make sure the supply water is turned on under your sink or behind the refrig. also it helps to turn on you i/m by lowering the arm or turning the switch to the on position.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for GE Profile? PCF25PGW Side by
Water is leaking in the front of refrigerator only when the water valve in the supply line is turned...
(More)
Water is leaking in the front of refrigerator only when the water valve in the supply line is turned on. the leak is in the line that goes in the door. is there any way to replace this plastic line
when you press the valve the water comes out in a full stream for about 3 seconds and then goes to a...
(More)
when you press the valve the water comes out in a full stream for about 3 seconds and then goes to a dribble wait a couple of minutes and it does the same thing again. need the part number of the valve and also how do you get the water lines out of the valve? i pull on them but couldn't get them out. looks like they were just pushed in.
