Question about Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3100 frozen on blue screen tried power on and off and reset button still frozen black bar at bottom of scren stays on blue screen
    President:
  • 1,111 Answers
I just replied to a fellow with the same problem and since your problem is same, ill post what i wrote him/her but try a hard reset 1st..turn the gps on then locate the little pin hole on the side, using a paper clip, push reset....if that fails, try the 2.18 update if you havent already.
updates for any magellan can be found HERE
but read below first before getting the update
i cant stress enough that patients is a must here. this update is huge 1.75GB
follow the instructions below whether you have updated your gps already or not!
There are few ways to solve this problem. i assume you installed the 2.18 update for the 3100 and assuming you tried the reset already, try and run the update again and follow the directions to the letter..make sure the battery is fully charged (i also keep mine plugged in if the update doesnt say not to) and do not try and run the update across a network. this update is huge 1.75GB and can take an hour or so depending on the computer..do not interrupt the update process. if you do not have the 2.18 update read me file, i can try and post it here, but its in PDF and dont think i can post that
if all else fails, magellan will fix or replace for free any of there gps that were rendered inoperable due to one of there updates.
either solution will work but magellans going to tell you to run the update again anyway before sending it back.
i gave you the 2 easyest ways to fix it,but
there are other ways to get it running again, but if your not comfortable copying and moving files...youll make it even worst then it is.
hope this helps.
bill
Comments: Jul 19, 2009 - here are a few key points, but read the full update guide before trying the update again.
hope this helps
NOTE: This update is COMPATIBLE ONLY with Windows® XP.
Before Beginning:
Check to make sure you have everything required for updating your unit:
• Magellan Maestro 3100 GPS
• PC running Windows XP
• A Blank SD memory card (16 MB to 2GB)
• USB cable
• Paper clip or similar object (for resetting your unit)
EACH OF THE FOLLOWING POINTS IS CRITICAL TO THE UPDATE PROCESS
1) The battery of your Maestro 3100 must be fully charged before beginning the update.
NOTE: It takes between 3 and 4 hours to fully charge the battery with your vehicle power adapter. Check System Settings to ensure the battery is fully charged.
2) Your Address Book will be erased during the process. Please back up your data to an SD memory card.
a. Insert a blank SD memory card
b. Select User Options
c. Select Backup and Restore
d. Select Yes to confirm
3) Do not connect your Maestro 3100 to your PC until instructed to do so by the Update Wizard.
4) Close all other applications while performing the update.
5) Disconnect all Pocket PC devices from the USB ports on your PC.
6) Insert a blank SD card (16 MB to 2GB) into your Maestro 3100.
7) Perform a hard reset on your Maestro 3100 by pressing a paper clip or similar object into the hole marked reset.
Update Process:
1) Launch the Magellan_Maestro_3100_2_18.exe file.
2) Select Next on the Welcome screen.
3) Turn on your Magellan Maestro and connect the USB cable.
Posted on Jul 19, 2009
  • Tami Bacon
    Tami Bacon Nov 08, 2013
    my question was in reference to a Digital2 android tablet being frozen with the device name only showing on a blank screen. need to know how to reset tablet.
I dropped my magellan "maestro 3100", now it will
hi elizalde_cl
start your 3100, then get a paper clip and depress the reset on the left side near the bottom of your 3100 to reset it and let it restart. that should fix it, but if it doesnt, let me know and ill tell you what to do next.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Dec 02, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
Blue Screen with a black progress bar
i asked yesterday what for error message were you getting, but you havent replied so maybe you missed it. the dos box you are refering to is part of the update process for the 3100. run the update again and be patient, this update is huge and takes about 30-45 minutes to complete.do not remove usb cable untill directed to do so then the unit will reboot numerous times to install the update. do not attempt to touch the gps until you see the screen with the time zone. if that fail hopefully you copied the files before you tried to update it. if the update fails again, let me know and ill show you how to restore your 3100
Aug 17, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan 3100 frozen on blue screen with black progress bar
where are you getting that error message, on the pc or the 3100
Aug 05, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Start Up acreen frozen after completed the bar.
if you haven't updated it yet, try the update..it can be found here
Jun 24, 2009 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 3100 only get logo and black bar
did you hit the reset button in that little hole on the left side of the unit?...press it with a bent straight paper clip wire and it should reset properly
Mar 24, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Touch Screen
You probably just need to reset it.
Magellan Maestro models- the location of reset button is on the left, right, or bottom side inside a small hole. Use an object to apply pressure to depress the reset button. Also try holding the power button down for up to 10 seconds to power the unit off and again holding the power button down for up to 10 seconds to power the unit on.
You may need to update your firmware. Go to this site
http://www.magellangps.com/support/
select your product family, model, and then press the submit button. Firmware updates are located in the updates/upgrade section.
This should solve the problem. Good luck. If this helps, plz rate it fixa. Thank you kindly.
Feb 07, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
My magellan maestro 3100 won't stay powered on
If the battery is fully charged then press the RESET button.
Jan 20, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan Maestro 4250
There is a RESET button on the bottom of the unit on the left side
Nov 22, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan 3225 - frozen on start up page
contact magellan corp custmomer service or repair tech,they can help call them first
Oct 12, 2008 | Magellan Maestro 3225 Car GPS Receiver
Magellan Maestro 3100 locks
You can try a hard reset. Hold in the reset button (left side of unit, use a pin or toothpick), while turning on the unit. If you don't get the blue Magellan screen, you'll have to try again. If you get a screen with a blue background and a menu, turn it off and try again.
So far, this has fixed:
1. unit won't go on
2. unit reboots when routing
3. unit turns off after a few seconds
At least, it's fixed it for me. No idea why this happens, but it's pretty damn annoying. Give it a try.
Dec 26, 2007 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan MAESTRO 3100 98083401 GPS Device Logo
1,067 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
