Question about Refrigerators
Freezer door pops open
After someone cleaned our Kitchenaid frig/freezer, now when shutting the frig door the freezer door pops open (creating tons of frost!).
Freezer does seal shut but when the frig is shut with any strength (you know, normal) the freezer door pops open about 1/4-1/2 inchs.
Nothing is blocking the freezer from shutting.
  • 39 Answers
There's nothing wrong w/your dr seal. add a then layer of silcone or vaseline to the seal. this will make it sticky again.
Posted on Jul 14, 2009
Kitchenaid superba frig.past 2 days high pitched over temp light alarm goes off every few hrs in between reset we cleaned coils temp in freezer seems fine but frig is not please help
May be frozen up or plugged up. Remove all food. Unplug it and open the doors. Leave for 24 hrs. Clean up any water. Clean out the tray underneath. Usually access from the front if you can pop off the trim panel under the doors. Pull it out. Remove the back. Inspect for large amount of debris. Check any cooling fins etc. use a vacuum with a hose to clean it all out. Plug it back in and try it.
Sep 15, 2015 | KitchenAid Superba KSRG25FK Side by Side...
My freezer door used to **** shut now it easily pops open
What you are talking about sounds like the magnets in the door seal are weak.
Mar 10, 2014 | Frigidaire Freezers
GE refrigerator model #LTC19340ST freezer door not sealing
That is a common problem with over-under units. You can clean or replace the door seal or, tilt the unit back a TINY bit. The door pops open because there is a common airway from the freezer to the fridge. When the fridge door shuts too fast, it pushes a lot of air into the unit. It needs to go somewhere so, it pops the freezer door open. If you shut the freezer hard enough, you will be able to pop the fridge door open.
Jan 20, 2013 | LG LTC19340ST 19.0 cu. ft. Top Freezer...
When I close the frig door, it blows the freezer door open. The same when I close the freezer door, it blows the frig door open.
That is because the unit is sealed. If the doors are staying opened I have posted a how to fix it linked just below.
Doors
May 26, 2010 | KitchenAid Superba Architect KSCS25INSS...
Freezer door won't stay shut
This indicates that you do not have good airflow and return airflow between your freezer and refrigerator sections. That is why the pressure from closing one door is causing the other one to pop open.
Check the drain tube on the back of the machine to make sure it is not clogged or blocked with frozen water inside. Also check any return air flow vents inside the unit for clear ice.
Jan 18, 2009 | Refrigerators
I have the exact same problem - very annoying. The only thing I found to work was to purchase one of those child safety locks. I bought the Kidco Appliance Fridge Lock S330 because it was the only one I could find that automatically relocks after you shut the door. Buy two (or more) at a time because the arm will eventually wear out and break (after several months depending on how often you use it). You can check out the product's details on eBay - that's where I purchased mine. Hope that helps.
Aug 27, 2008 | GE GTS22KBP Top Freezer Refrigerator
Maytag frig side by side door pops open when I shut the other side
the ref. is not level or too much wieght in the freshfood door
Jun 03, 2008 | Refrigerators
Freezer side door not locking shut
Mine has been doing this for over a month. Then on Friday it started making a clicking sound a CONSTANT clicking sound. I get home from a marriage retreat for families getting ready to be deployed and gee ALL my food in the fridge is BAD!!!!
My model number is ssh25kfrfww Please give yours. Also my door NEVER locked from day one. As my children are older I didnt think it was a big issue till today.
Apr 14, 2008 | GE GSS25SGSSS Stainless Steel Side by Side...
Refrigerators Logo
718 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
