Question about Moen Home
Diverter valve does turn to redirect the water. the valve stem does not come out . How do I remove it?
    President:
  • 1,273 Answers
Hello. W/D here....
I'll have to be general in this info as I don't know your specific valve, but I have worked on many diverter valves.
Either the packing gland on your valve is too tight, or you have a damaged diverter valve.
1. Make sure water won't come out in the tub or shower when your water is turned off; that is, that your water valves don't leak. If they do, you'll have to shut off the water.
2. Gain access to the valve body/diverter valve: Remove the plastic cap on the knob, remove the screw then remove the knob. The metal tube will unscrew from the valve body.
3. It gets a bit tricky here, so bear with me... Looking down the valve stem, there are two nuts surrounding the valve stem. The one closest to you is the packing gland nut. The inner one is the valve cartridge nut. The tricky part is that the nuts are difficult to get at. Turning (loosening) on the outer nut will make the valve easier to operate, and more likely to leak. A general rule for packing glands is that they should be just tight enough not to leak, plus 1/4 turn.
You can buy a set of thin wall sockets at Lowe's or similar, and they are handy. But....you may be able to slip a deep well socket onto the nut and turn it. This will save you ~$15, if it works... Unless you are familiar with adjusting packing glands, it will be easier to just replace the entire valve. Get a socket that will fit the valve body. Place the socket on the valve; the stem will have to pass through the square socket drive hole. You will have to use a pair of channel locks or pipe wrench (or similar) on the socket to remove the valve cartridge. When you have the valve out, look inside the valve with a flashlight and you'll see the valve seat. It will have a square or hexagonal hole in it. Check with your finger for nicks. If it is damaged, remove it. The valve seat wrench is available at a hardware store reasonably, ~$10. Pull the valve out and take it with you to the hardware store. Reinstallation is the reverse of the removal with two exceptions: make sure that the valve stem is "open", and make sure that the packing gland is snug, but not too tight. The easiest way to adjust it is to put the handle on the valve and to operate the valve in your hand. Tighten the gland to snug and operate the valve. Make adjustments in this manner until the valve is still easy to operate, but is getting harder to operate as you tighten it...you'll get the feel for it. Once you're satisfied for the most part, install the valve. Usually there is a plastic gasket or "O" ring that will need to go on the threads. Install according to the instructions included. Once the valve cartridge is installed, operate the valve a few times. Complete the reassembly.
Regards, --W/D--
Posted on Jul 14, 2009
Replaced a gerber diverted stem. Water pours out of it. I also replaced the stem valves for the hit and cold.
There should have been a friction ring made of either nylon or fiber that goes on the threads of the stem that screws into the faucet. If this ring is missing, the stem doesn't seal properly. Remove the stem and check for ring. Also, when you screw in the stems, you should always screw the stem into the full open position, or it will not thread in all the way.
Apr 10, 2017 | Plumbing
How do I remove the water flow dircetion lever
This is called the diverter if it is a tub/shower valve. There are just too many brands to say just how it comes out. Remove the handle. You may need a handle puller. Remove the trim. This varies. If I had a picture, I could tell you how to do this. You will then probably need a deep plumber's socket to remove the stem. Make the stem is turned all the way counter clockwise before unscrewing the stem. Go to a good old time plumber shop or hardware store to get a new stem.
Dec 30, 2013 | Plumbing
When I turn on the tub faucet, water comes out of the spout and shower head. It's a t215.710 model
Does it have a diverter on the spout? If so, replace the spout with the same type. If it is a new installation, did you make up the valve or was it complete and designed for tub & shower? If it's an old valve and it has a separate diverter stem, there is a spacer behind the valve between the valve housing. Replace it.
Apr 21, 2011 | American Standard Plumbing
Middle valves not sending the water to shower head
the diverter screw has come loose in the diverter stem. It is the center knob that turns on
the shower. If it is american standard, they were noted for this. You may want to shut off
water to the shower itself at the shutoffs but USUALLY not necessary as long as you dont
bump the hot/cold knobs while removing the diverter stem.
Remove the cover and or screw from the handle and remove it.
then remove the decorative escutcheon cover and tube by unscrewing
it counterclockwise.
(There may be a small set screw on the underside of the cover to loosen)
The stem unscrews counter clockwise as well and may take a small pipe wrench to loosen
Sometimes the screw becomes lodged in behind the seat and requires patience and a
pick to extract it (a short burst of water may eject it into the tub). Sometimes part of
the stem body becomes lodged in the manifold but can be removed with an internal pipe
wrench set (home depot carries them for about 12 dollars).
