Question about Whirlpool Freezers
Loud noise from fan under freezer side. Fan seems to get off balance then lows down and speeds back up.
  • 52 Answers
Oil it
Posted on Jul 14, 2009
Samsung refrigerator loud noise
if the fan is still running when you open the door , the I would be leaving that idea as a last resort
try this
get 2 taper door chocks and put one either side at the back of the fridge
push the cabinet sideways and slip one chock in a bit then do the other side
many noises are from the bottom plate that the compressor is mounted on from tapping on the floor and lifting it a bit stops the noise
the same as when you open the door the pressure on that plate is removed and so it stops hitting the floor
Nov 04, 2015 | Samsung RS261MDWP - 26 cu. ft. Side by...
Where is the evaporator fan motor? My Freezer and fridge would quit cooling/freezing. I took the back panel off in the freezer a week ago and the evaporator coils were completely frozen over with ice. I...
I do not believe the problem is the fan. sounds like the frig. is low on Freon this is what will cause the ice build up. you need to find the leak, you can do this by spraying soapy water on coil tubes & watch for bubbles. repair leak & recharge.
May 25, 2015 | Samsung RS261MDBP Side by Side...
Upright whirlpool freezer make loud noise when it comes on
This noise is the fan motor going bad because a bearing is worn out. You need to replace the fan motor before the compressor goes out.
Aug 28, 2014 | Whirlpool 19.6 cu. ft. Upright Freezer...
Miele freezer The fan on my standalone Miele
Hello David Riome,
Why are you discovering a FACTORY ASSEMBLY
does not fit ...??
(just be sure... KITCHENAID was one of my worst).
and keep in mind...
ALUMINUM only bends a very few times before
it breaks (soft, brittle & very difficult to repair).
((protect it)).
The FAN must be free of all obstructions to function.
If it is out of balance, worn or broken in ANY WAY...
REPLACE IT...
Make sure all wires and lines are ABSOLUTELY
NOT in contact with the fan bracket...
(secured out of the way).
Most of these newer units have aluminum evaporators
and a FAN BRACKET will easily wear a HOLE in
your REFRIGERANT LINES.
Like a saw... It may take a couple of years but
sure as winter follows autumn... $$$$$ damage
from conflicted refrigerant lines.
Move the wires and lines away from the FAN.
Carnac the Magnificent
May 13, 2017 | Miele Freezers
Freezer makes really loud noise
You need someone to check the fans and where the noise is coming from before the repair cost you a lot of money because of damage it can cause. The fan may be hitting ice in the freezer or out of balance because it is worn out. No one can hear what you hear and someone will need to be there to check these things out, Sea Breeze
Jun 10, 2013 | Frigidaire Freezers
It makes a very loud noise most of the time
First determine if the noise is from inside or outside of the freezer. If it is louder inside, and you have a frost free freezer, it is usally your evaporator fan motor. If the noise is behind and underneath you unit, then you need to pull the backing plate off, if it has one and determine if the noise is coming from the condensor fan motor, ( if it has one), or from the compressor itself. It usually is compressor and is definitely not worth repairing unless it is under a 5 year sealed system warrantee. Good Luck
Dec 10, 2009 | Hoover Freezers
Loud buzzing noise doesnt stop freezer is still working everything still frozen, just loud noise coming from back bottom of freezer where the parts are, and compressor is very hot to the touch. freezer is...
Locate what is making the noise. There is a fan in the freezer behind the rear cover inside. There is a fan underneath accessed from the rear behind the cardboard backing. The compressor is also there with a starter/overload relay which could make the noise.
Aug 20, 2009 | Frigidaire 20.6 cu. ft. Upright Freezer...
Frigidaire Chest 5 cu ft Making Fan noise & will not turn on...6 yrs old.
at 6 years old it certainly aint new!
from what you describe, sounds like a compressor fault
Oct 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Liebherr CNES 666 freezer - loud fan (?) noise
AbiH, the likelihood of frost inside the fan housing is high. You should manually defrost the unit. Unplug and use a hair dryer to melt as much water as possible. Be aware that hair dryers and water do not mix well! If it happens again, you may have low gas and require a service person.
May 26, 2008 | Freezers
Freezers Logo
64 people viewed this question
Top Whirlpool Freezers Experts
christian nielsen
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
