Watches Logo
A
Anonymous Posted on Nov 13, 2015
How do I turn off the alarm on Armitron 45/7042?
I have followed instructions. I get into the alarm mode but then when I press "C" button, it just changes the time for the alarm. I then press "A" reset and it changes from hour to minutes. The alarm keeps beeping at me. I don't want the alarm on. Help.
Trisha Wilmoth
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 06, 2016
Trisha Wilmoth
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
13515
Points
Hold A, and B and press C, mine shut off
  • 1 more comment
  • prbloomq
    prbloomq Dec 20, 2016
    Thank you. nobody made a youtube for this specific watch
  • Anonymous Dec 29, 2017
    This answer assumes everyone knows which buttons are A, B, and C, which isn't helpful if you don't have the instructions anymore.
  • SHERRY JANSEN Sep 03, 2018
    Mine didn't even come with instructions
Amanda Wilburn
Level 1:
  • Posted on May 27, 2020
Amanda Wilburn
Contributor
Level 1:
Answers
Questions
0
Helped
13515
Points
In case someone else comes for answers.. to shut the alarm off on an Armitron Pro Sport MS063(R) 45/7042, push the top left (A) and top right (C) buttons at exact same time and hold down until you hear a beep. That turns alarm on/off.
I've been searching for a manual (or just answers, period!) for this watch for 45 minutes now. There are links shared everywhere (just like the links shared in these answers) but I have yet to find the manual to this specific watch. Directions from other Armitron watches do not work on this one, I've tried.
Now.. I will continue on my journey on figuring out how to turn the hourly chime off on it.
  • Amanda Wilburn May 27, 2020
    Whew! Luckily found out the hourly chime issue too, by one of the other answers on here by Frann Lu! Yyeesss! (Didn't know that's what he was giving directions for since the original question was asking about the alarm).
    So, to shut off the hourly chime on a MS063(R) 45/7042 Armitron Pro Sport watch, check out Frann Lu's answer on this page!
Frann Lu
Level 1:
  • Posted on Oct 12, 2019
Frann Lu
Contributor
Level 1:
Answers
Questions
0
Helped
13515
Points
6
Press and hold the button on the top left corner. The display will change to showing what the last scheduled alarm was/is. While holding this button, press the bottom on the bottom left corner. If all of the days of the week appear at the top of the display, the hourly chime is on. If no days of the week appear, the hourly chime is off.
5 Related Answers
Anonymous
  • 5 Answers
  • Posted on Sep 07, 2008
SOURCE: Armitron WR165 watch - changing time
When you're in the regular time mode press "set". The secons should blink. Pressing "mode" brings you to the hour spot (hour should blink). Press "adj" to change the hour. To set the min., press "mode" again and the min. spot should blink press "adj" to change. Keep pressing "mode" then "adj" until all necessary time components are set correctly. Press "set" to get to regular time mode.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Mar 09, 2009
SOURCE: I have a Ladies Armitron All Sport watch Model
Follow this link and find instructions for your watch:
http://www.armitron.com/watch_instructions.asp
Do not forget to rate, please.
Anonymous
  • 2501 Answers
  • Posted on Mar 18, 2010
SOURCE: I have an Armitron 40/8125 watch. I try to set the
You need to press button A to enter the time setting mode and then press C.
If you have lost your instructions, you can get instructions from the Amitron web site.
Copy "www.armitron.com/watch_instructions.asp" into your search engine and you will see a list of illustrations of watches and associated
instructions.
Choose the one that looks like yours and download the PDF file.
gemineye61
Janelle Schoonover
  • 842 Answers
  • Posted on Aug 17, 2010
SOURCE: setting the time... I press
Sportline has a very complete website that should be able to assist you more direct. A little more complicated watch then I am able to assist you with. Best regards.
http://www.sportline.com/faq.php
Anonymous
  • 4 Answers
  • Posted on Aug 23, 2011
SOURCE: 5034 G-1000 Cannot set Date/Time
gibb erish....the same problem that already happened it on me..but there is a solution for that.just focus..let your excitement blow up if u done it will..
a manual has shown a combination of bottons to press..there is a diagram showing the combination to press so that it will beep. just try.. sometimes i press D go back to A and try long press tell it beeps and so on just follow the manual.. while the hands are still on movement just wait to stop before you press some bottons..be patient our watch is awesome..
