Question about Cameras
My camera won,t let me put more pictures on,it keeps saying memory card full,and i used to be able to store more pictures on it
  • 975 Answers
FIRST check out the settings of camera , example , 3 mp 200 pix capacity , 5 mp 100
pix capacity , the higher the MP , the less pictures capacity , hope this helps , AJ
Posted on Jul 14, 2009
My lg800 tracfone won't take pictures,it says memory is full even though i just put in a newmemory card?
Set the phone to store pictures on the card. Tap the camera icon to bring up the camera, then tap the gear to bring up the setting menu. Tap the down-arrow, then tap "Select Storage" to switch between camera and memory card. Tap "OK" when done.
Jan 13, 2013 | Oregon Scientific DS6618 Digital Camera
I cant format the pictures from camera
Try using a different memory card. Or use a memory card reader and format it using your computer.
Sep 14, 2012 | Kodak EasyShare C713 Digital Camera
Why does it keep saying memory full after I have only taken 6 pictures
You need to go to the store and buy Samsung S730 A-DATA 4GB SDHC Memory Card (Class 4)
It is worth about 8-20$. The memory card is used to save pictures. Here is an example: http://www.cellularfactory.com/camera/SAMSUNG/3/46100/
Apr 02, 2012 | Samsung Digimax S730 Digital Camera
I just got a samsung sensory pleasure nv3 i put a 4 gb memory card in it and it says memory full but the card is empty
Hi
Try formatting the SD card before using it.Also,check the storage destination of the pictures,could be they're storing on your camera and not in the memory card.Make the SD card the default storage device.
Hope it helps.
Feb 20, 2012 | Samsung NV3 Digital Camera
It keeps saying memory card is full. Bought a new memory card and put in and it still says the card is full.
Are you sure that isn't "internal" memory card is full message?
Sometimes, when "internal memory card is full" there is no more space in the camera's internal memory. Your camera has 16 MB of internal memory. The number of pictures you can store depends on the picture size setting you have selected on your camera. Keep in mind that the camera always uses internal memory, even if a card is installed (auto default).
If really, the problem is in the "SD memory card", I suggest make some backup all files and reformat the SD. Try formatting it in the camera, there should be a process in your owners manual for doing this; donw formatted SD in your computer, isn't good.
Hope helps.
Apr 28, 2011 | Kodak EasyShare One Digital Camera
Finepix a600, in memory full, won't take photos
Connect it to your PC, using the USB cable provided.
Click on my computer, you should see another HDD drive appear, it may be called Fuji or mass storage device.
Double click on that, you'll see folder, double click on that you should see the pictures stored on the internal memory of your camera.
Jul 21, 2010 | Fuji FinePix A600 Digital Camera
Always says MEMORY Full
Try the SD card on your computer to see if it recognizes and will store pics on the card. If that doesn't help, try another SD card.
Jul 10, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Camera keeps saying internal memory is full, even after putting a
Your internal memory is separate from your memory card. Think of it as two folders, the internal memory cannot be removed, and the memory card is one you can take with you. You can put new memory cards in it all day, the internal memory will still have pictures in it. You may wish to consider copying all internal memory to the memory card. To do this, make sure your camera has a memory card in it. View pictures on your internal memory, then from the menu option select 'copy all images to external memory.' In doing this, all of your photos will be moved, you can then clean out your internal memory by deleting everything/formatting it. :)
Apr 04, 2010 | Kodak EasyShare Z812 IS Digital Camera
I have a Kodak Easy Share C310. It keeps saying that the internal memory card is full. The card is the camera is 200 photos yet it is only showing the original 16! Thanks, Kathy D
"internal memory card is full" There is no more space in the camera's internal memory. Your camera has 16 MB of internal memory. The number of pictures you can store depends on the Picture Size setting you have selected on your camera.The following are approximate number of pictures you can take at each setting: 4.0 MP: 16 pictures 3.1 MP: 18 pictures 2.8 MP: 20 pictures 2.1 MP: 29 pictures 1.1 MP: 48 pictures Internal Memory?the camera always uses internal memory, even if a card is installed. Auto (default)?the camera uses the card if one is in the camera. If not, the camera uses internal memory Image Storage Choose a storage location for pictures and videos. To correct the issue your getting follow this steps: 1.Press the Menu button. 2.Press to highlight the setting you wish to change, then press the OK button. - The settings you need to look for is Image Storage 3.Choose an option, then press the OK button. - The option you need to choose is Auto the camera uses the card if one is in the camera. 4.Press the Menu button to exit.
Nov 15, 2009 | Cameras
Screen says internal memory full and wont do anything else
You need to copy picture files from internal memory to memory card and then delete those files OR put memory card in camera so it will store new picture files on it.
Aug 01, 2009 | Kodak EasyShare ZD710 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
