Visonik 10" 500-Watt Single Bandpass Subwoofer Enclosure Car Speaker Logo
Posted on Jul 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does it sound hot cool and bad *** - Visonik 10" 500-Watt Single Bandpass Subwoofer Enclosure Car Speaker
Anonymous
Level 3:
  • Master 655 Answers
  • Posted on Jul 14, 2009
Anonymous
Master
Level 3:
Answers
655
Questions
0
Helped
314116
Points
2081
Hello dylanholick,
Visonik is somewhat low-end car audio and band pass enclosures in general usually produce rather muddy and boomy bass. It will probably sound "bad", but not hot, and not cool.
If you aim is a good self-contained system with amp, sub and enclosure all in one, why not consider an Infinity Basslink, MTX Thunderlink, or perhaps a Bazooka. They're all available at www.crutchfield.com for little more than you'll pay for the Visonik and any of them will definitely sound better.
Hope this helps.
Engine is hot and the cooling fan are working
sounds like thermostat not workin right or BLOCK OR THE HEADS problems right away HOT ?Sounds Bad Let Me Know Get It tested For Pressure right Away Please So YA Know What,s Up with it
Runs fine until it gets warm or hot then cuts off then cools and will recrank
Does it crank over when the engine is hot. If it does sounds like your maybe loosing fuel if so check fuel pressure if t is good check for spark could be a bad crank sensor or bad distributor.
I have a kenmore dry that seems to hum very load once it heats up. If you turn it off and rest for 30 minutes it will sound fine again until it is 15 minutes into the cycle. What would be the likely...
Hello Bill,
Sorry to be the bearer of bad news,but what your describing sounds exactly what a bad motor will do...run whiles is realitivly cool,cut off when hot the restart after a cool down period and run for a while till hot again.
GENE
4answers
Buick running hot and cutting off.cools and runs good until it cuts off again. get red hot underneath the car
may want to have the convertor back pressure tested. sounds as if the honey comb in the convertor is breaking apart and has clogged it up.
3answers
When i am ueing the lop top it get hot and shut down i have to wait antill it cool down before it start up again
it sounds like your cooling fan has stopped working therefore the cpu is getting too hot to work and will shut the system down have the cooling fan looked at
Even thuogh I made sure it was not on economy mode my hot tub will not heat up and the message board keeps flashing the word cool, do you know what could cause this?
it may be a bad temperature sensor or a bad heating element. Sounds more like a heating element. The cool should just be a warning or depending on the model, could mean that it thinks the water is too hot and is in "cool" mode trying to cool the water. Have the temp sensor and the heating element checked.
2answers
SOUND AND PIC GOES OUT FOR 30 SECONDS, THEN PIC COMES BACK THEN SOUND. IS THIS THE LAMP OR THERMAL FUSE OR WHAT.
The lamp is going bad. If it was the thermal fuse it would not be intermittent. It is very common for some Sony sets like yours to do exactly what you describe when the lamp is going bad.
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
Top Visonik Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
