Question about Garmin nuvi 250 GPS Receiver
How do i reset my password
I forget my password for my garmin nuvi 255w how do i retrive it or restart it
    Brigadier General:
  • 3,006 Answers
I've been trawling for unanswered questions; this information may be too late for you (or perhaps it may help you resurrect a useless machine which you have put away) but it will certainly help others searching for advice with the same problem.
You have Garmin Lock activated on your nuvi: there are only two ways you can unlock it.
1. Enter the PIN code (but you clearly don't have it or you wouldn't be reading this).
2. Take the unit to the Security Location you chose when activating Garmin Lock: it will then unlock without the PIN code and you can then either reset the PIN or disable Garmin Lock. The Security Location should not be the owner's home address, but many owners ignore this recommendation. Many owners choose their workplace or a close friend or relatives address for this purpose.
If neither option works then your unit is useless unless you send it to Garmin with proof of purchase. Garmin charge for the service and if your maps are not up to date then it's really a waste of money as the investment would be better spent on a new unit with current mapping.
I hope that you manage to either fix your problem using my advice or at least can decide whether to abandon the unit and buy another.
Posted on Oct 06, 2010
An forget my paswuor
When you set the password you set up a "security location" go to this place and if should be unlocked. You can also send it in with a receipt to an authorized garmin dealer to have the password reset with a small service fee.
Jan 12, 2011 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 255W Delete Phone Numbers
Garmin Nuvi 255W Delete Phone Numbers
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 265WT, 275
Would you like to erase the phonebook entries on your Garmin Nuvi 255W, left over from when you bluetooth paired with your cell phone?
I can help you delete the phone numbers on your Garmin Nuvi 255W.
The phone numbers transferred to your Nuvi are only supposed to be available when your phone is paired to your cell phone. Changing the entry on your phone should allow that entry to show up changed the next time it is paired with the Nuvi. Sometimes, a bluetooth mix up causes entries to be duplicated or entries' phone numbers to get repeated.
To correct this, I recommend backing up your favorites, clearing all user data (this hard reset will remove the phonebook info from your nuvi), and then updating your Nuvi' firmware to make sure the nuvi and cell phone bluetooth process runs as smoothly as possible in the future.
Follow these three steps to take to get your Nuvi 255W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 255W WebUpdater to replace its firmware / system software.
I hope that helps.
____________________________________________
Backup your Nuvi 255W Favorites here.
Download Nuvi 255W Manuals here.
Download Garmin Nuvi 255W WebUpdater here.
Garmin Nuvi 255W Hard Reset here.
on Apr 23, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 255W Change Home Phone Number
Garmin Nuvi 255W Change Home Phone Number
Would you like to edit the phone number entry on your Garmin Nuvi 255W for the Call Home option?
To edit your phone number touch:
  1. Where To?
  2. Favorites
  3. Home
  4. Edit
I hope that helps.
I forgot my password for my garmin nuvi 255w how can i reset it? please help
If you forgot your PIN, take the unit to your Security Location (where you first set the PIN). The unit will unlock and you can reset it.
Aug 26, 2010 | Garmin nuvi 255W GPS Receiver
Will not turn on
I have a garmin 255W when turning on all itdoes is go to a white screen with black dot thatsay Press dot .It wont turn on how do you fix this
Jan 19, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Garmin Nuvi 255W Favorites Backup and Restoration Procedure Models: Garmin...
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Would you like to back up a copy of your Garmin Nuvi 200 Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
Garmin Nuvi 255W Hard Reset Here.
Garmin 255W WebUpdater here.
on Apr 18, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 255W Webupdate
Garmin Nuvi 255W Webupdate
Does your Garmin Nuvi 200 or 200W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Garmin Nuvi 255W Favorites Backup here.
I don't know the pin for my Garmin Nuvi 255W. Help! I have used it a few times in the past. My granddaughter set up but she does not recall the pin either. Any way to bypass this or is there a way to...
Unfortunately, even if you perform master reset on Garmin GPS unit, it does not reset Garmin Lock security feature, which password-protect most Garmin electronic devices to deter theft. If you forget the PIN or password unlock code to unlock the Garmin unit, the best solution is to bring it to Garmin to get unlocked. “Secure Location” does not unlock a locked Garmin unit either as it’s only a temporary fix as when it’s turn on outside the security location, the device is locked again."
So unfortunately, there is only one option: You have to send your nüvi into the Garmin, who can unlock it. Remember original receipt.
Apr 18, 2009 | Garmin nuvi 255W GPS Receiver
Forgot password on my garmin 255W
Page 37 of this manual gives some tips:
http://www8.garmin.com/manuals/nuvi205_OwnersManual.pdf
Basically, if you want to turn the system on, just return to your "Security Location."
If you want to reset the 4-digit code you will need to send your nuvi to Garmin and provide proof of purchase or valid registration.
Mar 26, 2009 | Garmin nuvi 255W GPS Receiver
Tip
Download Nuvi 255W Manual Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W,...
Have you lost your User's Manual or the Quickstart Guide for your Garmin Nuvi 255 or 255W GPS?
Would you like a digital copy for easy searching of terms and quick reference?
Both manuals are available in pdf format, just follow the photo links below:
I hope that helps.
on Apr 16, 2010 | Garmin nuvi 255W GPS Receiver
Garmin nuvi 250 GPS Receiver Logo
124 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