Feb 27, 2011 | Plumbing
Delta shower faucet loses pressure when turned all the way on (hot water). What could cause this? When it first happened yesterday, a few tiny pieces of black plastic/rubber fell out of the bathtub...
Turn off the water to the home. You need tthe stem beneath the handle. Remove the handle after locating the set screw, remove the cylindrical beauty cover, and unthread the retaining nut to access the valve stem. Take it to a plumbing supply house or home store to make certain of the match.
Oct 06, 2010 | Delta & Single Handle Shower Faucet
I changed the stem on hot water because shower leaking- now no hot water from shower head when water turned back on- wont pass stem and some spreay from where stem is?
I am not sure what brand of shower valve you have but it sounds like you lost a peice of rubber or plastic in the valve and it has either lodged in the diverter or somwhere from the valve to the shower head. Is it posible that you got the wrong stem or switched stems or maybe it was put in backwards. Wish i could narrow it down for you,Need better info.
Dec 02, 2009 | Moen 87530 Touch Control Single Handle...
I have a older Delta shower head/tub combination with scald protection. It leaks from the tub diverter. Where should I start?
I'm assuming that you have a three handle faucet. You need to remove the diverter from the faucet body and while your at it remove the hot and cold stems from the valve body (the parts are inexpensive). Remove the seats inside of the valve body towards the back, replace with new ones. If stems are in good shape, just the washers and seats need to be replaces. If the brass on the diverter or on the hot or cold stems is pitted or marred, then replace the whole thing. The parts should be readily available at most plumbing supply places.
Nov 27, 2009 | Bath Unlimited DELTA INNOVATIONS TOWEL...
Tub shower diverter stem on tub spout broke and need to have instructions for how to replace the ROD Diverter seal o ring in the spout.
you must replace the whole stem.you can get it at homedepot. first take the cover off over the stem. this should screw off or is held on with a allen key.then unscrew stem from valve body.make sure water is off to tub,just in case.
Jun 27, 2009 | Price Pfister Ashfield Single Control...
Shower spout
There is a threaded stem that passes through the spout and attaches to the white plastic diveter valve. If you are starting from scratch (everything apart), you can put it back together in this order:
1) Place the white plastic diverter inside the spout. the circular side with the black round washer should face the the wall side of the shower (mating up against the threads for the water pipe).
2) The stem can now be inserted from the top and into the notched section of the white plastic diverter valve. The threaded end of the stem shoud be outside of the spout (from the top side).
3) A round black washer fits over the threads. It should sit right where the threads end. Dont push it all the way on to the unthreaded portion of the stem.
4) Screw the threaded knob onto the threads.
Should be ready to install now. Including the spout itself, there are 5 parts and are configured in this order from top to bottom.
1) Female threaded knob (the knob for operating the spout)
2) Threaded stem (threads on top)
3) Round black washer
4) Spout
5) Whit plastic diverter valve.
Mine leaks when I turn on the shower, thus reducing shower pressure. I looks like a poor design to me. The stem is not a tight fit in the spout and this allows the diverter to "wobble". The washer on the diverter valve does not seat tightly and allows water to leak out the tub spout when showering. I would replace the spout.
Jan 30, 2009 | Price Pfister 01-311 Shower Head, Tub...
Shower diverter problem
It is very possible that a piece of rubber from the old washer or some debris has found its way into the shower diverter or the showerhead. The first thing to try, is to take off the showerhead and see if you get water without it. If you get water then your problem is solved!!! Puchase a new showerhead or take apart the old one and soak it in CLR or Lime-Away to clean it. If that doesn't do the trick than, Turn off your water supply to hot and cold. Remove the diverter (if possible) and inspect for debris. If you want you can also take out the hot and cold stems for a total inspection of the inside of the faucet. You can then flush out the inside of the faucet cavity with a Turkey Baster or something to that effect. Put it all back together ( use a bit of vasaline on all the rubber washers so they do not get stressed when re-installing) and you should be able to take a shower.....Also, if it was a cartridge you replaced, you may have inserted it 180 degrees opposite......Hope this helps.....Joe
Jan 12, 2009 | Ace Hardware BRASSCRAFT 45458 "ACE"...
Home Logo
491 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
