Question about Dryers
I have a maytag performa electric dryer that's giving out no heat. model# pye2300ayw. what do I do?
  • 234 Answers
Could be three things. 1st) 240v should enter the unit. if 120v is missing then the unit will run but will not heat (on an electric dryer).
2nd) the thermal cut-off is not showing continuity and therefore not allowing voltage to travel to the element. 3rd) could be the element itself not showing continuity.
Posted on Jul 15, 2009
Can I reverse the door swing on my Maytag Performa dryer>
http://www.maytag.com/-[PYE2300AYW]-1109316/PYE2300AYW/
Here is the link to the owners manual. This feature is not mentioned. Look at the molding in the metal case of the front of the dryer. See if there are identical moldings for the door and latch on both sides. If not, no. Only alternative is to get longer connection hoses and swap washer with dryer left to right.
Dec 24, 2014 | Maytag Dryers
My Maytag Performa electric dryer will not start. The Model # is PYE2300AYW, Serial # 10923714ZB. It was working fine but will not turn on now. I have checked the breaker box and it is in the on...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 16, 2011 | Maytag Dryers
Where is the tumbler belt located on a Matag Performa Dryer model # PYE2300AYW?
www.servicematters.com/maytag_library/docs/16023083.pdf
service and repair manual above, everything is in there.
May 13, 2010 | Maytag Performa PAV2200
My Maytag Performa PYE2300AYW keeps running and won't get to hot on low but on Regular it gets too hot
your cycling sensor thermostat is getting defective it will have 1 side a red wire coming off the heat selector switch and the opposite side will be a yellow wire from the safety thermostat connection
Nov 15, 2009 | Maytag PYE2300AY Electric Dryer
My maytag dryer heating element gets hot but motor will not run
Sounds like you have something shorted out.
The element issue could be a contact fused shut.
With both problems I would be looking for wires melted together, or a relay/sequencer welded shut melted etc.
You do have a potential fire hazzard here. If after removing the panel you cannot locate the problem, do not run the unit.
Oct 20, 2009 | Maytag PYE2300AY Electric Dryer
Maytag electric dryer is drying inconsistently.
you may need to check the lint trap and clean it .. also try cleaning out the dryer vent... if this doesnt work , try changing the drine belt...
good luck
Oct 12, 2009 | Dryers
My maytag performa pye2300ayw dryer will start but will not heat up. No matter how long I leave it on, it just won't heat up. what could be the source of the problem? the model number - pye2300ayw rev - 10...
You have a thermal overload switch that may be bad. It is located under the top of the dryer. Check first the breakers. Turn them off and then back on, then check the wiring in the back of the dryer and then the element itself. It may take 30 minutes to do all of this, but it will save you a lot in the long run.
Mar 04, 2009 | Maytag Dryers
MAYTAG PYE2300AYW ELECTRIC DRYER running but no heating
you need to take it apart if you'd like call 417-926-0106 i'll walk you through it Jim
Feb 27, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
167 people viewed this question
Top Dryers Experts