I can't change the hour on my armitron MD0699 no matter if I follow the instructions or not
Examine the watch face and locate the buttons labeled "Mode," "Adjust" and "Alarm." Press the "Mode" button repeatedly until the time display appears on thewatch. Hold the "Mode" button until you see the alarm display appear, then release the button. Hold the "Mode" button a second time to enter the time-setting mode.
4helpful
Instructions for Armitron All Sport 40/6623 time setting needed.
Here's how you set the 40/6623 M175 for anything. I figured it all out with help from here :). Okay so want to set the alarm? Press MODE once. Then hold it. And use the DATE and ALARM buttons to set the alarm. Press MODE twice and you're done. To set time do the step before this and press MODE once. Use the DATE and ALARM button to set the time. As for the 24 hr deal what you do is hold ALARM and press MODE or hold MODE and press DATE. To turn alarm on/off hold ALARM button and then press the DATE button. To set the date go to time set mode and keep cycling between the hours and mins until you get to the date :). That's all you gotta do :D. I know many of you need the instructions so here it is!!
32helpful
2answers
Watch instructions for Armitron m721 (49/1009 GP) need to set time and date
Hi mandardani,
You can change the time and day of your Armitron watch by following the steps below.
1. Press the MODE button once. This will put you in the timer.
2. Press and hold down the MODE button. This will put you in the alarm set display.
3. Press the MODE button once more and it will put you in the time set display.
4. Use the ST/SP button to change the blinking portion of the time. Then use RESET button to move you thru the different parts of the time/date.
Hope it helps.
Thank you for using FixYa.
4helpful
How do I set the hour, minute, date etc.
Thank you for contacting FixYa.
    Setting the Time and Date
  1. To set the time and date on your Armitron digital watch, begin by pressing the "A" button while in time-telling mode. The seconds place will begin to flash; press the "C" button to reset the seconds to "00". Press "B" to set the hour, and press the "C" button repeatedly until the desired hour is reached. Press "B" to set the minutes, pressing the "C" button until the desired minute is reached. Press the "B" button, followed by "C" to set the month, date and day of the week. When you are finished programming the time and date, press "A" to save and return to time-telling mode.
  2. Using the Chronograph
  3. To use the chronograph feature on your digital Armitron watch, press "B" while in time-telling mode to access chronograph mode. Press the "C" button to start the timing; press "C" a second time to stop the timing. To reset the chronograph, press the "A" button. Press the "B" button at any time to return to time-telling mode.
  4. Using the Split Lap Chronograph Feature
  5. To use the split lap feature on an Armitron digital watch, press the "C" button while in chronograph mode. Press the "A" button to measure splits or laps; at the end of the event, press the "C" button to stop the timing. Press "A" once to see the final split or lap time, press "A" twice to reset the chronograph to "0". Return to time-telling mode by pressing the "B" button.
  6. Setting an Alarm
  7. To set an alarm on your Armitron digital watch, press the "B" button twice to access the alarm mode. Press the "A" button and wait for the hours place to begin flashing, then press the "B" button twice. Press the "B" button, followed by the "C" button to set the hour and minute of your alarm. When you're finished, press the "A" button to save the alarm. Press the "B" button to return to time-telling mode.
  8. Using the Countdown Timer
  9. To use your Armitron digital watch as a stopwatch, begin by pressing the "B" button three times while in time-telling mode to access the countdown timer mode. Press the "A" button, followed by the "C" button to set the hour. Press the "B" button, followed by the "C" button to set the minutes and seconds. Once you've set your timer, press "A" to return to countdown timer mode. To stop the countdown timer, press the "C" button. When you are ready to reset the countdown timer, press the "A" button. To return to time-telling mode, press the "B" button.
Best regards. Jewel
1helpful
How do I turn off the alarm on my Armitron watch?
I don't know whether this is what you are looking for, as the watch comes with no packaged instructions OR general support, on their website, XD,
Nik.
http://home.earthlink.net/~eldonenew/armitron.htm
or
http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Armitron All-Sport Watch Instructions By Brian Walker eHow Contributor 9 Found This Helpful The Armitron All-Sport is a unisex style of watch made by Armitron that features a digital readout and four buttons around the outer dial for adjusting various aspects of the watch. It can set alarms, keeps the time as well as the date, and has a built-in backlight. Accessing and adjusting these various settings is a fairly simple process.
