Question about Logitech Cordless Mouse
My plug in mouse has stopped working, it will click and scroll but the pointer is frozen on one spot. i have tried plugging it in and out but it won't work there are no batteries because its a plug in mouse. the LED light is flickering... help?
  • 118 Answers
No solution--your laser is not functioning
contact logitech to check your warranty 5 years for most mice.if out of Warranty you may qualify for a credit thru logitech sales.
Posted on Jul 17, 2009
HP 2530p EliteBook - touchpad stopped working. Scrolling works except touch scrolling on right side of pad) and right button, but that's all. Wireless mouse works fine.
To access Mouse Properties, select Start - Control Panel - Hardware and Sound -Mouse.
Use Mouse Properties in Windows to customize settings for pointing devices, such as button configuration, click speed, and pointer options.
Jan 18, 2013 | HP EliteBook 2530p Notebook
My logitech wireless mouse for my laptop stopped working today. The green light still comes on, but the mouse appears to be frozen. I checked the batteries, tried the reset button, made sure it was turned...
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer then if your mouse works click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver in
make sure the battery is good ((has full charge))also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
Windows 7
hope this helps you
Aug 07, 2011 | Computers & Internet
I have a usb wired dynex optical mouse, i just bought a Toshiba sattelite laptop and external mouse does not work when i plug into usb port
Windows 7
make sure you turn the mouse on depending on type/brand of mouse it will vary it could be a buuon or switch on top or bottom
hope this helps
Jul 01, 2011 | Computers & Internet
Hp morfb1uo cursor is frozen everything else working fine
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
click start control panel administration tool computer managenent device manager scroll to mice and other pointing devices you might see a yellow question mark? right click to update drivers
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
(if applicable)
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
hope this helps
Jun 11, 2011 | Computers & Internet
Compaq notebook laptop: my mouse pointer or arrow is
If you have a manual for the notebook, check to see if you can use the function key and the similarly coloured key on the keyboard which enables/disables the touch pad. Usually you can disable the mouse pointer touch pad with this FUNCTION key + MOUSE key when pressed together. Often these keys have the same colour (usually blue). The purpose is to disable the touch pad when you are using an external USB or wireless mouse, then you press the 2 keys again together to enable the touch pad once you have removed the USB/wireless mouse.
If that doesn't work, borrow a USB mouse and attach it to your notebook to use temporarily while you diagnose the problem.
Dec 19, 2009 | Acer Aspire 5100 Notebook
Mouse pointer keeps wavering in the screen. Im not
try to look for the proper signal, try to click the button on the mouse, or try to unplug it and plug it again.hope it work.
Sep 30, 2009 | Samsung Pleomax SCM-9000 Mouse
Mouse is hooked up and lighted up, but no action!
lol ur os duznt matter...
chek whether the front part of the mouse is completely in place...
my mouse also stops responding when it falls...
chek the wire... move it and chek..
i suffer this problem too
May 16, 2009 | Dynex Wireless Optical Mouse
The mouse clicks work, but the pointer never moves
Here is a link for the driver download. You may download this driver, after you click the link scroll down to your part# and click on the download link. Hope this helps.
p.s this will work for vista op systems
http://www.jascoproducts.com/support/vista-certified-products.asp
May 03, 2009 | GE Computers & Internet
Laptop touchpad is left-clicking when it is touched.
hi,
Please reduce the touchpad sensitivity. that shld take care of teh issue.
inu
Dec 09, 2008 | Gateway MT3705 Notebook
Message saying alps pointing devive has stopped working, can still move mouse pointer but cant use the scroll function
A possible fix for the Alps problem Your Alps pointer problem is probably driver related. To fix it:
1. Open Windows Explorer
2. Right click on Computer & choose properties
3. Open Device Manager (Admin password may be required)
4. Under Mice & other pointing devices, right click Alps pointing-device & choose Update driver software
5. Choose Search automatically & it will download and install the latest signed driver from the windows repositories & hopefully that will fix that problem.
Jun 14, 2008 | Computers & Internet
Logitech Cordless Mouse Logo
356 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
