Question about Frigidaire ATF6000ES Front Load Washer
My washer works on any wash cycle that does not use hot water. However, if I choose a hot wash setting, it starts and begins the cycle then stops. The door is locked but the cycle stops running.
    President:
  • 1,273 Answers
Make sure that you are getting water out of the hot side. Close both faucets, and remove the hot side washer hose. Have something at the ready to catch the water. A bucket will do fine. Inspect both ends of the hose. Usually, there is a screen there to catch any sediment. Inspect the hot connection to the solenoid valve at the back of the washer. There's usually a screen there, too. If you note any specks of debris, pull the screen(s) out and clean. Reconnect the hose to the hot faucet. Pointing the open end at the bucket, open the water valve, making sure that you are getting water there.
>> If you are getting plenty of water at the faucet and through the hose, the problem is probably the solenoid valve. Replace, but unplug the washer first.
>> If the water supply is lacking, you have plumbing issues.
Regards, --W/D--
Posted on Jul 14, 2009
Hot/cold cycle stops before filling up
Your washer has a set amount of time to fill. If the flow is low and the time runs out, then all you will get is the amount of water that was able to fill. Check your lines to be sure that they all fully opened.
Aug 12, 2012 | Admiral 32 cu. ft. Washer
I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
You may have 2 defective parts.
First,make sure the hot and cold water hoses are connected correctly and both turned on.
If the water fill problem is the same,the water temp switch is bad.
The not filling after the wash cycle could be a bad lid switch.
Set the machine for SPIN and turn it on.
If it does not spin,replace the lid switch.
Sep 20, 2010 | Kenmore 24042 Top Load Washer
MILDEW SMELL COMES FROM WASHER
. Set the washing machine on the highest water level, temperature on hot and the wash cycle to normal.
2. Fill a gallon jug with hot tap water. Once the cycle begins, let it run for a minute or two, then stop the cycle, open the lid and slowly add the gallon of hot tap water. Don't overfill — you just want to raise the water level so that it is able to reach and clean the inside top rim.
3. Add 2 to 4 cups of household chlorine bleach and restart the cycle. In a couple of minutes, stop it again and just let it sit for at least 30 minutes. Afterward, let the cycle finish, and open the lid to air out the inside.
Jul 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Admiral Washer smells like mildew
yes it could . If you are trying to pump the water 7 feet or more above the floor then it will at the end of the cycle get air into the drain hose causing cavatation, the result when the machines stops is the water running back down the drain hose back into the tub and that is what causes the musty smell.
Lower the drain if possible
Apr 10, 2008 | Admiral AW22 Top Load Washer
Washing machine wont stop filling up
see if the water coming in is hot or cold by turning the water faucets off and on to see if one fills and the other dont and replace the valve
Feb 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire ATF6000ES Front Load Washer Logo
64 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
