Question about HP LaserJet 3030 All-In-One Printer
I cant send and receive fax with my hp 3030
My hp 3030 wont send and receive fax. the line though is ok but when im trying to send fax it says no dial tone. but before it was working fine. i already restored its factory settings but still it diddnt work out.
ShineMicheal
  • 131 Answers
SOURCE: hplj 3030.. fax set up
Paste the link below in your browser
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=378056&taskId=110
Posted on Jul 16, 2008
  • 81 Answers
SOURCE: No dial tone detected
It may be a bad modem on the copier. Plug your phone into the auxillary phone port on the copier and see if you get a dial tone. Also make sure that your cord from the wall is plugged into the line port and not the phone port.
Posted on Jul 24, 2008
rakeshpramod
  • 234 Answers
SOURCE: Fax will fax or receive fax
If it is a Officejet 6110 All-In-One first run a fax test:
Press Menu/Setup> Press the right arrow key to locate Tools> Press OK> Now press the right arrow key to locate Run Fax Test> and press Ok.
Check to see what has failed and correct what ever has failed in the fax test.
And follow the below mentioned steps to connect the All-In-One according to your setup:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu50333&cc=us&lc=en&dlc=en&product=79477
Good Luck
Posted on Oct 03, 2008
leroyal
  • 2120 Answers
SOURCE: hp 3030 will not send faxes or receive them
Check the phone line with a regular phone.
Plug phone line into the LINE port.
Posted on Feb 02, 2009
leroyal
  • 2120 Answers
SOURCE: No dial tone on fax machine
Yes, all fax machines are analog.
Posted on Mar 03, 2009
Why did my fax machine suddenly stop working?
Check that the memory is not full. Also, make sure a setting like (auto-dial 9 for outside line) is set incorrectly.
May 17, 2015 | Office Equipment & Supplies
Cant send or recieve fax
Might be silly question but is it setup to auto transmit and receive? And have you tried to operate it manually? + take out the inline filter fax machines operate on volume'db' to soft and it can't hear, to loud and it can distort sound.
Dec 28, 2013 | HP Office Equipment & Supplies
I have an HP Lazerjet Model 3030. Recently I have
Here is a link to Hp for your Laserjet 3030. Look under Troubleshooting Fax Codes and Trace Reports. Click on 'Fax send and receive codes'. Scroll down the page to locate each code that you mentioned. I suggest calling your fax number from a cell phone to see if the fax line is clean (doesn't have any noise or static other than the "handshake digital tones") If it does have other NOISE....have the phone company check your fax's phone line for troubles. Let me know.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=378056&prodTypeId=18972&prodSeriesId=378056&objectID=c00062808#A5
Nov 18, 2009 | HP LaserJet 3030 All-In-One Printer
I have two problems with my OfficeJet 6310: 1. The fax screens appear Hebrew. Similary, If I try to use the copier from the printer. This is continuously caused by HP Update 2. I can not send out a...
Use the HP Fax Test
The telephone number for this service is 1-888-HPFaxme (1-888-473-2963). The fax service receives faxes and returns faxes within 5 to 7 minutes to the number contained in the fax header. Solution two: Run a fax diagnostic test
  1. Load plain white paper into the input tray.
  2. Press the Setup button (c01669474.gif ) on the product control panel.
  3. Press the right arrow (c01669475.gif ) to select Tools , and then press OK .
  4. On the Tools menu, press the right arrow (c01669475.gif ) to select Run Fax Test , and then press OK . The fax diagnostic test prints.
Solution three: Check the telephone line and change the HP fax settings Step one: Test the telephone line
  1. Disconnect the telephone cord from the back of the HP fax product.
  2. Figure 1: Two-wire telephone cord c01501963.gif
  3. Pick up the handset of the telephone and check for a dial tone.
  4. On the single-line telephone, dial the fax number of the receiving fax machine.
    • If the receiving fax machine answers the call, continue with the next step.
  5. Hang up the single-line telephone.
  6. Use a second telephone line or a cellular telephone to call the telephone number assigned to the HP fax product.
Step two: Change the HP fax settings
  1. Connect phone line into line 1
  3. Press the right arrow (c01669475.gif ) to select Basic Fax Setup or Advanced Fax Setup , and then press the right arrow (c01669475.gif ) again to change the menu option settings to the settings listed in the following table. Fax menu Fax menu option Setting Basic Fax Setup Rings to Answer 1 or 2 (At least one more ring than a telephone answering machine, if an answering machine is connected.) Advanced Fax Setup Answer Ring Pattern All Rings
  4. Use the HP Fax Test Service to try to send and receive a fax.
If the HP fax product still cannot send or receive a fax, continue to the next solution. Solution four: Check VoIP digital telephone line Using a VoIP telephone service can cause faxing to fail because fax transmissions are sensitive to the timing of the signals used to transmit the fax. If using a VoIP digital line is necessary, changing the Fax Speed Adjustment setting to Medium might improve the ability to send a fax over a VoIP telephone line. Use these steps to change the fax speed adjustment to a lower speed.
