Question about Raymarine A65 Combo GPS Chartplotter/Fishfinder
Raymarine A65 My A65 intermittantly freezes on the sonar side when the engine is started.  ferrites have been fitted.
  • Seawatch Dec 28, 2007
    Thanks for the info, however, I have tried operating the system by utilising a stand-alone battery which was connected only to the GPS system but the problem still persists. I have not heard of the Newmar device or similar. I am UK based and I am guessing that you are US, that being the case, I will trawl the internet to see what I can find.
    I am most grateful for taking the time to come up with a suggestion, at least it does give me a possible way forward.
    I can be contacted direct on
  • 16 Answers
When the engine starts, there is a voltage drop as the starters crank, followed by a power surge as the alternators kick in and the voltage comes back up.
Ferrites are only there to prevent RF (Radio Wave) interference from other onboard devices.
You should either:
-add an isolated battery to the boat to service only your electronics. That way it is unaffected by the starters.
-There are several devices on the market like Newmar Power's "Start-Gurad" that automatically switch electronics to backup power during engine start. They work great and the electronics don't skip a beat.
Posted on Dec 28, 2007
When i tun on my raymarine a65 ,i get gray and white lightly shaded vertical lines. what is the problem
Check cable connections, reseat all at both ends(so say the book) Now disconnect all cables, CAREFULLY open the housing, visually check internally.Perform as a surgeon would do, reseat all connections(flex cable,wiring,IC's,& the liquid crystal LCD display) clean as necessary with electronic spray cleaner & red eraser. Reassemble. Reconnect. Good Luck.(definition of 'reseat'- unplug or move unit in socket to reconnect the components leads)
Nov 02, 2015 | Raymarine A65 Chartplotter Fishfinder...
How do I get water depths displayed on my C70
You haven't said if you have a DSM fitted ( sonar unit and tranducer) the C70 is only a multifunction display unit MFDU you then put a card in for navigation, a radar aerial/ scanner or a sonar unit for depth and fish finding .
if you have a sonar unit and it's working then
press Presentation
press Depth Digit and select on / off
press OK or cancel to return to the default display
hope this helps
Aug 28, 2014 | Raymarine C70 Multifunction Navigation...
Hello! Our Raymarine A65 will not start up. It starts a boot process but does not show "Raymarine A65" on the display and no chart is displayed as it usually does. Regards Odd
Probably a bad printed circuit board, just had to send mine in to have it repaired. When I hit the power button, I did hear a beep, but then nothing displayed. Mine was still under warrenty, so don't know the repair cost if yours is not.
Jul 15, 2009 | Raymarine A65 Combo GPS...
A-65 screen has fine scratches/clouds
My Raymarine A65 was so bad in daylight I could not read the screen. Used Never Dull polish from ACE hardware, similar to Brasso, and it took every scratch and cloudy mark off the screen. The can documentation includes glass as one of the items it?s safe to use on. Looks new again, Good Luck, Paul
Apr 08, 2009 | Raymarine A65 Combo GPS...
Hi, my name is adam and i would love to graciously help you. In your description you stated you need a wiring kit. I have a link included from ebay and you can go on there and hopefully find what you need.
Jan 09, 2009 | Garmin 340c Fish Finder Dual Frequency...
Instructions for ds400x
A full manual can be downloaded from here :-
however this sort of thing is very simple to find in Google, i am not being facetious , simply trying to point out you may have had an answer to your problem quicker had you not bothered to post here but Googled the same sentence you wrote on this site.
Hope this manual helps.... good luck Fishing!
Oct 26, 2008 | Raymarine A65 Combo GPS...
A65 Raymarine combo gps plotter fishfinder
your local marina should be able to tell you and they most likely are a dealer for seadog or diversified which will sell your parts just give them your model or just take the unit in with you
Oct 16, 2008 | Garmin 340c Fish Finder Dual Frequency...
No depth reading while on plane.
Depending on your transducer type, you may have a liquid filled type that simply needs refilling. If this is the case check for leaks and get it redone. If not it could be transducer placement or cavitation under the hull.
Jun 18, 2008 | Raymarine A65 Combo GPS...
Raymarine A-65 unable to find satalites
If you have a loose RS12 try moving it around the deck and see if it make a diffrence.There might be something knocking it out.
If it is doing a cold start it cold take up to 10 min to get a fix. Once it has a fix it will aquire the next time much quicker.RS12's are mostly rock solid and get great fixes.
Also set the time up on the A65 to what you are at ,IE, universal time minus 5 if you are on the east coast of the US.Time set up is under the units menu. Hope this helps
May 17, 2008 | Raymarine A65 Combo GPS...
Was the engine running when it shut off? How was the voltage at the time it failed? The A65 will shut down if the voltage drops below 11.2 volts.
Another common cause would be corrosion on the plug where it plugs into the back of the display, or the terminal connectors that attach it to the boat's power supply.
It could also be a bad crimp on the terminal connectors. Make sure connectors are the right size for the wire and that they are marine grade, such as Ancor brand connectors. I also recommend heat shrink style connectors,
I have not heard of any software issues for that model so I am betting it's a wiring issue. However, there is an update available from Raymarine. There were changes made to the WAAS satellites and the update helps it recognize the new satellites. You can download it for free from Raymarine. Copy it onto a blank CF card and plug it into the card slot on your GPS. When you turn the unit on it will prompt you on how to proceed with the update. It will fix any known software gliches at the same time.
I hope this answer helps. Please reply if you have any questions about my response.
Feb 25, 2008 | Raymarine A65 Combo GPS...
Raymarine A65 Combo GPS Chartplotter/Fishfinder Logo
271 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
