Question about Lands Phones
On dial pad there is an option for telephone or headset.When I chose headset I must chose speaker,microphone and ringer.How can I get magic jack to remember these settings so I do not have to set them each time?I see no option to save.Thanks,Chas
    Problem Solver:
  • 14 Answers
When you choose headset simply connect a hheadset to your ears, inhis option speaker/mic/ringer all are automatically comes in headset
Posted on Jul 14, 2009
Magicjack problems
Try another telephone as the magic jack device only provides a certain level of voltage output which does not supply enough power for a dial tone and power to older telephones. There are work arounds provided within the magic jack forum blogs which can be found by visiting this website, found on google.
Dec 22, 2013 | magicJack New & Improved 2012 Plus Free...
Install magic jack software
When you plug the MJ into a USB port, you should get a software program that come up asking you to Register it. Follow the directions and get a Telephone number and key pad for dialing out and/or receiving messages.
Dec 18, 2013 | Computers & Internet
Cs70 headset with a Cisco 7975 phone, is there a way to not have the phone ring in the headset ?
This works if you're using the HL10 handset lifter with your CS70. The HL10 has a built-in microphone to pick up the vibrations from the ringing of the phone speaker under the handset. The HL10 came with an accessory package that has an extra round microphone on a cord to help the lifter if the telephone speaker is located in an out-of-reach location on the phone. You take that external microphone, plug it into a jack on the back of the HL10 and let it hang free making sure it's not resting on any surface. That should eliminate any ringing in your headset.
Good luck from Headsets Direct!
Sep 13, 2011 | Plantronics CS70 Wireless Headset
Dont know how to hook it up to phone...have S10A and S11 model plantronics corded headsets
Turn over the S11 base and insert the headset slot. This is at the top of the base. Remove the handset cord from your telephone base and plug into the handset jack (there will be a picture). Using the short cord that came with the S11, plug into the line jack on the back of your base and the other end into the slot on your telephone where you removed the handset cord. Plug the headset cord into the headset jack that is on your S11 base. Connect the the A/C power adapter to the S11 A/C jack and a wall outlet. Put on the headset. Press the handset/headset switch and pick up the handset off your telephone, set it aside to make calls. Slide the configuration switch (on the side of the S11 base) until you hear a clear dial tone.
Aug 24, 2010 | Plantronics (45647-04) for S10, T10, T20...
I need to know if the vodavi 30 button part number 3015-71 needs a lifter for a headset or not
No. It's a programming item and a code or softkey.
The user connects the modular headset to the handset jack on
the telephone leaving the handset in place. The ON/OFF
button on the Digital Telephone is used to initiate and end calls
while using the headset.
To activate Headset Mode:
Dial [634] on the dial pad,
-or-
Press preprogrammed HEADSET MODE button. LED lights
steady.
To deactivate Headset Mode:
-or-
Press the preprogrammed HEADSET MODE button. LED
extinguishes.
While Headset mode is active, the ON/OFF button
activates the headset and disables speakerphone
and intercom call announce operation at your
station.
To install the headset, see the Installation Manual.
Station must be programmed in database
programming for headset operation before the
flexible button can be programmed.
Carl
Dec 23, 2009 | Vodavi 30-BUTTONVODAV XTS Telephone
Voice breakage
install your original audio drivers and try again another headset with microphone. test the microphone and speaker if properly working.
Aug 14, 2009 | Acer Aspire 3680 Laptop
Magicjack does not recognize my phone
"However the phone option is not available..." Are you sure? you can switch to headset or by phone anytime you want. Switching to either one of these devices you need to right click on your magicJack phone number in the software(located at the top left portion) and click on "switch to phone/telephone".
Feb 08, 2009 | GTech HARD DRIVE, G SPEED eS,4TB W/PCIe...
Can convert a stereo headset to a telephone headset?
hi only if you have some experience on how to add a mic in fact is a electret mike and are very cheap you joust cut one wire to hook the mic and thats set.....as you do this take a especial attention on which wire be the mic and the ear.......so you connect right..................saludos
Nov 18, 2008 | Portacom Porta-Com COM-60FC 6 Headset...
Help
Remote ring detection provides a low tone * triple beep in your wireless headset when you receive an incoming call. This feature requires a handset lifter accessory, such as the Plantronics HL1 or HL10. If you do have a handset lifter but do not hear the remote ring detection, please check the following:
  • Check the placement of the lifter. - Make sure the handset lifter positioned directly over the phone's speaker.
  • Try adjusting the phone's ringer volume. If the phone's ringer is too quiet, it may not trigger the ring detection built into the lifter. Try turning up the ringer volume of your phone.
  • Check the ring tone of the phone. - If your phone's ring tone provides short beeps or plays music, the lifter's microphone may not detect it. Try switching your ring tone to a traditional ring or long beep.
  • Does the phone have different rings? - For example internal calls vs external calls vs transferred calls. Does the phone ring the same for each type of these calls. If so try changing so all calls use the same tone.
  • Attach the optional "external ring detector" cable. This cable plugs into the lifter and provides a small, black microphone. It is included in the plastic bag of lifter accessories. Mount the microphone near your telephone's speaker. Click here for more details.
  • There are 2 versions of the Lifter accessory - HL10 and HL1. The HL1 is a larger older version of the liter with a more sensitive rind detector. Some phones will require the older version of the lifter.
  • Please view the On Line Compatibility Guide to see if the older version (HL1) will be required for your phone.
*Please note the volume of notification beep in the headset cannot be altered, it will always be a low tone triple beep .
Jan 15, 2008 | Plantronics CS50 Wireless Office Headset...
Lands Phones Logo
47 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