Other People Are Reading
Setting Date, Time and Alarm
  • To enter the date and time setting mode, press and hold the "mode" button, located on the top-left of the watch. Continue holding this button until the display begins to flash. This first display is the alarm setting, should you choose to set an alarm to go off. If you'd like to set the alarm, use the "alarm" button on the bottom-right of the watch to advance the hours to the desired one. Then press the mode button again; this will cycle through the minutes and seconds of the alarm to allow you to set those as well. Once you have set the alarm, you can press the "date" button at the top-right of the watch to proceed to the regular time setting. These numbers, which will now be flashing, also are adjusted by pressing the alarm button to change them. Pressing the date button again will now cycle through the hours, minutes, seconds and the date. As you continue to press the date button, the All-Sport will continuously cycle through these options; don't worry if you forget to set one, you can simply press the date button a few times until you get back to the setting you need to change. Once the alarm, time and date have all been set, you can press the mode button one more time to exit to the normal watch mode that will display the date and time.
Using Chime and Alarm
  • The Armitron All-Sport features both an alarm and an hourly chime. The alarm function will cause the watch to continuously beep at the selected time until you turn it off by pressing a button. The chime will cause the watch to beep once every hour. You can turn both these features on and off by pressing and holding the alarm button and while holding it pressing the date button. The first time you do this, the chime will turn on and a small house symbol will be displayed on the watch face. Performing this button-pressing sequence again will turn on the alarm, which in turn displays a small clock icon on the watch face. Each successive pressing of this button sequence will alternate between the chime and the alarm, turning them either on or off.
Backlight
  • The All-Sport also features a built-in backlight to help you view the watch in dark conditions. This light can be activated by pressing the "light" button on the bottom-left of the watch. Pressing this button is the only way to activate the light, and doing so will only cause the watch to illuminate for a few seconds at a time.
Read more : http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
I cant get the time set correctly! When i follow instructions it just seems to set the alarm! How do i do it?
Hi jeffrey_lafi,
You can easily change the time and date of your Armitron watch by following the steps below.
Hope it helps.
2answers
40/8125 - how do i set time and 24hr time and chime
You can get instructions from the Amitron web site.
instructions.
1helpful
I have an Armitron 40/8125 watch. I try to set the time as follows 1)Hold B - Alarm hours flash 2) Press C - Alarm minutes flash 3) Press C - It goes back to Alarm hours flashing where it should advance to...
instructions.
108helpful
2answers
How to set an Armitron WR330 Watch
he following labels are on the inner ring of the watch; I've given their positions relative to where numbers would be on the face of an analog watch. "ST/STP" is at 2:00; "EL" is at 4:00; "MODE" is at 8:00; and "ADJ" is at 10:00.
To set the time, date, and day of week:
Press and hold in the "MODE" button until the display starts flashing. (This is the alarm time.)
Press the "MODE" button again; the seconds begin flashing. Press "ADJ" to set them to zero.
Press the ""ST/STP" button to change what you want to set. The options appear in this order each time you press the "ST/STP" button: minutes, hour, month, day, day of week.
Use the "ADJ" button to change the value of the setting.
Touch "MODE" to save the settings and return to time mode.
The website listed below has many instruction sheets, but does NOT have instructions for this watch as of 25 December 2008.
Check:
http://www.armitron.com/WatchInstructions.html
Mar 15, 2009 • Watches
124helpful
3answers
Ladies Armitron 45/6967
Armitron alarm/chrono
1.To set the time hold the mode button until the alarm flashes, then hit it one more time and the time will flash to be changed. Once the alram or time is flashing use the ST/STP button to navigate between hour, minute, month, day and day of the week, the ADJ button changes the numbers.
2.While holding down the ADJ button use the ST/STP button to turn off the hourly CHIME and the ALARM chime.
Hope this helps!! K~~
Top Armitron Watches Experts
Gene Lawson
ADMIN Andrew
ADMIN Andrew
NOEL
NOEL
Are you an Armitron Watch Expert? Answer questions, earn points and help others
