Question about Compaq Keyboard
Key board turning off
The green light under the "1" located in the top right corner of the keyboard (right under where it says "Smart Card Terminal") goes off and on randomly and I hear a "chirping" beep. While the light is off none of the keys function. Is my keyboard dying?
Re: Key board turning off - Compaq Keyboard Keyboards & Mice
Posted on Aug 16, 2008
  • 1,601 Answers
What model do you have?
Posted on Nov 16, 2007
0 characters
3 Points
Not linking to iMac
Press the button on the top right side of the key board, if the green light lights up you have power in the key board. Turn your mouse over and the green light should be on if the mouse has power.
Apr 19, 2015 | Keyboards & Mice
How to use smart card in key board
Smartcards is done in a PKI environment. Meaning, your PC needs to be joined in a Windows 2003 or 2008 server environment that is requiring usually a double key log-in. You would use an ID card sometimes along with a password to log-in to the machine.
Dec 03, 2013 | HP KUS-0133 USB Black Keyboard Smart Card...
How to use smart car in keyboard
go to hp then download the drivers for the smartcard reader on the keyboard
My arrow key fell off my keyboard. the arrow key was located in the lower right had corner of the key board. I recently received it as a gift from my son and daughter in law. I located two of the keys...
You will not find replacement keys for the keyboard, even if you do - they might not be of the same make / color / design... You are better off, getting a new one.
Alternately, you can get an older similar keyboard from ebay / other store and replace just the keys :)
Oct 08, 2013 | Blurex D-lux Leather Case with Keyboard...
How do i print screen using "smart office keyboard
Hi there!
Just press the print screen button located in the upper right of your keyboard. (Prtsc key) and open the paint program (located in accessories folder). Once you open a new file, paste it from there or press ctrl key+ V key to paste. And then you can print it or save it to your computer.
This should solve your problem.
Feb 05, 2011 | EzKey EZ7000 Smart Office Keyboard PS2
My asus g73jh backlight will not turn on, it only turns on during reboot. How can i get it to turn on
If you're having trouble with the keyboard lights, hold the Fn key (right next to the left ctrl key) and press F4 to get the keyboard turned on. There is also the button at the top left corner that turns lights off.
Sep 04, 2010 | ASUS Keyboards & Mice
Mouse no longer cut and pasting.
make sur the "numlock" key is not locked. (top left corner key)
go to start>>control panel>> accessibility optons. make sure all of th echeck box under the keyboard tab and no check mark in them.
Jan 27, 2009 | Gateway 2520915 Keyboard
Green keys on bilingual (EN FR) keyboard
Finally I figured it out. Hold the shift control function keys at the same time. This will turn the green key function on and off.
Feb 18, 2008 | Acer NSK8458AN Keyboard
Saitek Eclipse II Lighted Keyboard
Changing the default colour involves a little dis-mantling. remove the screws from the back of the board. Carefully remove the rubber feet inserts too as there are 4 more screws under there. Now remove the top section of the keyboard (the bit with the keys) Lay the board down flat and you will notice where the usb cable comes in a circuit board. this has a connector with 4 wires attached to it on the left hand side. the wires are coloured red, grey, blue and black. Remove the connector and swap over the Blue and Red wires. Re assemble the keyboard after reattaching the connector to the circuit board being VERY careful not to overtighten the screws. Now at boot up the keyboard will by default be red.
Sep 15, 2007 | Saitek Eclipse II
Compaq Keyboard Logo
257 people viewed this question
Top Compaq Keyboards & Mice Experts
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Keyboard and Mice Expert? Answer questions, earn points and help others
