Question about Maytag NMPEB08F2A Air Conditioner
I have a used Maytag portable a/c, model #SMPEB08F2A. It has a little hole at the bottom left in the back which may be a drain but I don't know how to drain the water out. How and where do you drain the water out? It also has a little drain about mid-way in the back and I get about a cup of water from that about every two hours. I don't have a manual so I don't know how it is suppose to drain. Can someone help with this.
    Champion:
  • 233 Answers
The drain is generally the midway in the back below the coil, there may or may no be an internal hose connected from the blower housing or evaporator coil housing, they are drained by gravity and the unit pitched to the outside should accomplish that if the drainage path is not clogged
Posted on Jul 15, 2009
I have a M6PO9S2A Maytag air conditioner. The red light was beeping so i emptied water. Have no manual so I did not know i was supposed to. Now it flooded by bedroom!! do I need to get rid of it or is there something else i need to do? HELP!
Posted on Jul 14, 2011
My Maytag refrigerator drains water from the bottom.Seems congestion in drain line.How to fix it? Bobby,Tennessee
The drain is normally in a little tray in the back of the fridge. Remove the food and the shelves and you will often find a small piece of food or a lump of mould blocking the small hole. Clean it and pour a little water down it. If it doesn't move, use a length of auto wire and push it down the hole. It goes to an evaporator tray on top of the compressor, to be evaporated as steam.
Oct 03, 2016 | Maytag Refrigerators
My Maytag refrigerator is leaking water from under it. Model MFI2569VEM
Just how old your fridge is I don' t know. But is your defrost timer working on your freezer. It should defrost at least once a day. You may want to check out the drain on the bottom of the fridge also. It may be partly clogged up. Then newer models have the coils go over the pan to help evaperate the water.
Aug 05, 2012 | Maytag Refrigerators
I don't know if there is a place to drain the air conditioner unit.
jbuck, Since your unit is a multifunction unit (AC, Heat & Dehumidifier) you don't have to darin any water. It uses an evaporative system, that exhaust the water/moisture thru the exhaust hose to the outside. With that said, there may be a rare occasion, that the condensation pan under the unit, needs to be drained. In which case, you will find the drain hole, covered by a plastic screw off cap, on the left rear of the unit (as you face the rear of the unit), next to the cord keeper. A small plastic bowl or pan that will fit under the drain hole will suffice. As, there shouldn't be that much water to drain.
Hope this helped you. Please let me know. Thanks.
Jun 12, 2011 | Haier CPN12XH9 Portable Air Conditioner
Maytag side-by-side refrigerator Model # MSB2154GR: Ice is forming in the bottom of the freezer under the basket?
Hello, Thank You for using FixYa. I will be helping you today.The drain line is frozen.Remove the back wall in the freezer and remove the ice.You can either use boiling water or a hair dryer.The drain hole is in the center bottom.Be careful not to touch or poke the evaparator(big aluminum thing) You have to remove all the ice until you see the hole keep pouring boiling water until the water runs down the drain.It is a easy job just takes some time.
Thank You and please rate my answer if it was helpful..
Jun 11, 2011 | Maytag MSB2654HE Side by Side Refrigerator
Found water leaking from our maytag side by side model MSD2142ARW. Disconnected ice maker 4 weeks ago thinking it was that, and still leaking and has ruined my new laminate floors. Is the freezer gasket or...
The defrost drain hole in the freezer side is frozen closed.
Turn off the fridge.Remove the bottom bin and look on the back wall of the freezer for the drain pan. It will have a block of ice in it. Use a hair dryer to defrost the pan AND the drain hole inside the pan,until you can pour a cup of water through the drain hole.
Dec 28, 2009 | Maytag Freezers
Water leaks out the left front. Water seems to pool and freeze in the bottom of the freezer. The leak is not alot but it never stops. Have checked for level have disconected the water and ice maker. Still...
You have a plugged up defrost drain. There should be a drain hole way in back of the freezer, at the bottom. (it should be behind the panel at the back of the freezer compartment) Use a turkey baster with warm water to flush it out until water runs out the hole into the defrost drain pan under the refrigerator.
Dec 08, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag refrigerator mbr2256kes leaks water about every 36 hours. It originates underneath, midway back and a little to the left (when looking at it).
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you have any other question. Mike
Nov 27, 2009 | Maytag MBR2256KES / MBL2256KES
Top tray not draining
I called the service tech, before Maytag stopped supporting this unit. (built by Fedders with Maytag name). Fedders has gone out of business (7-09). The tech guy said that the tray gets clogged up with crud and the solution is to try to flush the tray out with water and compressed air. I had the problem of water leaking from the trays but not properly draining through the drain hose. This solution did the trick.
Jul 24, 2009 | Maytag Portable Air Conditioner M6P09S2A
Maytag NMPEB08F2A Air Conditioner Logo
905 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
