Question about LG WM-1480FHD Front Load Washer
  • 2 more comments
  • bikkle Nov 17, 2007
    I am having the same problem, repairman came out took something out of pump, it worked once, am now back to washer not emptying, wont spin ahd displaying OE. Help.
  • Anonymous Feb 22, 2008
    the machine will not empty or spin and oe is flashing , what does oe mean
  • Anonymous Apr 03, 2008
    I've had the same OE problems twice now. The first time, I was still covered by extended warranty and had the engineer come out to fix it. He changed the electronic board and tinkered around some more and fixed it.
    A few days ago I had the same problem again, and only found help on this site as there is no manual for this model online.
    I opened up the filter as suggested after draining the water, and bingo! found a 50p coin and a sweet wrapper. The washing machine is now working again.
    Thanks for the advice. Was on the point of giving up on LG and buying a new washing machine.
  • Anonymous Feb 24, 2009
    OE showing. Have checked drainage hose - not kinked and water is pumping through it, and have also checked drain pump filter - fine. Washing cycle cant seem to get onto the spin stage. Please help. Steve.
Had the same problem and there was a $2 coin stuck in the hose that empties the water from the barrel to the pump. Couldn't find the problem initially, but after numerous times emptying the front drain pump filter (little carriage you pull out) I felt inside where the pipe empties into this carriage and felt the coin. Had to get underneath and pull off the pipe that attaches to get it out. Hope this helps.
Posted on Dec 05, 2007
  • Pschsuze Dec 05, 2007
    More Info...........OE means a drainage problem. In the manual it tells you to check the drain hose (is it kinked or clogged) and check the drain filter (is it clogged). Poured water down the drain hose and checked it was running out through the drain filter at the front. The $2 coin was stuck in the pipe running to the drain filter from the barrel.
THANK YOU!!! Your comment about the filter just saved us a lot of money. I really appreciate you posting the information! We had the OE issue and it ended up being huge lint build up! THANK YOU!
Posted on May 21, 2008
My LG washing machine is showing OE fault what do it mean ?
OE means uneven load.
If you can open door, put a dry towel in with the washing and try spinning again ...
Nov 20, 2017 | LG Washing Machines
How do i fix "OE"code.
if it is like my dishwasher the oe code means the unit is over filled with water. My dishwasher had a major fault that blew up a circuit board and had a faulty front assembly. Still in repair shop waiting for parts.. I would deduct that the washing machine is not emptying water so I think a water pump could be failing. My dishwasher was not activating the washer motor and came up with the same code but..
Apr 03, 2015 | LG WD-12126RD Front Load Washer / Dryer
My washing machine isnt loading with water
hi i think you mean a ball looks like a ping pong ball it doesent go in pump it sits in filter i allways take them out anyway its up to you strange about water check wires to valves were water pipes fit unplug 1st
Jan 12, 2014 | Hotpoint Aquarius WF210 Front Load Washer
Wm1814cw will not drain oe error
oe on your machine means your pump is not emptying empty the machine manually and clean out your pump it should work then
May 23, 2013 | LG WM1814CW Front Load Washer
Top load washer filling, emptying but tub not oscillating or spinning. Motor sounds like it is running fine. Colin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
Dec 27, 2010 | GE Washing Machines
My washer machine keeps displaying OE. We have checked all the hoses, and everything seems fine. Will not empty water or finish cycle
Error Message : the OE is (outlet error).
1) If OE error occurs, clean & empty the filter.
2) If this doesn't solve the problem, and it won't drain, then provided that you can hear the pump spinning (the normal whirring the machine makes that should be accompanied by the water going down the drain) then the hose pipe leading to the pump is probably blocked.
I'm sure a lot of dodgy service people might just charge you for a new pump & labor, but if you can hear the pump spinning then you just need to remove the blockage.
Aug 12, 2010 | LG WM-1832C Front Load Washer
My lg front load washing machine is reading oe
oe is drain error, which means that the machine is slow/or not emptying..Most likely you have to clean the pump filter...This is accessed via the small door at floor level..Unscrew the pump cover andclean the filter...Remember that any water will drain from the machine from here, unless the machine is empty...Leaning the machine back can help...Good luck...Nomess
May 20, 2010 | Washing Machines
LG Intello wm-1460FHD stops spinning during the wash load.
OE is a drain error (indicating the machine has not drained out in under 10 minutes). If the drain pump is not coming on at all then you have a bad drain pump motor. If it is trying to drain then you may have a clogged up drain hose. The most likely cause is a bad drain pump motor. Hope this helps.
Jan 11, 2009 | LG WM-1480FHD Front Load Washer
LG WM-1480FHD Front Load Washer Logo
1,790 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
