Question about LG LRBN20510WW Bottom Freezer Refrigerator
MY ICE MAKER FEELER ARM IS STUCK IN THE UP POSITION. CAN YOU PLEASE TELL ME HOW I CAN FIX THIS? MODEL LFX25950SB LG REFRIG
Water is getting into the area where the arm pivots and freezing. This prevents the arm from dropping down when it should. I use a hair dryer to melt the ice in the area of where the arms comes out of the base. As soon as the arm drops, the ice maker will make more ice. This LG in the door icemaker is junk.
Posted on Oct 22, 2011
  • Chris Wynters
    Chris Wynters Jan 09, 2018
    I used the hairdryer trick on an Amana side by side fridge. Just held the hairdryer on the near side of the wire. After 2 mins it just dropped down. Nice.
The feeler arm is stuck in the up position on my frigidaire gallery refridgerator's ice maker
Hello;
My name is Peter. I am a retired field service appliance technician.
You have not given me any detailed in formation such as your model number to help you. You model number is on a label on the side wall near the top, in your fresh food section.
The one leg of your lever arm goes into the front part of the motor module, which is in the front of your ice maker. The arm is interlocked with plastic gear components one or more of these components are broke.
I am guessing if the following ice maker is what you have.
25314741-li150hslu5ucqppqaoc0zevv-5-0.jpg 25314741-li150hslu5ucqppqaoc0zevv-5-3.jpg 25314741-li150hslu5ucqppqaoc0zevv-5-8.jpg 25314741-li150hslu5ucqppqaoc0zevv-5-15.jpg
Dec 09, 2014 | Frigidaire Refrigerators
How do I get the ice maker to produce for the first time
Is the arm that gets pushed up by the ice cubes (in order to stop making ice when it is full) in the down position? it is able to be pushed up and locked so that the icemaker doesn't make at ice and may need to be pushed down.
Aug 27, 2014 | Maytag MSD2454G Side by Side Refrigerator
LG LRSC 26920tt won't make ice
In order to determine the problem you must check a few things:
1) Is there water in the ice tray? If not. verify the saddle valve is turned on, check the connection on the water valve, verify that there are no kinks in the inlet hose, and check he water filter to see if it is clogged.
2) Is the temperature correct? Make sure the fans are working properly and air is flowing. Verify the the frig and freezer are at the correct temperature and make sure the ice maker compartment door is sealing shut.
If these things check out ok, run an ice maker test. Make sure the ejector arm and feeler arm are in their original positions before beginning. If they are not:
1. Turn off icemaker and wait 5sec.
2. Turn on icemaker.
3. Wait until feeler arm and ejector are back to original positions.
To begin the icemaker test: Press and hold the test button on the icemaker for 5 seconds. If the LED, feeler arm and or ejector does not return to to their original positions the problem is with the ice maker.
The ice maker part number for your model is 5989JA0002G
Oct 14, 2013 | LG LRSC-26922 Side by Side Refrigerator
Need to know how to turn on ice maker in whirlpool gz25fsrxyy2
Should be a wire feeler arm that runs front to back on that icemaker. If it is stuck in the up position---the icemaker is OFF. It should be hanging downward to be in the ON position. If up---just gentley pull it down until it is moving freely. As the ice bin fill with cubes that arm should move up and down with the icemaker. Once the cube level is high enough for the feeler arm to be held in the up position it will stop making ice until you use enough cubes for the arm to fall again.
Sep 26, 2012 | Whirlpool White Gold 25 cu. ft. ENERGY...
Kenmore 795.5102 will not make ice
The problem is the ice maker, the modular head of the ice maker has broken, hence the clicking sound and the raised arm stuck up. You will need to have an accurate model number and contact a local parts distributor for a new ice maker. It is a simple repair usually only 2-3 screws.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 25, 2012 | Kenmore Side by Side Refrigerator
LG Refrig ice maker on model LSC27950 overflow bar i think is stuck in one position because it made to much ice and jammed it up. now no ice is being produced
you lift the bar up to shut the ice maker off . or the ice fills and shuts the ice maker off . simply push the bar back down to star the ice maker in operating again
please rate solution thanks
Oct 19, 2008 | Refrigerators
Faulty ice maker
Hello. Yes, that is the correct position for the icemaker feeler arm. The updated icemaker has a longer feeler arm that hangs down a little more (thereby shutting off sooner when the ice piles up not so high).
Your water leak onto your food is from water spilling out of the front left corner of the ice tray during fill. This has also been updated with a plastic lip that keeps the water from sloshing out when filling up.
The photo shows that your ice tray appears to be unlevel and drooping in the front left corner. This happens with flex tray icemakers over time. The icetray does not fully flex back to its level posiiton. I do not feel you need to replace the entire icemaker. Repalcing just the ice tray should fix your issue.
Hope this helps, please rate my solution.
Jul 01, 2008 | LG LRSC-26922 Side by Side Refrigerator
Icemaker not making ice - feeler arm in up position
You may have a broken icemaker and needs to be replaced.  The internal parts are solid state electronics and they can break.
Jun 18, 2008 | LG LFX25960ST Stainless Steel French Door...
Inoperative Ice Maker
The icemaker stops working because excessive water gets into the control box(where circuit board is housed) through the shaft hole of "finger" and freezes the wheels to turn the "ice-bucket-full detector rod". This stops to send the signal to open water valve.
To fix, remove the icemaker from the wall (need remove two screws - make sure power switch is OFF) and carefully separate the snap-on cable (retangular shape) and a ground cable on the bottom side of the icemaker. (Now you can remove the icemaker out of the refrigerator).
You can open the contol box (need unscrew one and carefully prop it open using a screw driver or a knife. You can unplug color corded snap-on cables for easiness to work (very simple).
You will see ice formed around the plastic gear wheel controlling the "ice-bucket-full detector rod". Remove all ice and dry all the parts in the box and put them back. Make sure all the cable are back to the matching color receptable(only fits in the right place). Connect the cable(rectangular shape) and connect the ground cable. Mount the incemaker on the wall using two screws you removed at first.
Turn the power ON and reset the system by press down the ice cube size selector until the "fingers" make a full cycle. You will see the metal rod moves up and down as system resets. During this cycle the water will be filled into the icemaker.
I believe this icemaker has a design flaw but it's very simple to correct the problem you are experiencing. You do not need much electronic or mechanical knowlege to fix this.
Best wishes
Young
Jun 15, 2007 | LG LFX25960ST Stainless Steel French Door...
LG LRBN20510WW Bottom Freezer Refrigerator Logo
3,464 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
