Question about Uniden DECT1080-2 Phone
My phone was working fine until we moved and now I can't make outgoing calls, caller ID doesn't work and answering machine won't pick up. I assume I have to reprogram, but can't find the manual. Wondering if I can download manual OR if you can tell me how to reprogram. By the way, if I plug in an old phone (no answering machine) I can make outgoing calls. Thanks.
  • 37 Answers
Buy a new one.
Posted on Jul 14, 2009
How to change number of rings on VTect cordless CS6114-11
The CS6114-11 isn't an answering machine. It will ring until you answer, an answering machine or voicemail system picks up, or the caller hangs up.
To change the ring count on your answering machine, consult its documentation. If you require further assistance, please add a comment to this question and identify the answering machine or voicemail system.
Jul 30, 2014 | VTech Communications CS6114 - cordless...
CHANGE THE NUMBER OF RINGS ON THE VTECH CS6719-16
The CS6719-16 isn't an answering machine. It will ring until someone answers, some other answering machine picks up, or the caller hangs up.
If you want to change the number of rings before an answering machine picks up, please reply to this post and specify the answering machine.
Apr 08, 2014 | Vtech CS6719-16 Cordless Phone with Caller...
My panasonic KX-TG5000 phone headsets cannot make or recieve outgoing calls and the intercom function is gargly.
You need to reset the menu once again as it is possible that the phone had hung up as there was LINE PROBLEMS . Once this was reset the CLIP facility came back. So if you can once again remove power battery and keep aside to reset , then start all over to set up the base and slave units to MESH , the intercom and line facility must work.
You can remove the battery from the slave remote units to reset.
Oct 20, 2011 | Panasonic KX-TG4500 Phone
Caller id is not working in my cordless phone. Instead of number of a caller, "Incoming Call" is showing. Please help me
Caller ID on landline phones relies on signals from the telephone service provider. Some companies charge extra if you wish to enable the service, others include it automatically, so you need to check with them first.
Even if you have caller ID enabled, callers can choose to withhold their number. Large companies which make lots of outgoing calls (especially cold callers) often have their service set to automatically withhold their number. In many countries, all other callers can choose to do so by prefixing all dialled numbers with a short code, e.g. in the UK it's 141. Mobile phone callers can usually alter a setting on their handset so that caller ID is withheld when making outgoing calls.
Sep 29, 2011 | Lands Phones
I am having a problem with my Panasonic KX-TG6442t. It won't store phone numbers and is not show numbers on the display when the calls come in. It just says incoming call. When I go into look at the...
Welcome to Fixya
Try to erase your phone's voice messages. Press ERASE 2 times while the phone is not in use. Caller ID is being activated by your phone provider. To use Caller ID features, you must subscribe to a Caller ID service. Contact your service provider/telephone company for details.
Thank you for using Fixya!
Jul 12, 2011 | Panasonic KX-TG6442T 1.9 GHz Twin 1-Line...
Answering machine Model 25865. Is there any way to turn the answering machine "on" remotely. Example: while away, electrical storm causes machine to turn off. Is there any way to remotely...
The manual for this phone doesn't say you can turn the answering machine on remotely, but every one I've ever seen can do so. Most of them say call your number and let the phone ring...and ring...and ring, and eventually the answering machine will turn on. Ten rings is what I've seen most often. I guess the manufacturers figure most callers will hang up fairly soon if the machine doesn't answer, so they pick a large number. Try it on your phone; worst that can happen is it won't work.
Jul 09, 2011 | Uniden Cordless Phone
No caller ID. TP company says I have service.
  • Did you fully charge your phone? - Make sure you fully charge for 16-24 hours .
  • Is the battery old? - Replace the battery.
  • Is the electrical outlet switch turned on? - If you are using AC (electrical) power, make sure that the unit is connected to a non-switched electrical outlet.
  • Are the connecting wires tight - Unplug the AC power converter from the unit and plug it back in.
  • Do you have Caller ID service with your telephone company - In order to receive Caller ID records, you must subscribe to the standard name and number Caller ID service available through your local telephone company. If the Caller ID works for normal calls but not on Call waiting calls, then you must contact your phone company to get the combined CID/CW service.
  • Caller ID shows up after second ring - Be sure to wait until the second ring before answering. Caller ID signals comes through after the first ring, if caller pick ups phone too soon Caller ID signal will not be transmitted to the handset.
  • Confirm that caller ID is still working on that particular line by checking another phone on the same line - If Caller ID is not coming through contact your phone company provider.
If this does not fix your problem, contact your authorized Service Center.*
Oct 16, 2010 | Uniden DECT 6.0 Cordless Phone ID
Problem with answering machine on Panasonic Model # KX-FPG376
i followed the advice posted & it worked fine after that. thanks.
Nov 22, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
I can not get my phone to pick up on the answering system when a caller is trying to leave a message
Try looking underneath the console of the answering machine. You must turn the answerer on on most machines and underneath there may be a switch to determine how many rings before it picks up as well.
Dec 26, 2007 | GE 28111 Cordless Phone
Uniden DECT1080-2 Phone Logo
105 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
