Question about Dryers
The Belt Tensioner came off of my Whirlpool WED5300SQ0. How do I put it and the belt back on, so that my dryer works?
    President:
  • 1,136 Answers
Hi, Here are the instruction to get to the idler pulley. UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. The drum should hang right there. The idle pulley bracket will fit into the slots located in front of the motor. I will send you a picture after I give you this info.
If I can assist you further, please let me know.
Thanks
Vic
Posted on Jul 14, 2009
  • Victor
    Victor Jul 14, 2009
    Here is the picture. I hope it helps you.
    Vic
Dryer makes loud grinding noise when you cut it on
The dryers drum runs off a belt as you may know to spin it around to dry clothes. This belt is attached to a belt tensioner also to keep the belt snug. This tensioner has a roller with a bearing in the middle of it. Most bearings are made of brass and wear out causing it to grind
I would replace the belt & tensioner pulley as a unit. Sears will have these two parts selling together as a kit. Go online to view with your make and model number to see
May 31, 2010 | Whirlpool LER4634J Electric Dryer
Need to replace drum belt
Most dryers have a tensioner pulley that the belt needs to go around to keep it tight. The belt goes around the motor pulley and the drum, but it goes around the tensioner pulley in a way that would keep it tight (you also need to release the tension on the tensioner to get the belt around it) If there's not a tensioner pulley there has to be some other means of putting tension on that belt, look around the the other pulleys that the belt goes around.
May 07, 2010 | Whirlpool 6.5 Cu. Ft. Super Capacity Gas...
Belt and tensioner issues on a Whirlpool LEB6300LWO have a new belt the tensioner was just laying in the bottom of the compartment think i know where it goes but doesn't add up cause you cant just cut the...
Hi, I wouldn't say you are way off, unless your expectations are way hi. Most average joe's or jane's don't work on dryer's everyday, so some reason needs to be considered. I'm currently on my iphone and not my home computer so I can't attach an illustration to guide you on how to thread the belt through the pulley/idler however, if you go to youtube and type in whirlpool dryer belt repair it should yield you many helpful videos on "how to" just what you need. Hope you found this info helpful and if so please rate it's helpfulness or leave a testimony...or both. Thank you for coming to "fixya" for your repair tips. Let me know if I can assist you further, and good luck. Macmarkus :)
Mar 15, 2010 | Whirlpool Dryers
How do I use idler tensioner for belt on dryer drum?
http://www.applianceaid.com/images/threadbelt2.jpg
Sep 04, 2009 | Whirlpool LER4634J Electric Dryer
Belt came off tensioner, and tensioner off unit.
Here is the tensioner diagram you need, for most any dryer.
http://www.applianceaid.com/images/belt-config.JPG
First clean and lubricate the axel of the wheel with some spray silicone. Try not to get it on the wheel outer surface.
Then locate the slot in the bottom of the cabinet floor. The wheel should line up with the drive wheel at the end of the motor shaft.
Place the tang of the tensioner in the slot.
Press the wheel wayyy back passing a loop of the belt BELOW the tensioner wheel and loop it over the end of the small drive wheel.
Release tension on the tensioner and the wheel will pull it taught.
Aug 13, 2009 | Whirlpool Dryers
The Belt Tensioner came off of my Whirlpool WED5300SQ0 Dryer
If the belt slipped off, this will cause the idler pulley to come loose. This is normal with no tension on the pulley to hold it in place. To re-install, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H. If you still have questions, please let me know. I hope this helps you.
Jul 14, 2009 | Dryers
Put dryer belt on maytag dryer
generic maytag dryer belt replacement
type 1:older models by Maytag with lintscreen under door
  • unplug dryer
  • remove 2 screws from under front panel
  • tilt front panel up from the bottom and unclip top
  • remove door switch wires
  • set front panel aside
  • remove front drum retainer 2 screws each side
type 2:newer models by whirlpool lint screen in top cover
  • unplug dryer
  • remove lint screen
  • remove 2 screws under lint screen
  • with putty knife or other blunt blade
    unclip spring clips at front corners of top panel
  • remove 1 screw each side of front panel 1/2 way from top
  • remopve door switch wires
  • tilt front panel down and unclip
all
  • withdraw drum forward
  • examine drum rollers for wear
    if worn or locked replace in pairs
  • examine felts and nylon glides(if fitted) for wear
    if worn replace
  • examin case floor for tensioner
    (sometimes broken belt ends pull the tensioner out of place its easy to see the slots on the case floor for the 2 feet and spring, looks like a power socket)
  • loop new belt around drum at wear mark of old belt
  • insert drum
  • loop belt around motor pulley
  • pull tensioner to end of travel against spring
  • loop belt around tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
Oct 29, 2008 | Maytag Dryers
LER6636PW0 drum does not turn
hi fakestar,
here is an exploded view of the dyer, and you can see where the pulley came off.8dd05ba.gifpart number 24 are the pulleys.
another picture is for the belt and the tensioner
1e696ba.gifpart number 53 is the tensioner and part number 56 is the belt.
it just tricky on how to put the belt.
first put the pulley back to its location then slowly insert the drum to the dryer while putting the belt around the drum with the grouve of the belt facing the drum.
have a helper hold unto the drum , in place, then lean underneath towards the motor and put the tensioner to its slot at the flooring, just like in the drawing, then insert part of the belt under the pulley of the tensioner then with your left hand, hold the tensioner pulley and with your right hand, grab the belt which you inserted under the pulley, and bend the tensioner towards the right with your left hand while the right hand is pulling the belt towards the motor until the belt loops to the motor's pulley.
i hope i was able to explain that one.
that is really tricky to put on.
tnx 4 using fixya,
drcool
Oct 10, 2008 | Whirlpool LER5636P Electric Dryer
Fitting the belt to the hoover 5050ed
nope,, but
all dryers are generically the same
remove the front panel and door
pull the drum
loop the belt around the drum, at apporximately the wear marks of the old belt
reinsert the drum
loop the belt around the motor pulley
pull the tensioner pulley hard against the spring to the end of its travel
loop the belt around the tensioner pulley
allow the tensioner to move back under spring pressure to tension the belt
rotate the drum by hand to make sure the belt is aligned and not coing to jump off the pulleys
reinstall front panel & door
26740a0.jpg the tensioner may be on the bottom belt run pusshing up, or the top run pulling down
breaking belts sometimes pull the tensioner out of its mounts, there is only one place that the tensioner will reinstall.
Its a standard whirpool dryer, rebadged as hoover, so the local parts guy has the belts rollers felts and glides as necessary, they are common to all the dryers whirlpool makes.
Oct 01, 2008 | Whirlpool LER4634J Electric Dryer
Drum won't turn
it came off the tensioner or it is broke. pull the belt and see if it is not broke. if it is still loose around the drum, then it just came off the tensioner.
look at the manual on how to put back the belt with the tensioner.
tnx 4 using fixya,
drcool
Sep 16, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
56 people viewed this question
Top Dryers Experts
