5
http://www.arboristsite.com/showthread.php?t=120981&highlight=poulan+xxv+oiler
The *.pdf is your oiler. I suggest you read the entire thread. and save the *.pdf to your hard drive. HTH
Lou
Feb 10, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Need to know gas oil ratio on poulan micro xxv deluxe
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Oct 08, 2009 | Poulan Garden
Spark plug location for Poulan 2300
Most likely to be found under the removable casing at the top of the chainsaw. The spark plug will have a black rubber spark plug boot which will identify its location. Remove the spark plug wire/boot to access the spark plug. The boot should just pull off. The spark plug will need the correct size socket to remove it.
Jun 14, 2009 | Poulan Garden
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
1,674 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
