Question about HP (D7580-60003) Motherboard
Laptop Wireless Not Working
My wireless connection started to be inconsistant, then it stopped so I replaced the Wireless Card, it didn't fix the problem. Then I purchased a wireless adaptor and is worked intermittiany for a few days then is quit completely.
The Network Utilty reconizes that there is a adaptor and the light comes on but it won't allow me to enable it.
I've talked to the adaptor people, they said there is a problem with the mother board. It's a two year old HP Pavilion with VIsta.
  • 3 Answers
Make sure you have correct Vista Drivers
Posted on Jul 14, 2009
Dell Latitude D 410 has suddenly (worked yesterday) stopped connecting to all known (and working) wireless networks. Is my internal wireless card gone?
If you get a 'Limited connectivity" on you wirelessconnection on your laptop, it means that the wireless card on your laptopprobably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and thenclick Repair.
This will force the wireless router to issue a IP address to the wireless cardon the laptop.
Apr 13, 2012 | Dell Latitude D410 Notebook
Laptop states wireless adapter not installed and configured? worked before.
To check if the wireless card is bad or OK.
Go to Control Panel - Network Connections - Is the wireless network connection listed and if so is there a red X on this connection?
If so, right click on the wireless and click Repair - this may fix your problem, it forces the wireless router to issue the wireless card with a new IP address.
If it doesn't fix the problem then go to Control Panel - System - Hardware tab - Device Manager - scroll down to Network Adapters and expand and check your wireless card, is it Working and Enabled?
If has a yellow ? against it or not working then reinstall the wireless card driver.
If the wireless card is built-in check the BIOS to see if the wireless card is enabled, if not enable the wireless card and repeat the above steps.
If this doesn't fix your problem then the wireless card is faulty and you need a new wireless card. You can get a PCMCIA wireless card to replace the faulty wireless card. If the wireless card is built-in then disable the faulty wireless card in the BIOS before you install the new wireless card.
Oct 11, 2009 | Gateway (802.11usb) Wireless Adapter
HP Pavilion dv9700 laptop, Wireless stops working at random.
HP's normally use the Atheros wifi card which recently has had many problems such as what you describe here. Try a different wifi card to see if this solves the problem. If you don't have a wifi card take it to a local repair shop to see if they have one they can try for you.
Sep 23, 2009 | HP Computers & Internet
Acer 6930 wireless won't connect anymore.
Hi acording your describle, you need do
1) please check the bios first, to set wireless to enable
2) check windows right buttom bar is there a wireless icon show there and click to see any detect wireless signal, if nothing to detect
3) check or compare to other laptop wireless configuration, check any incorrect setting.
4) if all sense ok, you need check the wireless card and wireless antenna wire connection, open a samll cover at back of laptop, there is a MINI PCI slot with a wireless card, take out and clean the card pins then put back.
5) still trouble please change another wireless card (same model)
it should be fix.
hope help you to fix it, please take a rating le me know how much helped you, thanks. for any question in any time please !
May 17, 2009 | Acer Aspire 6930-6455 Notebook PC
Wireless stops working and have to reboot
It sounds as though your wireless card is starting to go out due to heat. If you have another laptop or a friends laptop to see if they can connect ok without experiencing the same problem you will eliminate the router as the cause. But more than likely you will need to replace the wifi card.
Please rate this if it helps.
Thanks
May 03, 2009 | Lenovo ThinkPad SL500 Notebook
Acer wireless not working
There are many reasons why wireless doesn’t work but lets look at it step by step
How it works is that there’s a card inside your laptop which detects networks “wireless only” that are in your house and near you like neighbours.
The most common mistake is “the button” there is bound to be a button either
On the side, the rear, the front of the laptop or even near the keyboard it usually has
A dot with signal lines that button switch on and off the wireless device so make sure its on and then wait 10 second for the signal to appear.
There is no button? Right then there’s a keyboard shortcut to switch it on and off
You must first press and hold the “fn” button or the function button then find the wireless key which is either “f8” or “f4” it varies from model to another but it always has the wireless logo on it and it is always one of the f keys.
Didn’t help? It could be you’re running multiple utilities to run your wireless, you either have to use windows utility which is normaly in your task bar but if that’s not working then another utility is using it, so find in your programs list “wireless utility” or “belkin utility” which usually does the same.
Didn’t help? Its getting more serious, makesure your driver is installed for the wireless, if you go to the device manager and then to the network area and there makesure your wireless drvice is enabled “no red cross on it” or else if you cant find a wireless device in there then it means your wireless card is faulty and need an expert looking at it.
It is good practice to re-install the wireless driver to fix most issues.
Mar 07, 2009 | Acer Aspire 5050-3242 Notebook
Wireless connection
Does the Acer have a built in wireless LAN card?
If so are the drivers installed?
Go to the Control Panel, then Network Connections to verify the wireless connection etc..
If you don't has a wireless card you will need to get a PCMCIA wireless card and install the drivers and configure it to suit your wireless router configuration.
Jan 06, 2009 | Acer Aspire 5315 Notebook
Wgr614 wireless router will not connect
This makes me think that the wireless in either the router or the laptop has failed. Will the laptop connect ok if at another hot spot? if so, then you may have a problem with the router. If the laptop will not connect when somewhere else, then the wireless in the laptop has a problem. that could be a problem with the internal wireless card, or a driver file corrupted. Check the wireless card through the device manager to see if windows reports it working properly, and make corrections there as may be necessary. If windows reports all is ok, you may need a new card.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Dec 24, 2008 | NetGear WGR614 Wireless Router
Wireless access
my wireless card was working great, then stopped all of a sudden. If I connect to the Modem directly it works, do I need a new wireless card?
Jul 02, 2008 | Toshiba (PA3212U) Wireless Adapter
HP (D7580-60003) Motherboard Logo
98 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
