Question about Hunter Ceiling Fan Light Remote Control
Our fan is working, but our light isn't , we know it isn't the bulbs or the circut ,what next?
    President:
  • 1,273 Answers
Your light kit wire (the blue one) is not connected properly, or the common wire (white wire) is not making good contact. Check there first. If you have good connections, then I'd suspect the switch being bad.
Regards,
--W/D--
Posted on Jul 14, 2009
Taillights ,arenot working don't know where the grounds are located on the moter home
You can try tracing the wires from the bulbs to find where they are grounded to. Check the fuses for the tailights. Do the brake lights work? sometimes the bulbs short circut aswell.
Aug 18, 2013 | Cars & Trucks
My 52" Hunter Ceiling Fan with remote has been a gem. Last week when one of the light bulbs burnt out, I replaced the bulb, and then neither of the lights (it's a 2 light bulb fan) would come on. The fan...
The two bulbs are just having a separate live cable in parallel with the one of the motor.
So since you have mentioned that you had a burned bulb this sometimes causes a short inside the receptacle of the bulb. So you just need to disassemble the receptacle of the burned bulb and check both the wires live and neutral they are loose or disconnect or even melt and disconnect.
Is a simple operation since you need to check only two wires however it not so easy to remove the bulbs and reconnect the wires.
Oct 16, 2010 | Hunter 52" Ceiling Fan With Light And...
1997 dodge caravan 190,000 runs great, right rear turn signal quit working so i changed the bulb, didn't help, so i replaced all 3 bulbs, no difference....? not sure what to do next, front 1 works so it's...
1. Bad connection in factory wiring. You know, the male and female connectors. 2. Bad ground. 3. Gm's have a circut board for their taillights so if this is the same, it could be the problem too.
Aug 23, 2010 | 1997 Dodge Caravan
Stop Light fuse keeps burning out, resulting in no brake lights. Bulbs are all good. What is the next thing to check?
Check your bulb sockets for a ground short sometimes look good with the eye but you should use a circut tester to be sure witch sockets is the shorting out one.
Dec 25, 2009 | 2001 Isuzu Rodeo
Lights on fan knob does not work
the bulbs are made into the a/c control head and are not replaceable. the only way to get them working again is to replace the hole assembly.
Aug 18, 2009 | 2004 Mazda 6
Fan works lights dont
It's most likely that when the bulb burned out the electrical heat got to the socket causing the emergency shut down of the lights if you take of the light casing there should be a small switch next to one of the bulbs all you have to do is flick the switch, put back the casing and walla your lights should work (hopefully lol =])
Jun 06, 2009 | Hunter 20347 Ceiling Fan
Rear turn signal bulb on passenger side of 1997 GMC Yukon needs to be replaced, how do I do this.
Open your rear door and on the inside jam where the light is remove the two screws.There either a philips or torx head.Rotate out a little and litely pull the other side tabs out of the notches in the quarter panel side.Once you remove the light you will see a circut board with two more screws.Your bulbs are on the inside of the circut board.If your new bulb doesnot work,you may need to replace the circut board,there known to burn out.Hope this helps.John.
Mar 09, 2009 | 1997 GMC Yukon
F6 error... microwave not working
is the microwave itself working? because same thing happened to us apparently the guy who changed the bulb didnt unplugg the thing first and well it burned a part of the circut board cost us about 90 dollars to fix it.....
Oct 05, 2008 | Roper MHE14XKB Microwave Oven
Dryers Logo
201 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
