I have a samsung LCD display panel. Model LAM3261B it is a HD panel with analogue tuner. The A/V works fine as does the HDMI but the tuner is not picking up any signal. it has 4.30 volts and 3 volts at test points
  • 2 more comments
  • craquer69 Jul 14, 2009
    i have tried the TV in different areas and sources.
    it just doesnt pick signal up
    im in australia we dont change til 2013
  • craquer69 Jul 15, 2009
    the tuner is part of the signal board which is very expensive to replace if i can find one with an analogue tuner.I have alignment meters , grid and dip etc , just dont know where the problem lies
    it IS the tuner
    President:
  • 2,187 Answers
If this is the first time this is being set up, On the setting of the Samsung, you have the option on the channel for the channel schemes. See if it conforms to your area. It identifies which frequency for each channel. Try the different settings. If this has worked before check the connections or ports and try a another TV if see if it works. If this is via cable, if there is a box between the TV and the cable wire, have it checked if another TV worked on it.
Posted on Jul 14, 2009
I have a Samsung LW32A33W and it worked fine using HDMI cable for connecting a PS3. Suddenly when I connect my PS3 with the TV using the same cable I get a blue screen and nothing happens. Any ideas?
That HDMI connection hub port it some how got short and it dead.Tries other HDMI connections hubs.If all are like that they are all dead.All HDMI hubs ports connections are link together.If one dies usually all HDMI hubs dies together.Than ur tv Tuner signal board will not have anymore HDMI hubs functions connections at all,none of the HDMI hubs will work again ever.Have happen to mine Samung tv,so now i have to stop using HDMI hubs all together.
Aug 12, 2011 | Samsung LW32A33W 32 in. HD-Ready LCD...
Sceptre x23BV-naga 23" LCD HDTV needs a digital tuner replacement
just get a hd standalone tuner and hook it up to one of the inputs. way cheaper solution.
Apr 09, 2010 | Televison & Video
Compatibility with Samsung LCD Display
It sounds like the HDMI port on the back of your Marantz is damaged. if you know for sure that the HDMI port works on another tv still you might just use component connection because the visible difference between component and HDMI is not very recognizable.
Jan 13, 2009 | Marantz DV4001 DVD Player
Crt 4:3 to a 16:9
If your CRT Monitor has a DVI input you can certainly get HDMI to DVI adaptors (Maplin etc) but if the monitor is Analogue as I suspect you will need to find a Digital to Analogue converter. The problem here is that HDMI is copy protected and any analogue outputs must be disabled when HDMI is selected to prevent coping. I am assuming this also applies to your PS3 !!!!
I do agree with you about picture quality. I have a Samsung 21" CRT monitor which has a pixel size of 0.2 and is far superior to even the best LCD.
Apr 24, 2008 | Televison & Video
Samsung LTP326w
After few years of service with different TV providers I have problem with my TV. Last night my Samsung LTP326W just did the same think on HDMI connector and no mater what you do it will not turn HDMI video... it's connected to Verizon/Motorola DVR I called Verizon and they promptly replace DVR and HDMI cable but it didn't help at all, also sometimes when you power on/off I get message: The HD Content Protection of your display has been compromised Please use the YPBPR outputs for your HD connection...
When I switch to component cable it works just fine.
Feb 09, 2008 | Samsung LTP326WX/XAA 32 in. HD-Ready LCD...
Plasma with green tint
Could be a main board.Tuner could be bad.
Dec 24, 2007 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Televison & Video Logo
112 people viewed this question
Top Televison & Video Experts
