Question about American Standard "Ceramix" Single Handle Faucet--Polished Brass Finish
Tub fuacet has low pressure - American Standard "Ceramix" Single Handle Faucet--Polished Brass Finish
Check inline filter for blockage.
Posted on Jul 15, 2009
Our water is low pressure and cold. is there a washing machine available that can use low pressure?
Most old style top load washers use a water level sensor, so the water pressure isn't a big deal for them. And the newer ones are more energy efficient.
Aug 11, 2017 | Washing Machines
Water running all the time on wash ciycle
Check the small tube that is connected to the outer wash tub and the pressure switch. When the water flows into the tub pressure is created in the upper half of the tub which causes the pressure switch to turn off the water inlet valve when the required amount of water is present.
Check the tube for debris that prevents the pressure switch operating correctly, if the tube is clear, the pressure switch needs to be checked, replace if faulty.
Low water pressure into the machine can also cause the inlet valve not to close properly, minimum pressure required is 20psi.
Mar 01, 2014 | LG WM-2077C Front Load Washer
Had a LD error and successfully cleared clog in waste water tank. Turned it on and pump worked perfectly to pump out water. Started a new cycle to test everything and things went wrong. First, the tub...
If the water keeps filling with the unit unplugged you have a bad water valve(or low house pressure)
If the unit does stop filling when unplugged you have a plugged pressure hose to the pressure switch or a bad pressure switch. To access you peel back the front emblem to remove a screw in the center. This allows you to raise the top to check the pressure hose. You can also find the end of the hose at the control panel to blow through it, should be clear when tub is empty of water. A hole in the pressure hose would also cause flooding. This hose connects from the bottom of the outer tub to the pressure switch in the console to control the water level in the tub. Unit will not turn on drain pump if it does not sense water in the tub......
good luck......
Apr 06, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have a 2004 great lakes hot tub with a balboa controler. My hot tub heats up fine when the pump runs on high but the temp light never comes on when the pump runs in low.
check to see that the flow switch is working properly, it may not have enough flow on low speed to allow the heater to turn on. Make sure your filter/s is/are clean. If you have a pressure switch instead of a flow switch, it may need to be adjusted or replaced.
Feb 04, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
Shower/Tub Diverter Value Low Water Pressure
I had the same problem. I discovered that an O ring was missing (or I lost it without noticing) from a new diverter that I installed. Just got an O ring that fits on the threaded part of the collar where it meets the pipe. Worked fine. Amazing how a little plastic piece could make such a difference.
Jan 25, 2010 | Eljer Arlington Non-Jetted Acrylic Bath...
Dripping fuact
Seat assembly may need replacing, usually a cartridge style, grease it first......
Jan 04, 2010 | Ultra Max Eden Bath Black Ultra Zen...
No water pressure in bath tub after turning off hot water heater
It could be back flowing into the hot water heater tank which is not full because of the leak. Even though the valve is closed on the cold water entry side, there is probably no valve on the exit side. That is how it is returning to the tank.
Sep 14, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
LOW WATER LEVEL
you cant the water is meter though a pressure switch,,,but heres a trick but you have to find your way from here,,,fill the tub first than push the clothe,,careful of overflow,,if you do it enough you will be a master,,,
Jan 06, 2009 | Frigidaire GLWS1439F Top Load Washer
American Standard "Ceramix" Single Handle Faucet--Polished Brass Finish Logo
82 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
