Question about Intel SE7320VP2 Motherboard
ERROR 51A2 SYSTEM COVER HAS PROBABLY BEEN OPENED - I NEED TO RESET THIS ERROR CONDITION
    President:
  • 948 Answers
Go into the BIOS and disable the error message unless you are not the owner of the computer or you care when someone has opened the case.
Posted on Jul 14, 2009
2 Suggested Answers
preachw996
  • 1179 Answers
SOURCE: 51A2 System Cover has probably been opened.
The chassis intrusion detsctor has been set off. You'll need to look at your owners manual for the steps to reset it. Good luck and hope this helps.
Posted on May 04, 2009
I have a error code 33, what error code is 33
Hi, These are some codes to your DLP HDTV.
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disc
Jul 20, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Ink System failure
There is a reset procedure that you should try, I will post it here.
Oct 15, 2008 | HP Photosmart C5180 All-In-One InkJet...
Error message 6c10
Close the Inner Cover
Close the inner cover to resolve the error condition.
Inner cover open 1
Inner Cover Closed 5
Press the <Resume> button after closing the cover to resume printin.
Also
Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Dec 03, 2010 | Canon iP4700 InkJet Photo Printer
Mitsubishi tv error code 21
The service manual does not list an error code for "21".
Here are the error codes:
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Sep 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
May 04, 2009 | Intel SE7320EP2 (SE7320EP2DG) Motherboard
Error(51A2): System Cover has probably been opened
It is probably a raid error. One of the drives may have failed.
May 04, 2009 | Acer Altos G530 Server
Car Idles Hot Temp
I don't know how the above could have any effect on temperature. Is the vehicle full of coolant? In my opinion you have two different issues
Apr 03, 2009 | 2001 Dodge Stratus
Printer stopped printing durring project "Assert Error b52b00b4"
From the HP website:
ISSUE: The printer displays an assert error code. Assert error codes indicate that the printer has an internal condition that may respond to a hard reset of the printer. Beyond that, service may be required. This document applies to the following products:
  • HP Photosmart p1000/1000, p1000xi printers
  • HP Photosmart p1100, p1100xi printers
  • HP Photosmart 1115 Printer
  • HP Photosmart 1215, 1215vm, 1218, and 1218xi printers
  • HP Photosmart 1315 Printer
SOLUTION: Hard reset of the printer A hard reset of the printer may clear the error. Here is how to perform the hard reset:
  1. Shut down the computer.
  2. Open the top cover of the printer and remove the print cartridges.
  3. Close the top cover of the printer.
  4. Press the power button on the printer to turn the printer off.
  5. Disconnect the communications, (USB or Parallel), cable from the back of the printer.
  6. Disconnect the power cord from the back of the printer for one minute.
  7. Reconnect the communications cable to the printer.
  8. Reconnect the power cable to the printer.
  9. Press the printer power button to turn the printer on.
  10. Open the top cover and reinsert the print cartridges.
  11. Close the top cover and print the calibration page.
  12. Restart the computer.
Mar 18, 2009 | HP PhotoSmart 1115 InkJet Printer
Error code 1 2
I found this list of codes
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
Feb 12, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Error 51A2: System cover has probably been opened
I hope there an option in the BIOS that could disable chassis intrution detection. Please check the BIOS settings....
Sep 25, 2007 | Intel SE7320EP2 (SE7320EP2DG) Motherboard
Intel SE7320VP2 Motherboard Logo
368 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