  1. Press the Setup button (c01669474.gif ) on the product control panel.
  2. Press the right arrow (c01669475.gif ) to select Advanced Fax Setup , and then press OK .
  3. Press the right arrow (c01669475.gif ) to select Fax Speed , and then press OK .
  4. Press the right arrow (c01669475.gif ) to select Medium , and then press OK .
  5. Use the HP Fax Test Service to try to send and receive a fax
Jul 05, 2009 | Computers & Internet
Cannot send or receive faxes
Use the HP Fax Test
  5. Use the HP Fax Test Service to try to send and receive a fax.
Jun 23, 2009 | HP Officejet 5610 All-In-One InkJet...
I can receive faxes but cannot send them
Check your fax speed settings, also, make sure you get a good clear dial tone on the line. Sometimes it wont send if it detects line noise.
May 01, 2009 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Hp 3030 will not send faxes or receive them
Feb 01, 2009 | HP LaserJet 3030 All-In-One Printer
Hp laserjet 3030 fax
i have hp laserjet 3030. i cannot send or receive fax messages. i have checked with other machines as well. a beep sound is heard and there is no answer. my fax and phone lines are working fine.please help me as early as posible.
Sep 27, 2008 | HP LaserJet 3030 All-In-One Printer
Sending fax error message "low memory"
Try reading these:
General fax problems
Issue Cause Solution The document stops feeding in the middle of faxing. The maximum length of a page that can be loaded is 381 mm (15 inches). Faxing of a longer page stops at 381 mm (15 inches). If no jam exists and less than one minute has elapsed, wait a moment before press Cancel . If a jam exists, remove the media. If the item is too small, it can jam inside the automatic document feeder (ADF).
(HP LaserJet 3015 all-in-one) The minimum paper size for the ADF is 74 x 105 mm (2.9 x 4 inches).
(HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one) The minimum page size for the ADF is 127 x 127 mm (5 x 5 inches). If a jam exists, remove the media. The fax activity logs or fax call reports are printing at inappropriate times. The fax activity log or fax call reports settings are not correct. Print a configuration report and check when the reports print. Set the appropriate log or report printing times through the control panel or the HP Toolbox. The volume for sounds that the device emits is too loud or too soft. The volume setting needs to be adjusted. Set the appropriate sound volume settings through the control panel. Fax send troubleshooting Use the information in the following table to solve problems that might occur when sending faxes: Issue Cause Solution Faxes stop during sending. The fax machine to which the fax is being sent might be malfunctioning. Try sending to another fax machine. The telephone might not be working. Do one of the following:
  • Turn up the volume on the device, and then press Fax/Send on the control panel. If a dial tone is heard, the telephone line is working.
  • Disconnect the device from the jack in the wall, and then connect a telephone to the jack. Try to make a telephone call to make sure that the telephone line is working.
A communication error might be interrupting the fax job. Change the redial-on-communication-error setting to On.
See the electronic User Guide on the CD-ROM that shipped with the product. The device is receiving faxes but is not sending them. If the device is on a PBX system, the PBX system might be generating a dial tone that the device cannot detect. Disable the detect-dial-tone setting.
See the electronic User Guide on the CD-ROM that shipped with the product. A poor telephone connection might exist. Try again later. The fax machine to which the unit is sending to might be malfunctioning. Try sending to another fax machine. The telephone line might not be working. Do one of the following:
Outgoing fax calls continue to be dialed. The device automatically redials a fax number if the redial options are set to On. Press Cancel to stop the redials while the device is dialing.
To cancel a pending fax job, see "Canceling a fax job" in the electronic Users' Guide on the product CD-ROM.
See "Changing the redial settings" in the electronic Users' Guide on the product CD-ROM. Faxes that are sent are not arriving at the receiving fax machine. The receiving fax machine might be off or might have an error condition, such as being out of paper. Call the recipient to make sure that the fax machine is on and ready to receive faxes. The originals might be incorrectly loaded. Make sure that the original documents are correctly loaded into the automatic document feeder (ADF) input tray or flatbed scanner (not available with the HP LaserJet 3015 all-in-one). A fax might be in memory because it is waiting to redial a busy number, other jobs that are ahead of it are waiting to be sent, or the fax is set up for a delayed send. If a fax job is in memory for any of these reasons, an entry for the job appears in the fax log. Print a fax activity log and check the Status column for jobs that show a Pending designation. All of the numbers of a long fax number cannot be dialed. The maximum number of digits of characters that can be entered into a fax number is 50. Try manually dialing the fax number. Faxes that are sent include a block of gray shading at the end of each page. The original may be on the flatbed scanner (HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one only), with the glass-fax size set incorrectly. Make sure the setting is correct. See "Changing the default glass-size setting" in the electronic Users' Guide on the product CD-ROM. Faxes that are sent have data missing from the end of each page. The original may be on the flatbed scanner (HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one only), with the glass-fax size set incorrectly. Make sure the setting is correct. See "Changing the default glass-size setting" in the electronic Users' Guide on the product CD-ROM.
Jul 16, 2008 | HP LaserJet 3030 All-In-One Printer
HP 3030
no, you only have 1 phone(fax) line and it cannot handle 2 calls at the same time.
Jun 25, 2008 | HP LaserJet 3030 All-In-One Printer
HP LaserJet 3030 All-In-One Printer Logo
70 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
