Question about Frigidaire Refrigerators
Whats the wiring diagram on a frigidaire gallery refrigerator, model number FRS267TH
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
You should have a copy of it behind the toe grille on the front. Or on the back of the unit.
Posted on Nov 15, 2015
ryeisenman
  • 9 Answers
SOURCE: cold freezer/warm refrigerator
Same problem with Frigidaire Gallery model#GLRT182SAW5 (dated 2002 on back of case)
Vents were blocked with ice. Vents (from top compartment to lower) located behind light. You can check by poking a chopstick up the (2) holes; be careful not to hit fan blades.
Solution:
- took freezer coil cover off in back; checked that defrost heater element was working (marked and rotated the timer in the hole next to light); checked that fan working. Found ice in the vents and defrost drip area. Got it out with hair dryer.
- cleaned compressor coils in back (check fan is rotating; also tweaked some of the compressor tubing bends to make them more smooth - read somewhere about a manufacturing defect ...); blew out drip tube from defroster while down there.
- Set the freezer control to WARM and the refrig control to COLD (THIS SHOULD IMPROVE AIR FLOW FROM TOP TO BOTTOM).
- Put thermometers in top and bottom. Checked that refrigerator cycles (not running continuously). Checked that cold air is coming down from (2) vents behind light.
OK: so far, so good. Lower compartment is 40 or under. Top is under 18.
CONCLUSION: Suspect marginal design. Had problems with another similar model where defroster ice doesn't drain correctly, pools and refreezes. Leading to blocked vents as well as blocked defroster drain and similar problem including dripping water from top to bottom and warm bottom.
MAYBE KEEPING THE FREEZER CONTROL AT WARM GETS AROUND THE PROBLEM?? ANYWAY, ITS WORKING FOR ME FOR NOW !!
Posted on Dec 13, 2008
erpaalai
  • 999 Answers
SOURCE: I am looking for a wiring diagram for the Amana
Look behind the toe plate for the tech sheet. Hopefully it was not removed with the packing materials. If it is missing try here
http://www.apwagner.com/index.php?main_page=product_info&products_id=566096 the part number is RT1300013
Posted on Oct 12, 2009
SOURCE: finding wiring diagram whirlpool refrigerators
take off bottom cover should be on back if not look around compressor they usually leave them stuck around there
Posted on Apr 12, 2010
BIKER T
  • 909 Answers
SOURCE: Frigidaire Gallery refrigerator, evaporator fan not running
As insignificant as it may seem, that evap fan motor is as important as petrol in a car. That fan controls the fridge cooling on many fridges and circulation in tha freezer compartment. Replace it with the correct one and you should see a functional fridge/ freezer again. Note, i wouldnt run unit without it for long, as condensig temperatures run high and compressors dont last long.
Posted on May 23, 2010
heatman101
  • 43501 Answers
SOURCE: refrigerator not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 30, 2010
My older model of Frigidaire refrigerator will not stop running. we cleaned dust and stuff out of the back, but won't shut off. Whats wrong with it?
To check the thermostat, just remove one of the wires from it, if it then stops, but keeps going and does not shut off when you reconnect it, the t/stat is bad.
Feb 21, 2015 | Frigidaire Gallery Series GLRT83TEK 30"...
Where is the air filter?
Good Afternoon Friend, that\'s a great question!
In order to provide you the correct location of the air filter of your Frigidaire refrigerator, I would need your model number please? The serial tag, which lists your model number, is normally located inside the cabinet, on the right side wall. Thank you! - Z
Aug 09, 2014 | Frigidaire Refrigerators
ANYONE HAVE A WIRING DIAGRAM FOR FRIGIDAIRE GLR52642A?
Good Afternoon Friend, this is Z. Thank you for allowing me to assist you!
I understand you are seeking the wiring diagram of your Frigidaire refrigerator, GLR52642A. However, it appears that the correct model number is GLRS264ZA. I have successfully located the Wiring Diagram. I hope this information helps to some degree. If you have further questions, please do not hesitate to reconnect.
Aug 08, 2014 | Frigidaire Refrigerators
Frigidaire Dryer Model # GLER331AS2 wiring diagram
Hello Anonymous, thank you for your post!
I have successfully located the Wiring Diagram of your Frigidaire dryer, GLER331AS2. I hope this information proves to be helpful. Should you need any further assistance please feel free to respond.
Best regards - Z
Apr 06, 2014 | Frigidaire Dryers
What's wrong with my frigidaire gallery, it wont
What is the model number of your unit? Is the compressor running?
Nov 24, 2012 | Refrigerators
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Serial number
there are a few places to look for most frigidaire side by sides the model and serial number are on a tag either on the right hand inside wall of the refrig section or on the ceiling in the refrig section. on some older models though the tag may be behind the crisper drawers at the bottom. hope that helps. peyton
Jan 27, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery fridge, 1999. where is the water filter?
What is the model number of the refrigerator. looks like it is in the upper right corner of the fresh food section. If you go to frigidaire.com you can get the owners manual.
Jan 09, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerators Logo
137 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Sal De
tom wright
tom wright
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
