Question about Craftsman 25cc Gas Line Trimmer
Craftsman trimmer #358791820 spool ran out and cant reload it?
The spool ran out of line and we bought replacement line but cant figure out how to reload the spool so the line stays on. Tried to find a skematic chart but cant! Help!
SOURCE: have craftsman 32cc gas line trimmer it runs until given gas
Replace the spark plug, clean the air filter and fill the tank with new fuel at the correct fuel oil ratio. Had the same problem last year. Tried to cheat with year old gas.
Posted on May 10, 2009
  • 376 Answers
SOURCE: Craftsman trimmer won't prime
A new carburetor would be simplest solution. You could try disassembling the carb, cleaning and replacing diaphrams, but just replacing the carb would be my choice. What is the model # on the trimmer and I can tell you the part # of the carb you need.
Posted on May 24, 2009
  • 46 Answers
SOURCE: change feed fuel feed line craftsman string trimmer
no should be fairly straight forward! you can find the tubing at ace lowes home depot! good luck & happy trimming!!
Posted on May 31, 2009
SOURCE: repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Posted on Sep 05, 2009
bbreton
  • 437 Answers
SOURCE: try to replace fuel line craftman weedwacker
You will need to get some TYGON fuel line. Match it up to the size of each fuel line, some of these trimmer use two different size lines, and remember which size went on which connection. You will want about a foot of each. Cut one end of each line at a 60 degree angle. With a pair of needle nose pliers, feed the angled end of the fuel line into the hole going into the tank and feed it into the tank untill you can see at the tank fill. You cut the angled end off and put your filter on the line. Pull it back until the filter lays at the bottom of the tank. Hook this line up to the supply side of carburetor. Take the other line and put it in the tank about 1" or 2"
then cut it off to fit on the carburetor. HTH
Good Day.
Posted on Nov 10, 2009
Craftsman model 138.74503 12 inch string trimmer
Loading the line is confusing because there is no arrow on the spool (despite what is written in the directions) but there is an arrow on the cap that points counterclockwise. However, disregard the arrow on the cap. As written in bold letters on Figure 15 in the manual, both lines are wound CLOCKWISE as seen looking down on the top of the spool. This works.
Jul 18, 2012 | Craftsman Garden
Replace trimmer line
The steps for replacing line in a single line trimmer head are virtually the same for many trimmer head types, like double line trimmer heads.
1. Remove the Trimmer Head Spool
Removing the spool is the first step in replacing trimmer line in any conventional trimmer head, but trimmer head spools can disassemble in different ways.
The trimmer head pictured above and below disassembles by simply unscrewing the knob around its arbor bolt. Other trimmer heads can use press tab and other twisting styles for disassembly.
2. Insert Trimmer Line and Wind the Line
Single line trimmer heads have just one channel in their spools for winding line. The channel will have a hole in it somewhere that keeps the line in place as it is wound around the spool. Insert one end of the trimmer line in the hole.
Depending on the trimmer head, it might be helpful to bend a small portion of the cutting line at an angle before inserting it in the starter hole. Also, cutting the line at an angle can help this first step on some trimmer heads.
Of course, it is also important to make sure that the replacement line matches the diameter specification of the trimmer head before beginning. Once the line is started correctly in the channel hole, you're ready to wind. Most trimmer heads will indicated the correct winding direction right on the spool somewhere.
It's also important to wind the line carefully, keeping it in neat rows as much as possible. The line will have a much higher chance to feed incorrectly during trimmer use if it suffers from sloppy winding.
3. Snap the Line into its Retaining Notch
A conventional trimmer head will have a retainer on its spool. Snap the end of the trimmer line into the retainer after it is wound around the spool. The retainer will hold the line in place as the spool is replaced in the trimmer head assembly.
4. Replace the Trimmer Head Spool
With the cutting line held in place, the spool is ready to be replaced in the trimmer head assembly.
First feed the extra trimmer line through the trimmer head eyelet. Make sure to release the line from the retainer before completely securing the spool into position.
Replace any knobs, bolts, or other trimmer head pieces removed during disassembly.
Your single line trimmer line is now reloaded, and your trimmer should be ready to get back to work.
Although there are many steps to reloading line the conventional way, a little practice and familiarity with your trimmer will speed the process up a great deal. Once you're up to speed, reloading trimmer line this way can take less than five minutes.
If you want to know about the double line replacement, please click this
Thanks.
Apr 01, 2012 | Garden
I NEED HELP PUTTING A NEW LINE .080 ON MY WEEDWAKER MODEL NO.358791820. I DO NOT HAVE A MANUAL . CAN YOU HELP ME THANKS
Go to the link below and you can download a manual.
http://www.managemylife.com/mmh/owner_manuals/28120/CRAFTSMAN-Line-Trimmers-Weedwackers-Gas-L0803243?brand_name_search=358.79182
May 18, 2011 | Sears Craftsman LiftMaster Chamberlain...
I need to feed the line back into the holes on the craftsman 17' 25cc weed trimmer. I dont know how to remove the line holder to replace
Although it is called dual line, only one line is used - except that you use both ends of the line. Cut off as much line as you think the spool will hold. Put the two ends together to find the center of the line. Some trimmers have holes to thread the lines through and others have a place to hook the bend at the middle of the line. if yours has threading holes, thread one end of the line through each hole and then pull on both ends until the bend of the center of the line won't allow any more slack. If your trimmer has the place to hook the bend, hook there and start winding the lines in the direction shown on the spool. Be sure one line is on one half of the spool and the other line on the other half. Wind both lines at the same time as smoothly as you can. When the spool is full, insert the loose ends through the trimmer head, insert the spool and pull on the strings. Hope this helps Tim
Here is a site that can help if I did not understand your question correctly:
http://www.ehow.com/how_7872475_replace-craftsman-25cc-line-trimmer.html
Apr 10, 2011 | Craftsman 25cc Gas Line Trimmer
How to install replacement line for a Ryobi 18v weedeater
The long bolt coming down at the end shaft like place reel over bolt then turn back and forth slowly while pushing upward and it should lock in and take knob or bolt at end and tighten to the right.
Jul 05, 2010 | Ryobi Garden
Have Craftsman gas weedwacker double line ran out.
take off knob that holds on the spool on bottom of weedwacker, remove spool, there are notches around the outside splines on the bottom of the spool. (the bottom is the end that fits up into the spool housing. there are 2 little holes opposite one another on the spool - one on each section. Cut two lengths of line about 6 feet long. stick line into first hole (near bottom of unit) wrap line around spool. once wrapped line gets short - to the point where you cant wrap it anymore - stick the end into one of the notches - do the same with the other line - insert spool back into housing - make sure spring is attached to the spool and lines come out of the holes in the housing - reinsert knob and tighten - make sure as you are doing this you unseat the ends of the lines off of the notches on the spool and they are out through the housing - tighten knob and you should be good to go
Sep 06, 2009 | Craftsman Garden
I need part for a Craftsman Weedwacker
You can either go to sears, or craftsman website or even easier if you can get one off of ebay
Aug 18, 2009 | Garden
Craftsman 25cc Gas Line Trimmer Logo
472 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
