Question about Maytag PAV2300 Top Load Washer
Maytag washing manchine get stuck on final rinse. Sometimes work thru complete cycle w/o problem. on occasions it does not do final rinse.
    Problem Solver:
  • 5 Answers
Replace timer or control board depending on model
Posted on Jul 14, 2009
Maytag bravos gets stuck at 8 minutes on cleaning cycle
Probably the timer is hanging. A vinegar rinse won't make any difference.
Aug 21, 2017 | Maytag Washing Machines
My Maytag Neptune front load washer (about 12 years old gets stuck between 7 & 8 (minutes) in the rinse cycle and won't progress beyond.
It has reached it's use by date, It will just keep on needing repairs , save some money and buy a new one.
Jan 04, 2016 | Maytag Washing Machines
For some reason my GE GBVH6260 washer cycles are getting hung up on either the wash or rinse cycle. Some days it will stay stuck in the wash cycle & some days it will stay stuck in the rinse cycle for...
Most likely its your water inlet valve..(cold side is not letting water in). Very common problem that usually manifests during rinse cycle since rinse uses always cold water.
According to your model # , part # is WH13X10023
Jul 10, 2017 | Washing Machines
Dishwasher runs for appx 14 min & stops washing half way thru wash cycle. Timer contunies to run. No drain pump out (nothing). Let dishwasher set idle for appx 1 hour and it will re-set. Set timer...
This sounds like something is stuck in the drain pump. You can remove the inner cover to look for obstructions. You have a dual purpose motor it does the both circulating and draining. The blockage is causing it to overheat and trip the thermal protector. You can remove the drain assembly from underneath if you don't find anything from above. There is a video at www.appliancehelponline.com/servicemanual.html that walks you thru most of this. It is a different model but pretty close.If you find no obstructions the motor may be failing.
Apr 08, 2010 | Whirlpool DU840CWD Dishwasher
Washers fine but doesnt drain water and go to rinse cycle
Check the drain hose may be kinked. Washers have been known to eat socks, they go in to the the tub during the spin cycle and down in the pump. If you are so inclined to look dome pumps are clear and you can see the sock. There is a hose clamp to remove and you may be able to remove the sock. Reassemble and test. Remember as always to unplug the washer first before doing any work. This exploded view has a washer and if you hover over the bottom right it will show what the pump looks like.
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram Good luck
Aug 21, 2009 | Kenmore 22422 Top Load Washer
Maytag neptune stops in mid cycle
It sounds like your drain pump is going. Neptunes are suppose to neqarly dry the clothes with how fast it spins. A poor drain pump/motor, could cause this to be less effective. There could also be something in the drain lines. I would check that before you pay money on a pump though.
Feb 28, 2009 | Maytag MAH20PD Front Load Washer
Washer not finishing it's rinse/spin cycle
Run any load - large or the least bit bulky (like sheets) on the "BULKY" cycle. It takes longer, but the machine completes the wash. This shouldn't be the way it works. I love the Neptune TL for its retro look and lack of Maytag's classic big cranky knob. Too bad it runs like ****.
Feb 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag PAV2300 Top Load Washer Logo
189 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
