It does not turn on. It is conected, but nothing happens. I checked the power line, and it is ok.
  • 975 Answers
NEED TO CHECK the POWER SUPPLY for a possible BLOWN FUSE , AJ
Posted on Jul 14, 2009
Electrolux dryer edi97170w died while working over night power ok but nothing happens on display
You might want to post this in the washer/dryer section. This is currently listed in the vacuum section
Jan 26, 2014 | Electrolux Dryers
I have a Volkswagen jetta 95 automatic it won't turn over and I can't get it out of park, there's power to the car but nothing happens when I turn the key , any ideas what it could be
first check the in-line fuse on hot line going from battery to starter if it checks out ok and the battery is full charged then it is the starter
Aug 01, 2011 | 1995 Volkswagen Jetta
Turned key and nothing happened.. No lights, power, no click - nothing. Was just driving it and shut it off for short time. Took some fuses out and put back in. Turned key and car started. Shut it off...
sounds like a lose or bad conection on battery or bad conection to earth check leads from battery to chassy check leads from battery to fuses for any loose or bad conections
Jul 28, 2011 | 1995 Chevrolet Cavalier
AC/heater not turning on, no defrost, nothing happening???? i have already checked the fuses
check for power at motor if power there motor conection bad or motor burnt out
replace motor
Apr 12, 2011 | 2000 Volkswagen Beetle
When you turn key nothing happens,lights,horn,radio works
check the battery conections for tightness then check continuaty to starter motor.. if power is getting to starter , could be starter. however if any of the dash lights go dim when turning key , suspect the battery.
Feb 02, 2011 | 1993 Jeep Grand Cherokee
I have a compac lap top and when i plug in the wall charger nothing happens it wont charge
check to see if you can hear a hum from the charger it self , push the box hard againts ear if its humbing charger is ok, if you cant hear anything from it check fuse to plug. if this is ok then charger is broken.
If charger is ok check the conection into the laptop if it feels loose and when u move it slightly it goes on and off then possible conection to laptop prob.
If this conection is ok and the charger is humbing and working, could be a possible internal switch gone in the laptop that decides to charge and not charge when battery is full. These are always failling on laptops but hopfully its not this.
If you find the charger is broken search ebay for a new or secound hand one, aint to expensive. hope this helps
Nov 28, 2009 | Compaq Computers & Internet
Each time i try to turn on my Toshiba Satellite L305 ( laptop), the on light goes on, but nothing else happen's, the hard drive light does not flicker and the screen stays black. The airport light usually...
Removed the power conection and remove the battery as well and press and hold the power button for 5 to 7 sec and then connect the battery and power cable and try to turn on
Regards
Samson Ved
Dec 05, 2008 | Computers & Internet
Ruud central air conditioning and heat system
there is a fan relay in the unit. it is stuck and needs to be replaced
Oct 21, 2008 | Ruud Heating & Cooling
Green screen with almost horizontal zigzag lines
Is good that you hit it and it reacts,very likely you have loose conections in different places but for the distorted picture you need to check the horizontal driver transformer and flyback after that is corrected you need to check the complete chassis for loose conections.Take your time.Good luck.
Sep 07, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Computers & Internet Logo
351 people viewed this question
David Payne
David Payne
