Question about Palm Treo 500 Centro
Ringer it set ot high but it there is no sound
I had the same problem, called Palm and they told me to do a hard reset. Be sure to Hotsync first or you will lose all your media and contacts. To perform a hard reset you must press and hold the red power button, remove the battery (still holding the red power button) wait a few seconds and re insert the battery, wait for the phone to boot back up then you may release the red power button. I tried this and had no luck but that is what Palm suggested. In the end Sprint is sending me a replacement phone for no charge. Hope this helps.
Posted on Jul 15, 2009
Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
My LG220C ringer volume starts at about 0 and slowly increases in volume as you wait. With the Speaker "on" it starts with a loud ring. What needs to be changed to start the ringer volume at my high...
i BELIEVE there is a setting I think in either your ringer volume or in your sounds or tones (sorry I cant be more specific but its been a ling time since I had a phone that even came with that option) that will give an option of ascending ring which it sounds like to me it is set to this you need to change that
Oct 18, 2010 | LG Cell Phones
My problem is ringer volume i cant when someone is calling
Hi, when a phone has a ringer volume problem, is either the ringer of the phone is weak and you can't hear when someone calls you or the volume of the ringer is yet at a very low level in sound.
You will need to check the volume settings of the phone if the volume is low so you can increase it to a high level.
If the setting of the volume is high, that means the ringer that a makes you hear when people call is weak and will need to be replaced.
Any further question or comment, you can pass it on as comment.
Take care.
Oct 14, 2010 | RIM BlackBerry Bold 9000 Smartphone
My mobile Nokia 6300 call sound is very low
First Option:
You Go to Phone Settings and In the Sound Setting and Set the High Volume IF Volume Setting Ok But Sound very Low
So
Secend Option:
Your Phone Ringer Default So Please change Ringer
And High Sond Will Solved
Aug 24, 2010 | Nokia 6300 Cell Phone
My phone doesn't ring to maximum volume, its too low.
Welcome to FixYa
Dear User,
You can Adjust your Ringer Level to High...If your Ringer is in Full Volume and No Sound/Bad Sound-the Problem is with Buzzer or Board Complaint[Board complaint in Rare Case]
Ringer Option in 6300:
  • Settings
  • Profile
  • General
  • 'Personalise'
  • 'Incoming Call alert'[Must be in RINGING]
  • Move to Bottom 'RINGING VOLUME'[move to Right side-now you can Hear Sound-Set to High Level or as you Like
  • It may ask for Confirm Selection of high Ring Vol
  • Alert For 'ALL CALLS'[at Bottom]
  • 'Save' Click
  • Then Activate GENERAL
You are Done[In this way -you can Select any Profile]
Hope this Helped -Dont forget to Rate ME......Thanks for Contacting FixYa...
Jul 09, 2010 | Nokia 6300 Cellular Phone
KX TGA244B How do I get the ringer back on
Handset ringer volume
4 levels (high/medium/low/off) are
available. The default setting is HIGH.
1 Press {MENU}.
2 Scroll to “Ringer setting” by
pressing {V} or {^}, then press {>}.
3 Scroll to “Ringer volume” by pressing
4 Press {V} or {^} repeatedly to select
the desired volume.
LTo turn the ringer off, press {V}
repeatedly until “Off ?” is displayed.
5 Press {Save}.
Note:
LWhen the ringer volume is set to off, the
handset will display “Ringer off”, and
will not ring for outside calls. The
handset will ring at the low level when
paged by the base unit.
Jan 05, 2010 | Lands Phones
Can't hear phone ringing
Adjusting the Ringer Volume (From the Uniden manual)
  1. With the phone in standby, press ArrowUp or Arrow Down on the handset or VOLUME + or VOLUME - on the base. The handset or base sounds the ringer at that level.
  2. Use Arrow Up on the handset or VOLUME + on the base to make the ringer volume louder.
  3. Use Arrow Down on the handset or VOLUME - on the base to make it softer or turn it completely off.
  4. When you hear the ringer volume level you want to use, stop pressing keys.
  5. The handset or base will use the new ringer volume starting with the next incoming call.
  6. If you set the ringer volume to Off, the handset or base won’t ring.
  7. Other handsets or base will ring according to their individual settings.
Jan 03, 2010 | Uniden DECT 6.0 Cordless Telephone...
How do you adjust volume on base ringer on uniden dxa15588-2
Setting the Main Base Ringer Volume
The main base has three ringer volume settings: high, low, and off. You can change
the ringer volume while in standby mode or while an incoming call is ringing.
1) Press the ringer key.
You hear the ringer at the current volume level
([ ] High, [ ] Low, [ ] off) (if you set the
main base ringer volume to off, “Ringer off” is
announced) and it is displayed on the main base.
2) Press the ringer key repeatedly until the desired ringer
option appears.
3) The system displays the new ringer volume.
Dec 30, 2009 | Uniden DXA15588-2 Twin Cordless Phone
How can I turn the ringer back on? Thank you
1 Press (MUTE/FUNCTION).
pressing öor ñ, and press á.
3 Press áat “Ringer volume”.
4 Select the desired volume by
pressing öor ñ.
•Each time you press öor ñ, the
volume will change and ring.
To turn the ringer OFF:
press örepeatedly until “Off ?” is
displayed.
5 Press á(Save key).
•A beep sounds.
To turn the ringer ON:
Press ñin step 4.
•The ringer will sound at the LOW level.
•You can exit the programming mode any time by pressing (OFF).
•If set to OFF, “Ringer off” will be displayed while the handset is not in use.
•If you have received new calls, “Ringer off” will not be displayed but
“Received calls” will be displayed while the handset is not in use.
“Ringer off” will be displayed for about 5 seconds after completing operations
or lifting the handset from the base unit or the charger.
•You can also select the ringer volume while an external call is being received.
Press öor ñwhile the handset is just ringing.
•You can change the ringer tone for external calls. See page 49.
HIGH
MEDIUM
OFF
Ringer volume
Low High
Ringer volume
Off ?
LOW
ñ
ñ
ñ
ö
ö
ö
V.M. access
HRinger setting
Initial set
HRinger volume
Ringer tone
18
LCD
Oct 26, 2009 | Panasonic KX-TG2352 Cordless Phone
Palm Treo 500 Centro Logo
110 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Raj Patel
Andrew Taylor
Andrew Taylor
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
