Question about Apple iPod mini M9160LL/A MP3 Player
Problems with iPod Mini
I have two two main problems. one is playback.when I plug in headphones or dock it into an external speaker set,the sound is very scratchy to the point where it's unlistenable. thisis intermittent, but it happens with multiple headphones and externalspeakers.
the other problem is battery life. itwon't hold a charge, even when unused. I have to keep it plugged inconstantly when not using.
any thoughts on how to fix this?
  • 1,113 Answers
Re: problems with iPod Mini
Headphone sockets on these after a while can become loose at the solder joint on to the board, they develop cracks in the joint making a poor contact, dismantle and resoldering headphone socket terminal is the fix.
As for battery life, it sounds like the battery pack itself is stuffed, there is now fix except to replace battery pack, recharbel nicad batterys do wear out. You could also check that termals on battery and ipod are clean and making a sound secure connection.
Posted on Nov 16, 2007
0 characters
3 Points
Don't how to connect iphone to ear speaker
moz-screenshot-12.pngmoz-screenshot-13.pngmoz-screenshot-14.pngmoz-screenshot-15.png honestytessy.jpgHow to Connect an iPod to a Speaker Bar
A speaker bar is a (usually portable) speaker system that includes a dock for an iPod. The unit is usually bar-shaped, with either a rectangular or cylindrical cross-section. Connecting an iPod to a speaker bar is usually as simple as plugging it in. Many speaker bars will also charge the iPod while it is connected. However some do not have an iPod dock, in which case the iPod must be connected by a 3.5mm audio cable.
Things You'll Need:
* 3.5mm cable (for some speaker bars)
Turn the iPod on. Look to see if the speaker bar has a dock for the iPod. The dock will fit an iPod perfectly and will generally be located in the center of the speaker bar. There will be a connector that resembles the connector on the docking cable that came with the iPod. Place the iPod on the docking station and turn on the speaker bar. Such is the case with the "2.1 Channel Bar Speaker with Dock for iPod" or the "Yamaha YAS-71BL Front Surround Speaker System"
iPod headphones use a 3.5mm audio cable.
Connect the iPod via the 3.5mm cable. If the speaker bar does not have a docking station it will have a 3.5mm cable connector with a jack like the headphone jack on iPod ear pods. Plug the 3.5mm cable in the iPod headphone jack. Plug the other end in the iPod. Turn on the speaker bar. The procedure is straight forward and Apple specifically designed the headphone jack with third party stereos in mind.
Select a song on the iPod and play it. The speaker bar will play the music from the iPod.
Hope that helped..
have a nice day.
Feb 23, 2011 | MP3 & Digital Media Players
Four weeks ago I bought an iPod Touch 32GB. After listening to my iPod on an external speaker I tried using the headphone and the sound is just too low. I thought my headphone was damaged but I tried it on...
Sounds like plugging the external speakers in has damage the spot were the headphones go in. If this is under warranty that bring it to apple store.
Jan 19, 2011 | Apple iPod touch
For some reason my ipod touch won't play when I plug it into my stereo. It is playing out of the ipod itself. How do I turn this off.
This is a very common problem, you may have to get a different jack that works with the headset jack thats on the iPod. iPhones and iPods have a weird style jack on the top that wont allow most headphone or 3.0mm to 3.0mm jacks to go fully inside the jack causing it so there is not connection with the jack itself in the iPod. You can check this by turning the volume up and down using the rocker buttons on the side while you are at the home screen with no music playing and see if it says speaker or headphones when your turn the volume up and down. Speaker means there is no jack connection, headphone means that there should be music playing through the stereo. Thats using the jack.
If your talking about an iHome or other direct plug in stereo specifically for the iPods and iPhones, make sure that the dock is the correct dock for the iPod, and make sure that it is pressed fully down onto the dock. If all that is correct there should be no problem. If the problem still is happening, it may be your stereo. =/ Goodluck! Hope this helps!
Dec 07, 2009 | Apple iPod touch
Cannot play external speakers
Try firmly pressing the iPod into the dock connector. If it works, good. If it doesn't, then your iPod may not have support for the speakers.
Aug 03, 2009 | Apple iPod touch Second Gen (8 GB,...
Ihome won't play ipod, even after resetting ipod I have de same problem. I got an itouch 2nd generation and docked it on a speaker that supports it. It worked fine for two or three hours, but suddenly it...
Welcome to the wonderful world of the iHome frying the Ipod.
Your iHome, has most likely fried the mainboard on your ipod.
to check plug a usb into the ipod and connect to the computer.
if it comes up disconnect the usb and try a headphones in the jack.
if it doesn;t play sound its fried and you will need a new mainboard.
if it does play through the headphone jack, your lucky and keep it off the dock.
I have fixed at least 30 ipods taken out by ihome docks and other docks.
they are terrible for the ipod. Even Apple sells the docks on their website
that shows how much they care about the product.
If this helps leave a vote on fixya
May 11, 2009 | Apple iPod touch
Ipod classic works but no sound
This is common among the 30gb Video iPods. If you play your iPod on a Dock,
such as a iHome or other speaker device, for some reason, they like to take the
Mainboard out. Normally, if it's a headphone jack, the problem will start with
sound only playing on one side of the Headphones.
As a start, you can replace the headphone jack and see if it corrects your problem.
If not, you will need to replace the mainboard in your iPod.
Mar 03, 2009 | Apple iPod classic MP3 Player
IPod MA146LL/A no sound
You should check and see if the headphone jack is broke or not. That sometimes accounts for the reason why sound won't come out.
Go here to see about replacing/fixing a broken headphone jack:
May 10, 2008 | Apple iPod MA446LL/A MP3 Player
scince i fixed a laptop before, i might help.clen your hands and ipod, open VERY carefully and buy a new phone jack and computer/ac input parts. but befopre you do that, just make sure the wires are connected firmly and the negative is connected to negative and positive to positive(black is with black and redis with red
Jan 24, 2008 | Apple iPod MA446LL/A MP3 Player
Problem with external speakers
need new bf.
are you sure you push the jack all the way down?
Jan 04, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod nano
The dock connectors on most of the speaker systems available are cheap and break easily. I have experienced the same problems. if the ipod doesn't sit just right then it doesn't connect. why they seem to charge but not send music signals i'm not sure. highly unlikely that it's your ipod. either buy a good speaker dock (klipsch, bose, sonic impact... check amazon or e-bay for good deals) or use the headphone jack to connect to the speaker dock you have, and use the wall charger to supply power/charge your ipod.
Feb 19, 2007 | Apple iPod nano
Apple iPod mini M9160LL/A MP3 Player Logo
52 people viewed this question
Top Apple MP3 & Digital Media Players Experts
 Mike M
Mike M
Ron Dufek
Ron Dufek
Raisin Brann
Level 1 Expert
Are you an Apple MP3 and Digital Media Player Expert? Answer questions, earn points and help others
