SOURCE: Can i send video from Nintendo Wii through my home theater to my projector?
A few things to consider; what type of connection is your Wii using? Composite, component, s-video, coax? Most home theater setups are made to route multiple video signals, usually of the Composite (RCA Red Yellow White) variety, and should be clearly labeled Video In. If it doesn't have extra inputs, you might want to consider buying a media switchbox- http://www.cyberguys.com/templates/searchdetail.asp?sk=MC71730&productID=7663 A switch like the one linked above allows you to hook multiple audio and video sources into it and easily switch between them by pressing a button on the front.
SOURCE: Black and White video on S-Video output
The Concept of S-video is Splited Video Signal (Luminance for black and white, Chrominance for colors), in your case the luminance is ok but there is no chrominance out. Expert technician is required: Check for dry solder at the s-video out outlet. Good Luck Toufic Malek
SOURCE: I'm not getting any color pictures in my home theater system
Well, assuming were talking about a dvd player with dvd's,you dont specify what type of cables you are using to conect it to your tv, it appears that it has something to do with Progressive Scan been turned on. Progressive Scan is a feature built in your dvd player, wich by using it, it would give you a better picture//resolution on your tv, you need to use Component or HDMI cables to hook up the dvd to your tv if you want this settings, but if you are using composite RCA cables (Red,White & Yellow) and the Progressive funtion is turned on by accident, it may give you a split screen, black & white, or no picture problems. Also if you are using Component (Blue, Green & Red) cables, if one of them is unplug, the picture can be out of colors, or no picture. Check this things, if not, write back with more details about your set up.
Thanks...
SOURCE: Error Message
The F61 indicates a problem detected in the output amp stage and the unit us shutdown to prevent further damage. If you can supply the model number, I can give you the part required and the approximate cost.
Dan
