How to change the belt for a whirlpool washing machine
    President:
  • 1,136 Answers
Hi, Whirlpool washers have a coupler instead of a belt. If you are sure yours has a belt, please send me a model # so I can look this up.
If you tip the washer against the wall and look at the motor from underneath, The pump is attached to the motor right behind the front panel and then the motor attatched to the transmission with the coupler that is 2 white plastic pieces and a black piece.
Here are the instructions on changing the coupler:
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can set it aside.
How to replace a coupler:
Now that the cabinet is out of the way, remove the pump from the motor and set the pump off to the side. Remove the two screws holding the clips on the motor and remove the clips. Unplug the motor harness and on some models you wil need to unplug the capacitor.
Now you will need to replace all three parts to the coupler. I use a ½” socket and a small hammer to force the coupler onto the motor and transmission shafts. Put the rubber part onto the coupler half on the transmission and then line up the post on the motor shaft with the holes on the rubber part and it should go on ok. Put the clips that hold the motor in place and plug in the harnesses.
Put the pump back on and the clips to hold it in place. Set the cabinet back on the frame. Make sure the lip on the front cabinet is under the front rail of the frame. Ease the cabinet on the frame making sure the two rear sides of the cabinet set down on the tabs of the frame.
Put the two clips back on that hold the cabinet and plug the lid switch back in. Fasten the control panel down and you are all set.
please let me know if I can assist you further.
Thanks
Vic
Posted on Jul 14, 2009
4 Suggested Answers
  • 219 Answers
SOURCE: whirlpool washing machine won't spin
its probably your motor coupling u have to take pump and motor off to get to it
Posted on Apr 17, 2009
  • 119 Answers
SOURCE: how do I change the drive belt on a top loader
WITH THAT MODEL NUMBER, IT'S A FRONT LOADER YOU MEAN. THERE'S A PANEL IN THE BACK TO ACCESS THE BELT
Posted on Jan 24, 2010
jumptrout51
  • 3361 Answers
SOURCE: changing a belt on a washing machine
There is no belt on this machine.
It uses a direct drive coupling between the motor and transmission.
Ope the control console,then remove the cabinet clips to remove the cabinet for access to the motor.
Remove the motor then remove the broken drive coupling(3 parts).
Replace the part and re-assemble the washer.
Posted on Jul 25, 2010
My whirlpool large wasjer seemed the belt was squeeking .... then it stopped spinning.. Is it worth is to get a new belt repaired or buy a newer one.
Of course it worth to change the belt, is more cheap then a new washing maschine.
After 7 years of usage my Samsung washing machine was doing same problem. I change the belt with a new one about 3 years ago, and it's working fine.
All the best !
Nov 06, 2017 | Whirlpool Washing Machines
How to change a belt on a whirlpool ultamite care plus washing machine
Rear access panel off belt right in front of you. turn drum and pull old belt towards you fit new one by putting over motor spindle first, then feeding onto drum spider as you rotate it. Tension by moving motor on it's bolts (out for tighter, in for slacker) About 1/2" movement in centre of slackest part of belt.
May 19, 2012 | Whirlpool Washing Machines
How to change belt on whirlpool ultimate care plus washing machine
Top loader? Turn machine up so you can see underneath, remove access panel, belt right in front of you. Fits over motor spindle and base of agitator spider
May 19, 2012 | GE WBSR3140DW Top Load Washer
How to replace belt on Whirlpool AWO/R4205
Please find tips from the link below on how to replace belt.
click on Washing machine belt replacement
Nov 11, 2011 | Washing Machines
Not spining
Check belt. Will need to till machine on side. Easy to change. Should be able to go to a bearing and power transmission store and find a belt. Look under local yellow paged for v belts.
May 14, 2011 | Whirlpool Washing Machines
How do I replace the belt in my Whirlpool Cabrio Washing Machine?
There is no belt on the whirlpool Cabrio washing machine. What kind of problem are you experiencing?
Dec 21, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Wool sweater got washed and washer stopped before "spin" - has 6" of water still in it - and will now not work. Is it just clogged? You can hear the hum of the motor but nothing happens.
More than likely you broke a belt or a drive coupling. If it is a Frigidaire, Roper, most Maytags, etc it is a belt. If it is a Kenmore, Whirlpool, or a few others made by Whirlpool, it is a drive coupling. Directions for belt change varies. Directions for changing a drive coupling can be found in the one tip I wrote. Search my tips and you'll find detailed instructions for changing it on a Whirlpool or Kenmore. Good luck.
Feb 27, 2010 | Washing Machines
How do I change the drive belt on a top loader whirlpool washing machine
Jan 24, 2010 | Whirlpool GHW9300 Duet Washer
Whirlpool Thin Twin
this unit is a direct drive washer is does not have a belt.
Jan 18, 2008 | Whirlpool LTE5243D Top Load Stacked...
Washing Machines Logo
245 people viewed this question
Top Washing Machines Experts
