Question about AEG T57800 Electric Dryer
Pilot how do i light the pilot light on my dryer,i have a whirpool
  • 52 Answers
It probably has an electronic pilot light. It should light by itself. If you have a real old one, you have to open the cover at the bottom, and light the pilot.
Posted on Jul 14, 2009
My Whirpool dryer Model LGR 563 isn't heating now. Does it have a manual or electronic pilot light? I don't see a pilot light lit through the hole.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 24, 2011 | Whirlpool LGR5636PQ Gas Dryer
Our Whirpool Gas water heater is leaking from one of the top water supply lines and the pilot went out. we tried to light it back on and it does not. before we can replace the leak should we continue to...
first repair the leak then remove the burner assembaly at the end of the pilot tube you will find a small orfice were the gas comes out for the pilot remove that and be sure it is free from debri and not clogged replace it when the burner assembaly is back in place and reconnected try to light the pilot if it still wont light as you are trying to light the pilot tap the side of the gas control valve (somewhat hard) if it then lights you know you have a bad gas valve if you are getting gas through the pilot orfice (not air if you have recently disconected the gas supply) and it seems to be blowing to hard you will need to replace the pilot assembaly at the end of the orfice as the small sheild also helps make the gas air mixture
Aug 25, 2010 | Whirlpool Heating & Cooling
How do I relight the pilot light?
There is no pilot light on many of the dryers of today. They light with a hot surface ignitor.
Here is a tip that I wrote about dryers and no heat on gas dryers...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Apr 01, 2010 | Kenmore 72802 Gas Dryer
No heat in whirpool supreme dryer
Check the PILOT-LIGHT. And be sure the gas is reaching it.
Oct 25, 2009 | Whirlpool LER5636P Electric Dryer
How do I light the ignite pilot light
Most new dryers don't actually have pilot lights. They use an electric heater that turns red hot, and ignites the gas at the right time. If your trying to light the pilot light (which probably doesn't exist) because the gas isnt being ignited,,, its possible that the electric igniter needs to be replaced.
Mar 13, 2009 | Kenmore Elite HE4 Electric Dryer
How do I light the pilot light
Gas dryers use an electronic igniter, there is no pilot light.
Mar 12, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Whirpool dryer wont run
inside light on when door is closed??? that sounds like a bad door switch. it doesnt recognize the door shut so it wont start, replace the door switch
Mar 29, 2008 | Dryers
Pilot Lighting for Neptune Dryer
there is an electric igniter but no pilot light in the Maytag 5500 gas dryer. you can change it yourself.. let me know
Aug 23, 2007 | Kenmore 67082 Electric Dryer
Pilot light
Pilot Light? Are you sure? All the gas dryers I've ever worked on were pilot-less. There should be a glow-type ignitor that heats up when the dryer is turned on. When it reaches a certain current potential a gas valve is opened and the burner ignites. How old is this dryer? Maybe this is something I've never seen before.
Jun 05, 2007 | Kenmore 72802 Gas Dryer
AEG T57800 Electric Dryer Logo
193 people viewed this question
Top AEG Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you an AEG Dryer Expert? Answer questions, earn points and help others
