Question about Frigidaire GLTR1670A Front Load Washer
Door Locked and wont open
  1. When my washer finished its cycle the door will not open and remains locked
Mine is crazy too! Sometimes, if I open the soap dispenser it will open, othertimes not. Sometimes, if I pull up on the big, round knob (that you use to turn on the cycle), because it gets stuck down. Once in awhile, I just put it on the last 2 minutes of spin cycle again.
Posted on Nov 18, 2007
Door remains locked after wash, no error code or anything.
if there is water left in the machine it will not open pull out the washer if under work top tilt the machine back wards the door should open thwn clean filter and try
Dec 02, 2012 | Washing Machines
The door is locked and wont open
If the machine didnt finish the cycle due to the pump being clogged the door will remained locked also if the lock mechanism went bad, the machine will stay locked. Remove the top of the machine by taking the screws from the top back out. Once removed look down the right hand side and you'll see the lock mechanism, usually with a plastic tab you pull to manually release the lock. On some machines it maybe be required and sometimes easier to remove the bottom kickplate and access the lock assembly from there
May 08, 2012 | Frigidaire ATF6000ES Front Load Washer
My Samsung VRT washer was working fine. The cycle appears to be finished but the door remains locked. I get no response from any of the buttons. You would think that the washer wasn't getting any...
I don't know if I have the same model SAMSUNG front loader, but I have a similar problem. The door has decided to stay locked at the end of the cycle. I can turn it off and on and even send it through another cycle, but at the end of the washing, it drains, goes to END but does not go the extra step of unlocking, like it usually would about 1min after ending the cycle.
My clothese have been through about 6 different cycles, hoping it will magically clikc open at the end. I assume they are very clean, but getting dizzy.
Any help out there?
Aug 12, 2011 | Samsung WF337AA Front Load Washer
The door wont open . I have tried to put it on for a cycle and you can here the the water for around 5 seconds then it stops and does nothing.
Check and make sure your pump or filter is not clogged, then next I would suspect you have a faulty door lock mechanism
More common issues with the door lock.
Is water hooked up to the washer?
The door will remained locked while draining water. If during installation the washer was plugged in and turned on without water hoses attached, the washer may attempt to drain for 8 minutes before the door unlocks. Let the washer run until the door unlocks. Do not turn off the washer or unplug the washer.
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Select Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle. For models that have Rinse/Drain & Spin, push the Extra Rinse button to turn off the rinse to remove excess water.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
Trying to gain access into a locked door can be a bit frustrating. Upon researching your question I found some links that may help you unlock your washer door. I attached all links below. I hope this helps!
http://www.managemylife.com/mmh/questions/204092-how-do-i-get-the-door-open-on-my-kenmore-washer
http://www.managemylife.com/mmh/questions/220303-does-front-loader-door-open http://www.managemylife.com/mmh/questions/134692-why-wont-the-door-open-on-my-kenmore-frontloading-washer
Jun 10, 2011 | Washing Machines
When washer starts it usually makes a clicking noise know it is humming and nothing happens the door is locked and wont open
your main belt is broken or loose i would suspect the latter,the reason the door will not open is the machine has started a wash cycle and because the belt is not able to finish the cycle the door wont open so the progam is not finished,switch the machine of at the mains and the door will open after 10 mins.But the problem remains the belt.please rate this answer thanks.adrian,,,,,,,,,
Aug 23, 2010 | General Electric WCVH6800J Front Load...
Door lock light is on door is not locked and
Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
Thank you !!
Jun 19, 2010 | Frigidaire GLTF1040A Front Load Washer
Cycle finished but door won't unlock, please help
normally, front loading machines have this bypass cables in case this things happens, if there is a small opening at the front to acces the drain filter, open it up then look for a small plastic pc with a ring at the end. this is the pull release cable of the door lock. pull it downwards and the door will be released.
if you do not have the small opening to access the drain filter, you can tilt the machine to its back, ( be carefull, its very heavy) then reach for the plastic ring underneath to pull to release the door lock.
tnx 4 using fixya..
drcool
Aug 30, 2008 | Hotpoint WMA40 Front Load Washer
Hotpoint aquarius washer door wont open
I've got the same problem, the locked symbol is showing
Feb 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Door jam!
Probably you need a new doorlock. I really dont have a good answer how to open the door with this problem.
Jan 24, 2008 | Electrolux EW1000i Front Load Washer
Frigidaire GLTR1670A Front Load Washer Logo
264 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
