HOW DO I REPLACE PRINTER CARTRIDGES - Office Equipment & Supplies
  • Randy Prevost
    Randy Prevost May 11, 2010
    What is the make and model of your printer?
    Sergeant:
  • 259 Answers
Find the user manul of the printer
Posted on Jul 14, 2009
Epson XP-100 can't get the ink cartridges from docking too soon
Hi
go to 'Printer properties' then 'Maintenance' , click 'Replace cartridge' button and follow the instructions...
Another way is to open the printer lid, wait until the printhead/cartridges are in an accessible location in printer - and disconnect the power cord. Then replace cartridges as needed, plug the power cord back in and turn printer on.
Sep 20, 2014 | Office Equipment & Supplies
Printer ask for cartridges
turn off your printer...then replace new cartidges.after replacing cartridge restart printer...always when you want to change or replace cartridge/Drum/fixing/belt trun off your printer...
Jul 12, 2012 | Lexmark X9575 InkJet Printer
Printer says offline and cartrige light is flashing
Check whether the ink cartridges are properly installed.If installed incorrectly they can cause the printer to go offline.Install them correctly.
Also check whether you're running low on cartridges ink and replace if need be.
Sep 27, 2011 | HP Deskjet 6940 InkJet Printer
Ink Cartridges too far over to replace
Unfortunately you haven't mentioned if your printer is switched on at the time, but if you are changing cartridges your printer should be plugged in & switched on when you open the cover to replace the cartridges.
The printer cartridge carriage should then automatically slide to the center of the printer where the cartridges can easily be removed and replaced.
Thank you for visiting Fixya.
Best wishes,
Graemevm
Mar 25, 2011 | Canon PIXMA MX310 All-In-One Printer
How to replace the ink cartridge
1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
3. Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
4. Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
5. Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
do rate the solution if it helps
Nov 26, 2010 | Lexmark X1240 All-In-One InkJet Printer
Lost my manual, need to change the ink cartridge, help
  3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
  4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
  5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
Apr 24, 2010 | Lexmark C533DN InkJet Printer
My HP Deskjet D4260 printer has been unused for 2 years. I have been told it would be useless to replace dried cartridges, because the inkjets themselves are probably clogged, and therefore the printer is...
That is absolutely not true. The printer you have uses integrated print head cartridges. This means every time you replace the ink cartridges you are replacing the print heads. Throw out the dried up ink cartridges and buy new ones. Your printer takes the HP 74 black and HP 75 color cartridges. There are XL versions of these cartridges that hold more ink and are a better value.
Dec 19, 2009 | HP Deskjet D4260 Printer
I HAVE AN HP PHOTOSMART C6280 ALL-IN-ONE PRINTER BROUGHT OVER FROM THE U.S.A. 3 OF THE INK CARTRIDGES ARE EMPTY AND I HAVE REPLACED THEM, BUT NOT WITH HP INK. THE MESSAGE ON THE SCREEN IS SAYING THE INK...
As the printer was bought in the US the printer is meant to use the #02 cartridges.
When you decided to replace the empty cartridges with refilled ones…the place you took them to be refilled more than likely decided to replace the little chip with a local flavour, which attempt to mimic original HP cartridges #363 (or what ever the number of those cartridges is where you are now). Hence now they are rejected by your printer.
But because the printer is only designed to use #02 cartridges it will reject every other cartridge/chip that do not have an #02 programmed into them….
You could try to call HP and explain them your situation and see if they can help you reset your printer to accept a different cartridge number …
Cheers.
Nov 08, 2009 | HP Office Equipment & Supplies
Replacing empty cartridges
Make sure that the cartridges you installed are compatible for your printer.
Refilling the ink could actually damage the head that is why it is not advisable to refill, this will cost you more money for printer replacement.
Reseating the ink cartridges and rebooting the whole system could do the trick.
But if not, check if ink cartridges are really defective or has dried out so you can fix a return for those lemon.
This way we can identify if you really need to replace the printer instead of jumping into conclusions right away.
Thanks.
Jan 06, 2009 | Lexmark X6100 Flatbed Scanner
176 people viewed this question
jasbo
jasbo
