Question about Air Tools & Compressors
We have a Craftsman electric air compressor (6hp, 150psi, 30 gal upright) it will only start up and run 10 seconds then throws the breaker switch. Now that is all it will do, we plug it in, it runs for 10 seconds and then throws the breaker.
    Scholar:
  • 103 Answers
Motor may be getting old and consuming more pwr and exceed power given popping breaker. try another outlet,is chord ok or grounds?
Posted on Jul 14, 2009
Compressor starts innitially,then when pressure gets low it trips breaker when it tries to start back up.20 amp breaker to light switch to compressor is about 2o ft on12-2 wire. tried 30 amp breaker,does...
the start capacitor on the motor body is weak,the motor needs this component to over come the air pressure when cycling to re-build the low air pressure,change both the start and run capacitors when doing the start because the other run capacitor is just as old and it will soon fail
Mar 19, 2011 | Craftsman 33 gal Air Compressor 6 hp...
Problem with the craftsman 30 gal compressor 6 hp vertical oil free. motor or compressor will not engage, when turned motor starts for a second and sound slow then pops the breaker
sounds like you are not getting enough voltage to run the compressor if you are using an extension cord check your manual to see what gauge it should be depending on how long it is if you are plugged into a wall outlet then is the compressor the only thing that is running on the circuit if some thing else is running then you may be overloading the circuit.
Feb 24, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
It will start to run but seam kinda slow and will pop the breaker after 10 seconds. it is a upright 5 hp. ran fine and then not no lead in to the prob.
Make sure the service that you have the compressor plugged into is sufficient to run that big of a motor. ie, a 20 or 30 amp breaker/service.
Aug 23, 2010 | Craftsman Air Tools & Compressors
6hp craftsman air compressor runs to 3 or 4
make sure it is plugged into a 20amp outlet. and do not use an extention cord
Jan 16, 2010 | Craftsman Air Tools & Compressors
6hp, 25 gallon compressor, never cycled back on, blew the breaker. reset the breaker and soon as i flip the compressor it trys to start then blows the breaker right away.
sounds like its the motor drawing too much current,has it got plenty or oil cause they run low and seize up,not the most reliable can be fine but equally can be dramas especially if its from China
Oct 26, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Breaker blows out when starting up compressor
there are a number of possible causes. you really need an amprobe to read the draw as the compressor starts up. Then check the label on the motor. There is also an unloader in the air loop that allows the unit to start up with no air pressure against it. to help you you really need to give alittle more info.
Aug 09, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman compressor runs for 10 sec. and shuts off.
I have a Craftsman 2hp/12 gallon Air compressor that does basicly the same thing, will start, run for about 3 seconds and stop. I replaced the pressure switch but still have the problem. Any suggestions?
Apr 08, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 6hp 150psi 30gal won't keep running
It sounds like the internal circuit breaker in the motor is heating up and then the breaker trips to shut down the motor. This is the protection so you don't have a fire if the motor burns up. The smell you have is the coils in the motor. Sorry to say that you will need a new motor for this unit. I hope this helps out.
Jan 17, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
297 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
