Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Ge spectra gas stove top not lighting
I have a GE Profile Spetra Gas oven/range that I inherited when I bought my house. I believe the stove was bought sometime in 2000. I can get the model if needed. When I tried to light the stove top the igniters click but the gas wouldn't flow right away. Initially it probably took 2-3 minutes to light. Then the problem started getting worse over time and now it probably takes 20 minutes to a half hour before the gas flows. Any ideas what would cause this? It's a natural gas stove and all the other natural gas appliances (fireplace, dryer) seem to work fine.
have 5 year old GE Profile on natural gas. When you turn on left knobs the right igniters click and the stove does not light. When you turn on the right knobs the right burners ignite properly. The left burners will light with a match!
  • 5 more comments
  • Anonymous Nov 21, 2007
    My right front and left rear burners lite, no problem. The right rear lites occasionally and the left front only fires the igniter system, it click but does not lite. I am getting plenty of gas just no spark where It needs to be.
  • Anonymous Jul 09, 2008
    Have a jenn air gas stove top and the burners work sometimes.. i can
    hear the ignitor but they only come on occasionally..
    Left front burner will not automatically light. The ignition clicks, gas comes out, but will not ignite. Problem just started today.
  • lilmomma5 Sep 03, 2008
    when I turn the right nobs the left one clicks, same with the left. I also am getting no flame. I tried manually lighting them, but no luck, seems like no gas is flowing through the line, but my oven is working fine. Can anyone give me any help
  • Anonymous Mar 12, 2014
    I have a viking VGIS4806GDSS stove that two of the gas burner igniters are not working. On this model when you turn on any of the gas burners they all should spark but now the two on the left side do not. The griddle and the two ovens seem to be working properly. Can you help me find the problem and describe how to change the defective part?
  • Anonymous Mar 14, 2014
    stove was not in use, and when i came in house igniters were clicking away, everything was off. the gfi for outlets finally kicked off. Not until i unplugged stove did gfi come back on
  • Anonymous Mar 30, 2014
    We have just bought a jayco van which is fitted with a 3 gas burner cooktop and a small grill type stove.how do I light it is there any secret in lighting thr top burners
  • 213 Answers
No gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Posted on Nov 21, 2007
Xl44 GE GAS RANGE OVEN WONT WORK, RED LIGHT IN
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
czvb
May 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas stove oven wont turn on
Put a new iginiter for the oven on your stove.
Mar 03, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 gas range, oven dial doesn't have "lite"?
Set the oven for the desired temperature. It will cycle on and off at that temperature.
It will lite automatically.
Feb 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra gas oven, stove works, but oven does not
the ignitor is bad. replace the ignitor and it will work perfect.
Feb 13, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
There is nothing fancy about how the gas controls work on this unit. Do all burners give you the same problem? If so, it could be a kinked service hose or a service valve that has been partly shut. If it is limited to a single burner or two, the valve may be gummed up and should be replaced.
Nov 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra oven not lighting
you need a new oven ignitor for bake if its a gas stove..
May 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
996 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
